KNOW WHAT?
Between February 12, 2018 and June 18, 2018, this space displayed 13 Million, 871 Thousand and 87 times.
Author Topic: LT40HD SS side support covers. Why not loader arm tubing ?  (Read 1643 times)
Offline antioch01
  • I'm new to sawing and need lots of help
Re: LT40HD SS side support covers. Why not loader arm tubing ?
« Reply #20 on: August 07, 2017, 07:24:55 AM »
When I select the "click here to add photos to post",,, it opens my picture file on computer,, when I select the picture it just keeps uploading it to my album,,, not the post,, when I copy the file description from the album and paste in the post all I get is the description,,, no pic.
I do not see the page you reference,,,, somehow I did get that page when I did the post that has the pic,, but have not been able to find that page again.
2006 Woodmizer LT40HD,
1975 Mack RD686 Log Truck with 110 Prentice Loader,
Morooka MST600 Tracked dump truck used as skidder.
Cat D3C LGP
Bobcat T200
Ford 675D Backhoe
Case 1080 Excavator
Snorkel 42A Manlift
Offline antioch01
« Reply #21 on: August 07, 2017, 07:31:29 AM »
Caveman,,, I see you are in Lakeland,,, did not think there were any sawmills in Florida,, had a hell of a time trying to find one down here. They all seem to be from Alabama, Georgia and North from there.
Glad to see you are in the area,, looks like you have done a lot of pine,,, I have questions on trying to keep the pitch build-up to a minimum.
Cat D3C LGP
Bobcat T200
Ford 675D Backhoe
Case 1080 Excavator
Snorkel 42A Manlift
Offline antioch01
« Reply #22 on: August 07, 2017, 07:40:18 AM »
LT40HD Finished,,, think I got this pic posting figured out now.
LT40HD  Before, took exactly one month, mill only has 635 hrs, but stayed out in the sun.
Cat D3C LGP
Bobcat T200
Ford 675D Backhoe
Case 1080 Excavator
Snorkel 42A Manlift
Offline antioch01
« Reply #23 on: August 07, 2017, 07:42:04 AM »
I got it now,,, when you select the pic from the album,, you get that page for inserting in post,, Thanks for the help.
Cat D3C LGP
Bobcat T200
Ford 675D Backhoe
Case 1080 Excavator
Snorkel 42A Manlift
Offline Ga Mtn Man
  • Y'all can call me GMM
« Reply #24 on: August 07, 2017, 08:47:59 AM »
That is a first-class restoration job!  Can you tell us about what paint you used and what prep work you did?
2012 LT40HDG29 with "Superized" hydraulics,  2 Logrite cant hooks, home-built log arch.
Offline antioch01
« Reply #25 on: August 07, 2017, 09:04:47 AM »
Thanks, had to sand blast to get all the rough areas clean and the old decals off,,, Rustoleum brown primer,,,, Rustoleum Orange,,,, I read a lot of different variations of mixing safety orange and yellow etc. The Rustoleum Orange matched the color under the decals that pealed off and were virgin original color, very well. And availability of the paint for touch up made it a no-brainer for me. All black is Rustoleum semi-gloss.
Bought both the tail light housings, 4ea. stainless back support covers from Woodmizer as well as all the new style decals.
I already had the stainless 5" tubing here for the loader cross tube, just had to cut it in half with 4 1/2" cut-off grinder with .045 wheel. Mounted with 1/4" stainless bolts, also used all stainless bolts, nuts and washers every where else except jacks, used the steel bolts for strength and stainless nuts and washers.
Cat D3C LGP
Bobcat T200
Ford 675D Backhoe
Case 1080 Excavator
Snorkel 42A Manlift
Offline thecfarm
« Reply #26 on: August 07, 2017, 07:58:59 PM »
And you even put some "white space" between the pictures.  8)
Just so others will know,hit the enter key a couple times. Preview is your friend too.
Offline Ga Mtn Man
« Reply #27 on: August 08, 2017, 08:01:14 AM »
It seems that Rustoleum has several lines of paints with more than one orange in each.  Which one did you use?  Thanks.
Offline antioch01
« Reply #28 on: August 08, 2017, 08:51:23 AM »
Rustoleum 7769830 Rusty metal primer and Gloss Orange 214084, it is available in spray cans for touch-ups. That was the main reason for using it,,, Lowes stocks it here.
Cat D3C LGP
Bobcat T200
Ford 675D Backhoe
Case 1080 Excavator
Snorkel 42A Manlift
Offline Kbeitz
  • Never enough time...
    • My Hobbies
« Reply #29 on: August 08, 2017, 10:13:06 AM »
I always thought Rustoleum was a pretty good paint.
Love machine shop work
and Wood work shop work
And now a saw mill work
Offline antioch01
« Reply #30 on: August 08, 2017, 11:31:50 AM »
So far I am happy with the coverage etc,,,,, but the paint is also new, we will see how it holds up. At least the mill is not going to sit out in the weather any more,, it will be under cover for the most part. Other wise I would not have taken the time to restore it.
Cat D3C LGP
Bobcat T200
Ford 675D Backhoe
Case 1080 Excavator
Snorkel 42A Manlift
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #31 on: August 08, 2017, 03:32:47 PM »
Rustoleum paint is good but the nozzles stink.  I always invert and blow the paint out.   Maybe that is the plan because you can't clean them.  I use Krylon instead.  The nozzles are self cleaning and never clog.
Offline Kbeitz
    • My Hobbies
« Reply #32 on: August 08, 2017, 04:50:27 PM »
I was talking about the brush on stuff.
The nozzles can be cleaned with music wire. I do it all the time.
Also sometimes if you just tale it off the can and smack it on something hard
with the inlet hole down is all that's needed. I also keep a small can of used nozzles
on my shelf to use when I can't get one to unplug.
Offline antioch01
« Reply #33 on: August 08, 2017, 04:53:46 PM »
These new cans are all angle spray,, so you can't invert them to clear the nozzle any more,, I use to do the same thing. The great thing is you don't have to hold the can vertical.
Cat D3C LGP
Bobcat T200
Ford 675D Backhoe
Case 1080 Excavator
Snorkel 42A Manlift
LT40HD Back Support Kit
Started by John_Haylow on Sawmills and Milling
Last post December 05, 2007, 02:10:46 AM
by Brucer
1987 woodmizer lt40hd drive side bushing question and more.
Started by jclvsall on Sawmills and Milling
Last post January 18, 2014, 03:24:20 PM
by jclvsall
side support rollers
Started by timberjackrob on Sawmills and Milling
Last post November 09, 2010, 06:17:38 PM
by Burlkraft
Help! LT40HD log loader not going down
Started by DGK on Sawmills and Milling
Last post December 16, 2015, 08:39:47 AM
by isawlogs
