Arborwear
Author Topic: What a Difference More Horsepower Makes !!!  (Read 1428 times)
Offline DR_Buck
  • Nuff said.....
    • Got Logs?
« on: July 14, 2017, 08:54:32 PM »
Today I went to PA Wood Mizer to pick up my mill.  It's been there since mid June when I took it up after breaking a crankshaft.
( That sad story is here : http://www.forestryforum.com/board/index.php/topic,96578.msg1490435.html#msg1490435 )
After weighing the cost of repairs against other options I decided a new engine was the way to go.  I also splurged for more HP.   The mill came with the Kohler 25 HP and because the engine design had changed some replacement cost was close enough to the cost of moving up to the Kohler 35 HP so that is what I decided to do.     I had Wood Mizer do the work because right now I have no extra time to fool with it.    Marty Parsons at PA Wood Mizer did the work and it turned out great.   First thing I learned was the engine that came in was the new EFI 38 HP Kohler.   8)   He also found several other problems that needed attention and took care of them as well.
Late this afternoon when I got home from PA I set up the mill to try it out by cutting a dozen rafters for one of my equipment sheds.  WOW   8)   What a difference.   The blade moves so much faster and I was able to push through the log like I never did with 25 HP.   It was almost scary.   I'm pretty sure I'm really going to like having 13 more horses spinning the blade.
Here are a few pictures of the new engine on the 2003 LT40HDG25, Now an LT40HDG38.  ;D
Hidden Acres Farm
Been there, done that.   Never got caught
Wood-Mizer LT40HDG38
Lucas Dedicated 60" Slabber
Offline Peter Drouin
    • A&P Saw mill LLC
Re: What a Difference More Horsepower Makes !!!
« Reply #1 on: July 14, 2017, 09:37:25 PM »
Good, 8) 8) Did it come with a new crank support?
2008 LT40 super,2008 edger, Cat telahandler, JD 5410 And can cut up to 45' long
http://www.forestryforum.com/sanbornton     NH Timberland Owners Association supporter.
And a license NH soft wood grader.
Sawing since 1987
Offline red
  • we will never forget
« Reply #2 on: July 14, 2017, 09:56:40 PM »
Very Nice , Horsepower is King
We have a lot of good boys and girls in harms way
lets all support them and their familys.
Offline SineWave
« Reply #3 on: July 15, 2017, 06:52:40 AM »
Good deal, have fun with her.
I'm with Peter, did it come with a crank support bearing? Would love to see a pic of it, if so...thinking about designing one into my home brew mill...
Offline MartyParsons
  • Wood-Mizer Service and sales PA, VA, MD, WV others
« Reply #4 on: July 15, 2017, 09:02:22 PM »
Hello,
  WM does not use crank support bearings on the gas engines. Not sure it is needed.
Marty
There are some things to think about when going with a larger engine that may give you issues in the future.
The 38 hp has a wire for a oil pressure light. We did not install a light on this project. You could purchase a new operator front cover and it would have a place for the light. If you are changing to from a diesel to gas. The light would be already there.
Up down circuit breaker on this mill was 30 amp, it tripped the first time we did a test cut. We did raise the amps of the breaker to 40. WM recommends installing a 1 hp motor to lower the amps with the added weight.
The other thing we needed to install was a 3/5 v belt from the 2 BX belt. There was some added cost to the retro from changing the pulley from 2 to 3 grove.
The engine kit comes with a new pin, engine mounting plate and the covers for the belt.
Marty
A pessimist sees difficulty in every opportunity; an optimist sees opportunity in every difficulty. -Winston Churchill
Offline ladylake
« Reply #5 on: July 16, 2017, 06:40:29 AM »
 I'd think most industrial motors are designed for a heavy side load a its very rare the hear of a Kohler crank breaking, every manufacturer can get a bad one once in a while. In the case of Cat motors they got a bunch of bad ones or maybe cheapened them up as too many company's are doing which most times costs them more in warranty work and reputation .  These Cat cranks are breaking in skid loaders with no side load so time will tell if the bearing support helps.   Steve
Offline jmouton
  • never enough time
    • Log-Gistics
« Reply #6 on: July 17, 2017, 07:24:22 PM »
what i want to know ,  who is the moron who designed an oil filter upside down ,,,i hate that ,,,just sayin
lt-25 woodmizer,25 hp kohler,hyd loading,fiat tractor,bobcat,international flatbed,10 ton trailer, stihl 075,041,029,and a 2015 f-350,and a oldwheel loader ,grapple system coming soon!!
Offline GAB
« Reply #7 on: July 17, 2017, 08:23:52 PM »
Someone very green and sopping wet behind the ears newly minted engineer.
I made a good living correcting their lack of experience designs.
Gerald
Offline Chuck White
  • Sawing Mobile since 2005
« Reply #8 on: July 17, 2017, 08:29:37 PM »
First off, I don't know!   ;)   ;D
I had a lawnmower that had an upside down oil filter and one of the guys in the mower shop let me in on their SECRET!
When you get ready to change the oil, get the engine up to operating temperature, get your catch-pan ready and loosen the drain plug, then take a hammer and nail and punch a hole in the highest point on the filter, then remove the drain plug!  Before unscrewing the oil filter, put a piece of tape over the hole that you made in the filter!
Doing it this way, minimizes any oil spill!   ;)
~Chuck~
I LOVE MY SAWMILL
Offline Kbeitz
  • Never enough time...
    • My Hobbies
« Reply #9 on: July 17, 2017, 08:32:19 PM »
I'll have to remember that trick.
Love machine shop work
and Wood work shop work
And now a saw mill work
Offline jmouton
  • never enough time
    • Log-Gistics
« Reply #10 on: July 17, 2017, 09:28:40 PM »
me too
Offline DR_Buck
  • Nuff said.....
    • Got Logs?
« Reply #11 on: July 17, 2017, 09:35:47 PM »
I'm betting that oil filter drains into the crank case when the engine is off.     I gusee I'll find out for sure at the 1st oil change.  :-)
Hidden Acres Farm
Offline SlowJoeCrow
« Reply #12 on: July 19, 2017, 08:09:33 AM »
Very good trick!!!  Even if it does drain out into the crankcase when the engine is off, a proper oil change is done when the oil is at operating temperature.  So if you do that, there will be oil in there.
sad
What a difference a year makes
Started by chet on General Board
Last post April 14, 2013, 02:52:46 PM
by SwampDonkey
Old and New Growth wood,What makes it old and what makes it new?
Started by JOE.G on Forestry and Logging
Last post January 05, 2013, 10:29:21 PM
by Jay C. White Cloud
Old horsepower vs new
Started by Mike-in-Virginia on Sawmills and Milling
Last post February 03, 2014, 08:01:28 AM
by bandmiller2
One horsepower splitter
Started by r.man on Firewood and Wood Heating
Last post February 27, 2013, 08:59:05 PM
by John Mc
