Arborwear
Author Topic: Stihl 041 problem  (Read 556 times)
Offline jayhdjr
Stihl 041 problem
« on: July 23, 2017, 11:13:08 AM »
Howdy,
I've picked up a couple 041's in the last couple years, at the time for parts when needed. But neither is that far form being complete and usable. Main problem with both of them is they rev really high from the get go. Start saw up and it's at full throttle with out any pull on the throttle at all. Rebuild the carb on one and still acts the same. Adjusting the carb seems to do nothing till the point it just dies. Ethanol is not the problem either.
Any idea's or suggestions welcome.
Thanks in advance, Jay
Logosol M7, Stihl 041, Stihl MS 310, Kubota B26
Offline sawguy21
Re: Stihl 041 problem
« Reply #1 on: July 23, 2017, 02:03:35 PM »
Check the gaskets under the carburetor, they may be torn and allowing air to enter. Also check the insulator block for cracks.
Offline jayhdjr
« Reply #2 on: July 23, 2017, 02:40:12 PM »
Insulator block? Under the carb. ? I don't believe these have one.
Thanks, Jay
Offline blueberrymuzik
  • Actively Retired
« Reply #3 on: July 23, 2017, 03:13:30 PM »
Do you have access to the Illustrated Parts List for the 041? If so, it will make locating these parts much easier. If not, let me know and I will forward a copy to you.
Offline jayhdjr
« Reply #4 on: July 23, 2017, 04:49:42 PM »
I don't have the parts list. It would be great if you could forward it. Thanks, Jay
  • Actively Retired
« Reply #5 on: July 23, 2017, 06:29:57 PM »
Please send me your email address, and I will send you the IPL.
  • Actively Retired
« Reply #6 on: July 23, 2017, 07:52:58 PM »
Did you receive the IPL? This should make it easy to see how the carburetion system is assembled.
Offline jayhdjr
« Reply #7 on: July 23, 2017, 08:31:53 PM »
Yep, I got it. Thanks again, Jay
Offline jayhdjr
« Reply #8 on: July 25, 2017, 02:41:05 PM »
Got around to looking in to this again today. Insulator block is fine, but that gasket under it isn't. So I'll have to get a few of them. Looks like the same gasket in 2 spots for 2 saws. I should have looked while I had it apart, but what is the second hose for? Just a return line or ? How do you guys seal your gaskets ? I usually use a little oil.
Thanks, Jay
I have a problem problem starting Stihl ms290 chainsaw
Started by bardos on Chainsaws
Last post May 07, 2015, 08:42:26 AM
by GAB
question
Stihl 038 mag problem
Started by Alta1274 on Chainsaws
Last post November 13, 2013, 04:54:43 PM
by Al_Smith
Stihl 029 problem
Started by jmaine on Chainsaws
Last post April 13, 2009, 11:06:48 PM
by Hilltop366
Oil problem on 660 Stihl
Started by DaveP on Chainsaws
Last post May 13, 2017, 07:56:20 AM
by DaveP
