Arborwear
GALLERY LINK
The Forestry Forum Galleries.
Over 250,000 images!
Author Topic: g matic  (Read 344 times)
Offline coxy
g matic
« on: July 17, 2017, 12:38:32 PM »
what do you guys use to put under the puller point to take the out side bearing off so you don't mess the inside of the hole up where the little u cup goes
Offline North River Energy
Re: g matic
« Reply #1 on: July 17, 2017, 12:45:33 PM »
Have not had to do that particular repair yet, but would probably turn up some sort of 'push pad' on the lathe.
With a 'stud' to keep it centered in the critical hole, and a small pocket on the opposite side to center the puller screw.
Offline Ed_K
Re: g matic
« Reply #2 on: July 17, 2017, 02:40:30 PM »
 I used a chisel behind it and just tapped on it till it came loose.
Ed K
Offline coxy
Re: g matic
« Reply #3 on: July 17, 2017, 02:55:46 PM »
I use a flat plate mostly but didn't know if any one had a better rig
gear matic 19/119
Started by coxy on Forestry and Logging
Last post May 12, 2016, 12:15:00 AM
by John Woodworth
gear-o-matic 8A need to be rebuilt
Started by Ken@MN on Forestry and Logging
Last post October 14, 2013, 09:07:17 PM
by rfm7fxfox
