KNOW WHAT?
Between February 12, 2018 and June 18, 2018, this space displayed 13 Million, 871 Thousand and 87 times.
Author Topic: Bander... metal or plastic?  (Read 1220 times)
Offline nopoint
« on: July 15, 2017, 07:50:43 AM »
Would like to purchase a bander to make moving and loading lumber and slabs easier. What are your thoughts on metal vs plastic banding? The plastic seems like it would be nice for slabs that occasionally get burned or cut up with chain saw. Also less potential for staining lumber... thoughts?
Offline petefrom bearswamp
  • made 70-10 and still feelin pretty darned good!
Re: Bander... metal or plastic?
« Reply #1 on: July 15, 2017, 08:00:13 AM »
I use plastic but sometimes break the band when trying to get too tight.
But mine is a cheap HF set
LT40SHDD51
Kubota 900 RTV
Polaris 550 Sportsman ATV
1 Husky 1 gas Echo 1 cordless Echo
241 acres of woodland
Offline drobertson
« Reply #2 on: July 15, 2017, 08:12:32 AM »
I used metal, but they will stain the oak, but for slabs they are great, but they dont burn very good.   They say some of the non metallic banding is pretty good stuff,
Offline JB Griffin
« Reply #3 on: July 15, 2017, 08:35:37 AM »
We use both at work.  The plastic is cheaper so we use it on everything but slabs. The slabs are sold to the charcoal plant so they get metal.
2000 LT40hyd remote 33hp Kubota, 160 Prentice, Frick 2 saw gang edger, Wright W-37 ABG, Suffolk dual tooth setter, Cat claw single tooth setter,'96 F-250 7.3 PSD 4x4, CS-590 Echo, MF 20c, M681 Memo.
1.8 million bdft sawn with a Baker Dominator and counting.
Offline Kbeitz
  • Never enough time...
    • My Hobbies
« Reply #4 on: July 15, 2017, 08:42:07 AM »
There is a clear/yellow plastic for machines that I'm sure you wont brake.
stronger than steel.
Love machine shop work
and Wood work shop work
And now a saw mill work
Offline Ohio_Bill
  • Wood is Good
« Reply #5 on: July 15, 2017, 08:51:54 AM »
I use ¾ inch poly cord on slabs and 5/8 poly strapping on lumber. The only reason for the poly strapping is it’s cheaper. If you’re not doing a lot you could just use the Poly Cord. Got all of mine from Uline.
Bill
USAF Veteran  C141 Loadmaster
LT 40 HDD42-RA   , Allis Chalmers I 500 Forklift , Allis Chalmers 840 Loader , International 4300 , Zetor 6245 Tractor – Loader ,Bob Cat 763 , Riehl Steel Edger
Offline paul case
  • Original wearer of the PCM.
« Reply #6 on: July 15, 2017, 09:13:36 AM »
I use this product from uline.com.
https://www.uline.com/Product/Detail/S-3250/Polyester-Strapping/Uline-Polyester-Strapping-5-8-x-035-x-4200-Green
That roll of strapping is $101, the tensioner is $67, the seal crimper is $90, and the box of seals is $92. It is kind of expensive to get started but we use it for everything and only use 2 rolls a year. It stays tight and we do not break one very often. If we only made our bundles for a tractor loader or skid loader we probably wouldnt break any. If we do break one it will usually be on slabs that get one hooked on the door or something to break the band.
PC
pc
Offline Larry
« Reply #7 on: July 15, 2017, 10:14:10 AM »
My tools and crimps work equally well on either plastic or steel.  I use plastic 90% of the time.  Sometimes I will put three or even four bands on slabs just to make sure short pieces stay in the bundle.  Two bands on lumber.  I'm a small time hobby sawyer and I'm not slamming bundles around.
The charcoal plant only accepts slabs banded with steel.
Offline Bruno of NH
« Reply #8 on: July 15, 2017, 03:33:47 PM »
I use the plastic it works good for me and use the buckles .
I don't like metal seen it cut or break and know a guy who put his eye out when a metal band broke.
thomas 8013 mill ,Mahindra 3540 cab tractor loader  Dump trailer  and lot of contracting tools
Offline btulloh
« Reply #9 on: July 15, 2017, 03:44:01 PM »
You're using the buckles instead of the crimped style?  Do they hold up ok?  What size strapping?
HM126
Offline Ohio_Bill
  • Wood is Good
« Reply #10 on: July 15, 2017, 04:11:39 PM »
Here is a homemade holder for the Poly Cord .
Bill
Offline Bruno of NH
« Reply #11 on: July 15, 2017, 04:33:20 PM »
The buckles hold great and you can reuse them and pull them back tight if need be.
5/8" from uline
Offline btulloh
« Reply #12 on: July 15, 2017, 05:59:23 PM »
I thought I was the only one using buckles.  Looks like a lot of bucklers around.
HM126
Offline paul case
« Reply #13 on: July 15, 2017, 08:23:18 PM »
I started off using that poly cord strapping with the buckles. it works ok but I have had some heavy bundles loosen off while hauling them. The neat thing about them is that you dont have to have a special tool to tighten them up on bundles. A 4' 2x6 with 2 saw cuts into it half way across at 6'' and 9'' from one end and you got yourself a tightener.
I built a box that looked like a planter box just as wide as the poly cord spool and a little longer and cut a hole through it for the spool to turn on and throw the buckles in the bottom. a poly cord for a handle and it is portable. I have just such a deal and half a big box of buckles I would let someone have. I probably will never go back.
PC
pc
Offline YellowHammer
  • Always taking steps to save steps
    • Hobby Hardwood Alabama
« Reply #14 on: July 15, 2017, 09:35:49 PM »
I use the 1/2 inch orange Kubinec strapping and buckles for lighter loads, but I don't like its stretchiness.  I tried it for over the load, but it would let packs get loose.
I use the heavy duty 5/8" green embossed "lumberyard" banding anytime I'm carrying wood on the road.  The stuff is amazingly strong, and I've never had it break or pull apart, even under circumstances when I expected it to.  I figure its good enough for professional lumberyards, its good enough for me.
I used to use the 1/2 brown plastic crimp packing, and I've had it break before, and it will cut itself on sharp lumber edges, especially oak.
HobbyHardwoodAlabama.com
Culverts--metal or plastic?
Started by sprucebunny on General Board
Last post November 12, 2004, 05:15:19 PM
by SwampDonkey
metal ducting vs. plastic
Started by getoverit on Drying and Processing
Last post August 30, 2006, 11:53:06 PM
by jack
Bander
Started by ladylake on Sawmills and Milling
Last post May 18, 2004, 08:04:19 AM
by DansSawmill
steel bander and 3 roles of banding
Started by Norwiscutter on For Sale
Last post December 29, 2008, 08:20:08 PM
by Banjo picker
