Arborwear
Author Topic: Considering engine replacement  (Read 3473 times)
Offline Kbeitz
  • Never enough time...
    • My Hobbies
Re: Considering engine replacement
« Reply #20 on: July 20, 2017, 11:27:52 AM »
I don't keep ether at my shop. I seen way to many small engines damaged with it.
Instead I keep an old pump oil can filled with gas. Works great for me.
It also works good on wasp nest.
Love machine shop work
and Wood work shop work
And now a saw mill work
Offline iffy
« Reply #21 on: July 20, 2017, 12:43:49 PM »
Once I saw the pin height was a lot different I didn't proceed with weighing.
Offline kelLOGg
  • Still learning more than I'm teaching
« Reply #22 on: August 03, 2017, 05:29:14 AM »
I have a friend who is really into John Deere riding mowers and he says he has a Yanmar 3 cylinder water cooled 18 HP engine on one of his Deeres that he will give me. What do you guys think of Yanmars?
Bob
Cook's MP-32, 16HP, 20' (modified w/ power feed, up/down, loader/turner)
DH kiln, CatClaw, setter, tandem trailer, log arches, tractor, thumb tacks
Offline ladylake
« Reply #23 on: August 03, 2017, 06:05:30 AM »
   Great engines that sip fuel, keep in mind it will weigh around 200# more than your old Kohler.   Steve
Offline kelLOGg
« Reply #24 on: August 03, 2017, 06:44:18 AM »
 :o Really? My current Kohler is under 100 lbs. If it is almost 300 lbs, I'll pass.
Offline ladylake
« Reply #25 on: August 03, 2017, 07:17:35 AM »
  My 3 cylinder 29HP Isuzu is right at 300# with the radiator and all of the fluids, I'm thinking that 18HP Yanmar is quite a bit smaller so maybe just over 200#.  You can mount a windup garage door opener on your mill to help lift the extra weight.  Steve
Offline sawmilllawyer
  • Ride hard, die free.
« Reply #26 on: August 03, 2017, 11:38:06 PM »
Yanmar diesel motors are the standard in the nautical industry, very dependable, durable, long lasting engines. Like said above weight might be an issue. Just my two cents.
Stihl MS-361, MS-460 mag, Poulan 2150, 2375 Wildthing.
Offline kelLOGg
« Reply #27 on: August 04, 2017, 06:52:37 AM »
Maybe I misunderstood my friend but I think he said it was a "gas" engine. Looking on Yanmar's site I see they make only diesel.  >:( I'm really not up to more sawmill mods to make a heavy diesel work. I'll stick to gas.
Offline Banjo picker
  • A goal without a plan is just a dream. Elbert H.
« Reply #28 on: August 04, 2017, 08:19:27 AM »
We run yanmars on spray trucks.  You really got to watch them...they burn so little fuel you will forget to check the tank.. That would be a nice engine to have there Bob.  But i am only a tiny bit from being a hoarder.   Banjo
Cooks AC 36--Prentice 210C--Morgan edger--Kubota M7040 with loader--Case 580 K with extendahoe--Case 850C dozer--Int 1700 series twin cylinder dump/log/flatbed truck--logging arch--2 Logrite mill sp.--Cat claw sharpening system--And a bulldog to make sure it all stays here.
Offline BigZ La
« Reply #29 on: August 04, 2017, 09:49:22 AM »
Yanmar does make some diesel engines that are aluminum. They are in the smaller hp and used on generators water pumps and such. I would check out what he has and it's weight. They are very fuel efficient.
Offline pineywoods
« Reply #30 on: August 04, 2017, 10:39:02 AM »
Going from gas to diesel, the real bear is weight, especially with manual mills. I looked at the options, and elected to stay with gas, BUT, there is another option. Gas engines are set up to run way rich for the extra cooling. Kawasaki makes some liquid cooled V twins that almost as frugal on fuel as a diesel and they weigh about the same as a comparable air cooled engine. To go diesel, you will need to address the weight problem. Do a search on "faster up for older woodmizers" Shows how to add some garage door springs to help the up-down mechanics.
Offline MbfVA
    • Tanglewood Ordinary Country Restaurant
« Reply #31 on: August 04, 2017, 11:30:10 AM »
 I didn't go back through the thread to see what the original poster's needs were, but given the cost and the weight of a diesel, that's a lot of upfront cost & bother unless the usage is going to be heavy enough, no pun intended, to justify the disadvantages.
 One additional feature of any liquid cooled engine, is less noise. The disadvantage is the user has to keep up with antifreeze and associated problems.  If it's  going to be your only diesel engine, there's a new fuel supply to keep up with as well.  Wish we could make this simple for you.
I have no knowledge of modern aluminum diesel engines, certainly there have been improvements, new alloys, etc.,  but I can tell you this: heat and aluminum historically do not play well together in the world of internal combustion . I hope they solved that problem  well enough to stand the rigors of diesel.  My mother had a 1962 Oldsmobile F 85 with an aluminum engine which was a hunk of junk. Left us on the side of the road waiting for emergency service several times before we finally ditched it.  The service manager at the dealership admitted that they had replaced more than one warped block and/or head.
