Arborwear
Author Topic: Sawmill build question  (Read 289 times)
Offline BigZ La
« on: July 16, 2017, 09:40:20 PM »
Sorry to keep bothering everyone with questions but I have another opportunity to get closer to a sawmill build. A friend has a Kubota motor with a pto clutch attached. Twin disc pto. Motor does not run but pto clutch will fit one of my running motors. Would it be a good idea to pick this up for my drive motor to run the blade?  Thanks for any help.
Offline ljohnsaw
Re: Sawmill build question
« Reply #1 on: July 16, 2017, 11:37:23 PM »
Is it a clutch or just an engage type lever?  That is, can you engage it while the drive shaft is spinning or does it grind?  If it is a true clutch then I'd say grab it!
There have been a sudden rash of sawmill build threads.  If you have already started one, you should keep all the questions in one place.  Makes it easier for others to follow and, in the future, other new guys to see the whole story.  Don't mean to sound snarky, JMHO
John Sawicky
SkyTrak 9038, Davis Little Monster backhoe, Case 16+4 Trencher, Home Built 38" cut Bandmill up to 64' - using it all to build a timber frame cabin.
Offline BigZ La
« Reply #2 on: July 17, 2017, 10:32:30 AM »
It is a clutch. I haven't started a sawmill build yet, I'm just trying to decide just what I want to build and when opportunity presents itself acquire the parts that's best used. I was wondering if this would be good to use or maybe just overkill or I would have problems using.
Sawmill build
Started by joegeds on Sawmills and Milling
Last post February 18, 2016, 10:34:33 AM
by york
My new sawmill build
Started by Piddler on Sawmills and Milling
Last post February 08, 2018, 07:17:59 PM
by Kbeitz
First sawmill build
Started by BraschBrothers on Sawmills and Milling
Last post January 29, 2017, 01:14:15 PM
by Joe Hillmann
New Guy with my Sawmill Build
Started by Jimmysmill13 on Sawmills and Milling
Last post April 12, 2016, 09:27:48 PM
by Ox
