Arborwear
Author Topic: Setworks Project...your input is requested  (Read 2232 times)
Offline JB Griffin
Re: Setworks Project...your input is requested
« Reply #20 on: July 15, 2017, 08:44:43 AM »
Ga, I like the setworks upgrade. If you were to make a replacement or fix for those of us with the old setworks I would gladly test it out for you. My setworks has quit and I can't see paying $700+ for a new encoder with a display that's on the fritz.
2000 LT40hyd remote 33hp Kubota, 160 Prentice, Frick 2 saw gang edger, Wright W-37 ABG, Suffolk dual tooth setter, Cat claw single tooth setter,'96 F-250 7.3 PSD 4x4, CS-590 Echo, MF 20c, M681 Memo.
1.8 million bdft sawn with a Baker Dominator and counting.
Online Ga Mtn Man
  • Y'all can call me GMM
« Reply #21 on: July 18, 2017, 07:51:02 PM »
I do have plans to do something and I will keep you in mind JB.
One reason I took on this project was I hoped to be able to increase the head UP/Down speed.  Several years ago I played around with putting a larger pulley (AK32, same as on Super mills) on the lift motor and it did speed up the head by about 50% but I couldn't get the SimpleSet to work accurately at that speed.
AK32 pulley next to stock AK22 pulley.
The new setworks controller has plenty of adjustability that should allow it to operate at a wide range of speeds, but I had not tested it yet at anything but the "Standard" speed.    I got the chance to try the larger pulley again today and after some tweaking of the settings...
...I'd say it's working pretty good!  The head is dropping at about 2"/sec.
Online POSTON WIDEHEAD
  • Getting old but doing it with Friends.
« Reply #22 on: July 18, 2017, 09:59:54 PM »
If the head drops at 2" per sec.....Thats moving!
Where's the Spoon?
Online Ga Mtn Man
« Reply #23 on: July 19, 2017, 09:48:12 AM »
"If"!  Do you doubt me sir?  :snowball:
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #24 on: July 19, 2017, 12:07:38 PM »
NO SIR!!
Online Ga Mtn Man
« Reply #25 on: July 19, 2017, 02:23:15 PM »
Sorry Danny, didn't mean to scare anyone.  I sometimes forget just how intimidating I can be. ::)
« Reply #26 on: July 19, 2017, 04:20:37 PM »
Talk about putting somebody in "Goat Mode".  :D :D :D :D :D
Where's the Spoon?
Offline 4x4American
  • Team red, white, blue and orange
    • Website Link
« Reply #27 on: July 19, 2017, 09:56:24 PM »
Goat Mode is a trademark pending term so don't be using it too loosely otherwise I might could charge ya for it lol
Boy, back in my day..
Offline JB Griffin
« Reply #28 on: July 19, 2017, 10:13:30 PM »
Ga, whats the setworks reading off of to know where the bed is, the dro?
Online Darrel
  • Never throw an unopened log on the burn pile.
« Reply #29 on: July 20, 2017, 09:24:58 AM »
"Two inches per second"
That's the same speed at which your coffee drops after you swallow it in the morning!  :laugh:
No doubt! :D :D :D
1992 LT40HD
Offline D6c
« Reply #30 on: July 20, 2017, 09:37:23 AM »
I was wondering the same thing....how do you "home" the vertical position on start up?  Is there a limit switch at the bottom of the travel like on a machine tool?....drop down to the limit switch and then continue to a set point on the encoder?
Online Ga Mtn Man
« Reply #31 on: July 20, 2017, 09:08:30 PM »
Sorry 4x4, you were too late trademarking "Goat Mode".  I checked the ofishial govment website and you were no where to be found.  So it is mine.  GOAT MODE coming to a setworks near you.  Video to follow  ;D.
JB & D6c--  The blade position routine tracks the blade by counting encoder revolutions (full and partial revs), adding and subtracting as the head moves up and down.  There is a "Calibrate Blade Height" function similar to the Accuset2...move the blade to 10" (I chose 10 instead of 12 cuz the math is easier :laugh:) and press and hold the secret button.  The encoder count is then reset to the correct rev count for 10", which is the encoder gear ratio x 10" (10.640 x 10 = 106.400revs) .  There is an interrupt routine that is triggered on power-down that saves the current blade position to EEPROM.  This saved value is reloaded into the blade height variable on power-up, so the blade position is retained .  In theory the blade height should never have to calibrated again after the first time.  In theory.
Offline customsawyer
    • The Custom Sawyer
« Reply #32 on: July 21, 2017, 03:26:44 AM »
Most impressive.
Two LT70s and to much other support equipment to mention.
www.thecustomsawyer.com
Offline hackberry jake
« Reply #33 on: July 21, 2017, 06:59:02 AM »
How does it save to eeprom if power is lost?
Online Ga Mtn Man
« Reply #34 on: July 21, 2017, 02:14:42 PM »
When the +12V supply falls below a certain level, the interrupt is tripped, giving a short window to save the values before the +5V (LDO) regulator drops out.
« Reply #35 on: July 22, 2017, 04:28:47 PM »
I wish I would have thought of that. I programmed mine to save to eeprom after every command. And eeprom has a limited read/write life, so your way is much better.
Offline slider
  • sawyer,trucker,tree service
« Reply #36 on: July 24, 2017, 07:47:20 AM »
Intimidating,yes you are Paul like you were at the first project but after this i think i will just sit in the truck at the next project.
al glenn
Online Ga Mtn Man
« Reply #37 on: July 24, 2017, 10:14:14 AM »
You must be thinking of someone else Al.  As I recall it, I stayed off to the side the whole time, afraid someone would figure out I had no business being there amongst the real sawyers. :-\
Offline slider
« Reply #38 on: July 24, 2017, 04:31:17 PM »
Dang if i had known that i would have introduced my self sooner.we would have fit right in.
al glenn
Offline 4x4American
    • Website Link
« Reply #39 on: July 24, 2017, 07:25:29 PM »
Oh Paul I remember you blasting down Jakes drive with your sawmill lettering all over your pickup like you owned the joint lol lol
Re: Roadless areas input requested
Last post August 03, 2001, 06:47:50 AM
by swampwhiteoak
Requested Project From A Special Person
Started by Andy White on General Woodworking
Last post March 14, 2014, 05:05:41 AM
by Freedom6178
My log splitter project - Input needed
Started by bmcdowell40 on Firewood and Wood Heating
Last post March 13, 2014, 05:49:19 PM
by Cguignard
Swingblade or Twin blade setworks with log cut solution DIY design project
Started by CaseyK on Sawmills and Milling
Last post October 05, 2015, 12:32:37 AM
by CaseyK
