Arborwear
Author Topic: Finish for wood drink coasters  (Read 864 times)
Offline Downstream
« on: July 17, 2017, 10:55:45 AM »
I have made a jig to slice limb cookies to make wood drink coasters on my band saw so now I have to decide what type of finish to apply, if any.  Seems to be a number of things people have tried but curious to what anyone on this board as had good or bad luck with.  Looking for simple if possible in case I need to do many at a time.
EZ Boardwalk Jr,  Granberg Alaskan Chainsaw Mill, Stihl 660 and 211, Logrite 60" cant hook
Offline tule peak timber
  • roborob
    • tule peak timber
Re: Finish for wood drink coasters
« Reply #1 on: July 17, 2017, 12:28:59 PM »
We use epoxy on similar projects with great success. It is  more of an "in " the wood finish than an "on " the wood finish.2-K poly may be added on top of the epoxy , but probably is not needed. Attached is a pic of some cookies in the shop right now using this "in" the wood method. End grain doesn't like water and this is where the epoxy soaking really shines. A simpler option is to heat beeswax and mineral oil and apply to a warmed cookie so it soaks in.  Cheers  Rob
Offline Crusarius
  • Lost in....
    • RockModified.com
« Reply #2 on: July 17, 2017, 12:32:45 PM »
I always love your work. that is beautiful.
I knew what I thought I meant.
Offline bucknwfl
« Reply #3 on: July 17, 2017, 01:57:12 PM »
I made some coasters to go with the cypress table. Cut them out of a 4x4 sanded burned an L in them (Angie has to have initials on everything) then just coated with helmsman spar urethane
Buck
If it was easy everybody would be doing it
Offline Kbeitz
  • Never enough time...
    • My Hobbies
« Reply #4 on: July 19, 2017, 03:36:06 AM »
Rubber tool handle coating for the bottom keep them form sliding around.
Love machine shop work
and Wood work shop work
And now a saw mill work
Finish on Barn wood
Started by Brad_bb on General Woodworking
Last post January 10, 2016, 12:07:57 AM
by Kbeitz
Economical wood finish?
Started by medic1289 on General Board
Last post April 17, 2017, 03:01:06 PM
by Kbeitz
finish on wood drawer slides
Started by jueston on General Woodworking
Last post October 29, 2014, 04:43:39 PM
by jueston
Butcher block wood finish. Need Advise
Started by LAZERDAN on General Woodworking
Last post April 18, 2009, 11:37:45 PM
by Handy Andy