Someone with more knowledge of the mechanical world please correct me if I'm wrong, but weren't there some problems with the GM diesels of the 1980s related to the materials they were made up?
What happened with the harbor freight option, or am I mixing up my threads?
Offline ladylake
« Reply #32 on: August 04, 2017, 02:26:42 PM »
Bob
 If I could get that engine free it would be going on my mill, putting a torsion type garage door spring on a mill is no big deal and should lift 150# or so.  I put one  my mill, nice and neat.  Diesels sip fuel with very little problems and have way more torque.  I went from a 27HP Kohler to a 29hp Isuzu, the Isuzu uses 1/2 as much fuel and cuts way faster, plus oil changes are 200 hours vs 50 or 100 for a gas motor.  Steve
Offline Kbeitz
    • My Hobbies
« Reply #33 on: August 04, 2017, 02:57:19 PM »
There is only one horsepower rating formula for any internal combustion engine, regardless of the fuel type used.
The only real difference is torque of a diesel engine happens at lower rpms .  Horsepower and torque are directly related.
Diesel engines don't rev up very high, so they make less horsepower on average than gas engines.
Gasoline powered engines in garden tractors typically have peak horsepower at about 3000 rpm and horsepower falls off quickly below that . Diesel engines in our compact tractors typically have their peak horsepower at about 1000-1500 rpm and horsepower stays up throughout most of the rpm range. A diesel engine, however, has a much broader power band.
Offline BigZ La
« Reply #34 on: August 04, 2017, 03:20:47 PM »
I checked the dry weight on my Kubota engine in my lawn mower and I was surprised to find out it only weighs 169 lbs. That yanmar may not weigh enough to worry about. Find out the model number and get a dry weight on it. Mine is a 3 cylinder 21 hp.
Offline BigZ La
« Reply #35 on: August 04, 2017, 09:28:57 PM »
With a little more time on my hands I checked how much the 3 cylinder engines weigh in the John Deere mowers and to my surprise the heaviest one, the 3TN75 weighs 160 lbs. All the rest were lower weights with many weighing less that  125 LBS. With those weights I definitely would go with a diesel especially if it's free. You could even get the electric clutch to run on them.
Offline SineWave
« Reply #36 on: August 05, 2017, 07:12:57 AM »
Well, lots of Hayabusa riders and F1 drivers would disagree. I think a lot of the kinks have been worked out with aluminum, what with the Nikasil cylinder coatings and whatnot.
One huge advantage of aluminum is that it is waaaaaaaaaaay ahead of cast iron or almost any other material in its thermal conductivity. This is part of what makes it so difficult to weld (you need a large welding power source), but also what makes it good for radiators and for light, high-output engines. It can dump a lot of heat FAST. (You'll realize this if you ever pick up a piece of hot aluminum after welding it.)
You don't want to mis-treat it, though ... it'll still warp like a pretzel and it still gets galvanic corrosion to beat the band, and it's famous for leaving its threads on steel fasteners...but it's not as bad as it used to be in the Corvair days...
Have you boys seen the "race" chainsaws they make out of old aluminum Oldsmobile V-8 engines?
Now THAT'S a "PREDATOR"!!! smiley_thumbsup_grin
Offline Darrel
  • Never throw an unopened log on the burn pile.
« Reply #37 on: August 05, 2017, 03:44:29 PM »
Put a ripping chain on that thing and mount it on an Alaskan chain saw mill and then go to the sawmill shootout!
1992 LT40HD
Offline kelLOGg
« Reply #38 on: August 06, 2017, 07:31:41 AM »
My friend brought his John Deere mower to me to see if the engine would be suitable for my mill. It is long and narrow so it will fit under the hood of a riding lawn mower and it is 9 inches to long to fit on the mill. It is a gasoline Yanmar. Oh well, nice try.
Offline JB Griffin
« Reply #39 on: August 07, 2017, 06:22:15 PM »
That may not be a bad option yet, Bob. It very well could be a mich better engine than a kohler ( imo, it wouldn't take much)
2000 LT40hyd remote 33hp Kubota, 160 Prentice, Frick 2 saw gang edger, Wright W-37 ABG, Suffolk dual tooth setter, Cat claw single tooth setter,'96 F-250 7.3 PSD 4x4, CS-590 Echo, MF 20c, M681 Memo.
1.8 million bdft sawn with a Baker Dominator and counting.
gas engine replacement for Detroit 353
Started by mjeselskis on Forestry and Logging
Last post March 06, 2015, 11:35:39 PM
by treeslayer2003
smiley
engine replacement time?
Started by woodbeard on Sawmills and Milling
Last post June 30, 2007, 02:28:05 PM
by woodbeard
Replacement Engine Cover
Started by Magicman on Sawmills and Milling
Last post December 14, 2012, 11:05:34 AM
by PC-Urban-Sawyer
Splitter Engine Replacement thoughts
Started by stumper on Firewood and Wood Heating
Last post April 05, 2016, 05:13:20 AM
by Al_Smith
