Arborwear
Author Topic: new sawmill incoming, what to saw first (poll)  (Read 1611 times)
Offline runmca
« on: July 14, 2017, 08:21:28 PM »
Hi Everyone,
My Junior Peterson mill is on it's way from Left Coast and should arrive within a week or so. I've only sawed a few logs with my Alaskan mini mill so not much experience at all (none with a swingblade). I thought I would have the FF decide what to mill first. So here's what I have so far, all around 8' in length. I have no idea if this wood will be usable but it will be fun trying. So please make a vote, and any comments or suggestions would be appreciated too. I'll post pics of the 'winners' results, unless they are too embarrassing :laugh:
Cheers!
Offline JRWoodchuck
Re: new sawmill incoming, what to saw first (poll)
« Reply #1 on: July 14, 2017, 08:34:15 PM »
I would use the log you care about the least and go from there! Good luck.
Home built bandsaw mill still trying find the owners manual!
Offline MbfVA
    • Tanglewood Ordinary Country Restaurant
« Reply #2 on: July 14, 2017, 08:35:09 PM »
 Start with the one that's least valuable, make your mistakes there.
Add:  looks like consensus to me
Offline DR_Buck
  • Nuff said.....
    • Got Logs?
« Reply #3 on: July 14, 2017, 08:56:07 PM »
Find one full of nails and get that experience out of the way right up front.   ;D
Hidden Acres Farm
Been there, done that.   Never got caught
Wood-Mizer LT40HDG38
Lucas Dedicated 60" Slabber
Offline MbfVA
« Reply #4 on: July 14, 2017, 09:10:45 PM »
 And I believe he works for a retipping service  smiley_sun
Offline runmca
« Reply #5 on: July 14, 2017, 09:21:07 PM »
The pin oak was a roadside and has a stain so that would be a good nail candidate. The elm is a roadside too.
MbfVA - I see you have the JP's big brother, I've been following your other threads. I hope all is going well.
Offline DanMc
  • Thankful for this forum!
« Reply #6 on: July 15, 2017, 01:23:58 PM »
I voted for the locust only because it's one of the smaller logs.  Start small and work your way up.  But what do I know, I have only gone through about 10 logs so far myself.   I started out with the smallest.   The big ones are heavy, so they have more opportunity to hurt you if they do something unexpected.
Woodland HM126 mill
JD 4600 tractor
28 acres of trees.
Offline SineWave
« Reply #7 on: July 15, 2017, 05:53:27 PM »
Doesn't really matter so long as it's not the log clamp!  :D
Offline Sawmill Man
« Reply #8 on: July 16, 2017, 08:09:11 AM »
The straightest one you have and make stacking sticks out of it .
"I could have sworn I went over that one with the metal detector".
Offline woodweasel
  • I'm No Longer New, But Green As A Gord
« Reply #9 on: July 16, 2017, 08:19:04 AM »
Saw them all, makes no difference which one you start on. Get er done 8) 8)
Offline terrifictimbersllc
    • Terrific Timbers LLC
« Reply #10 on: July 16, 2017, 04:02:28 PM »
I said the 17" oak.  give yourself some width to dial in your mill adjustment settings.  I was going to tell you to go get a 28" dried out Christmas tree spruce log but then I backed off, that's bandsaw humor.  Good luck with it.
DJ Hoover, Terrific Timbers LLC,  Mystic CT   2001 WM LT40SHDD (42HP Kubota, Accuset2, FAO's, Lubemizer, debarker, hydraulics everywhere), Peterson WPF 10-30 with chain slabber. LogRite fetching arch, WM BMS250 sharpener/BMT250 setter.
Online 4x4American
  • Team red, white, blue and orange
    • Website Link
« Reply #11 on: July 16, 2017, 09:23:19 PM »
I voted for the black locust because of the end use, usually you shove locust into the ground after you saw it or use it for deck boards or whatever industrial application so it don't quite matter it its a little messed up
Boy, back in my day..
Online Darrel
  • Never throw an unopened log on the burn pile.
« Reply #12 on: July 17, 2017, 12:22:55 AM »
I voted for the sassafras on account of because it's the one I'd most like to see and smell. No such tree in these parts. No oak, pin or otherwise here either.
1992 LT40HD
Offline runmca
« Reply #13 on: July 17, 2017, 09:37:18 AM »
Thanks for the comments/suggestions everyone.
If the wood is usable, here are my initial thoughts
elm - workbench tabletop
locust - raised garden bed
sassafras - outdoor chair/table
oak - ?
Darrel - we have a bunch of sassafras around us, we use the saplings to make root beer. Still working on the recipe but pretty good stuff  smiley_beertoast
Offline fishfighter
« Reply #14 on: July 17, 2017, 10:37:06 AM »
Bought my mill a couple years ago. I used a couple boards that came off my mill this weekend that were some of the first boards I sawed. ;D
Offline Ox
  • Trying to learn/remember something new every day.
« Reply #15 on: July 18, 2017, 10:27:56 AM »
Black locust - you need something to put down on the ground to stack your other lumber on.
Offline runmca
« Reply #16 on: September 09, 2017, 07:33:16 PM »
Finally got the mill up and running 8) The rails were lost in transit so I had to wait for another set to arrive.
So I worked the the black locust (the winner). It had some rot, not the greatest log but worked out because I had to make some minor adjustments to the blade. I had a few other locust logs that were a bit smaller and they were not so great either, but fun to learn with. I got about 50bf. Tomorrow I will practice sharpening the blade and maybe start on the sassafras. I had a good time and can't wait to practice some more. Oh yeah, and here are some pics  :)
Online Ianab
« Reply #17 on: September 09, 2017, 09:29:32 PM »
 :D  Picked one of the hardest woods to learn on. But the little mill handles it fine.  8)
Offline Bob_T
« Reply #18 on: September 11, 2017, 02:44:34 PM »
Good looking mill and lumber.  Looks like your dog is happy with your new mill too.
1959 FWD Model 286 Dump Truck
1955 Allis Chalmers HD-6G Crawler Loader
1941 GMC CCKW 6X6
Wood-Mizer LT30 G18
Poll: Sawmill involvement
Started by Ron Wenrich on Poll Archive
Last post November 27, 2006, 07:10:18 AM
by DWM II
Sawmill satisfaction poll
Started by Jeff on Poll Archive
Last post January 16, 2004, 08:14:44 AM
by Frank_Pender
question
Sawmill Type Poll
Started by Captain on Poll Archive
Last post November 20, 2003, 10:49:21 PM
by KiwiJake
moved
MOVED: Poll: Sawmill involvement
Started by Ron Wenrich on General Board
Last post November 26, 2006, 08:55:16 PM
by Ron Wenrich
