Arborwear
Author Topic: Parbuckling question  (Read 3563 times)
Offline Chop Shop
Re: Parbuckling question
« Reply #20 on: August 10, 2017, 02:17:10 PM »
Rope is for fishing boats and tree guys.
Its been marketed to offroad people because its lightweight and very profitable when cut into 100' sections and the ends braided around a thimble.   BIG money to be made by telling 4x4ers how safe fishing rope is for their winch.
You wont see rope used for skidding logs on logging sites, on tow trucks, cranes, or any commercial rig other than tree service (cuz its light) and fishing boats (cuz it wont rust).
Offline fishfighter
« Reply #21 on: August 10, 2017, 03:15:09 PM »
Why is cable preferred over winch rope for parbuckling? I have used rope for years doing extreme offloading and recovery. To me rope seems safer.
Look at it this way, trucks, jeeps have wheels, logs don't. If your trailer that you have is just for logs, look into a arch and load from the back. So much easy and you are out the way if a cable pops.
This is mine that I built. I can remove the arch by unbolting two bolts. ;D
Offline WranglerSS
« Reply #22 on: August 10, 2017, 03:52:48 PM »
Tow trucks do use MasterPull 3/4" winch rope on rollbacks in my neck of the woods.
Kubota L3240
Kubota RTV 900
Woodmizer LT28
Woodmaxx 8h Chipper/Shredder
Offline Ben Cut-wright
  • I'm new here! I'm old everywhere else
« Reply #23 on: August 10, 2017, 08:07:29 PM »
[/quote]
Their website lists 262 foot of 3/4" synthetic tow truck and wrecker rope at $5,334.  And...they are out of it!
Offline Ditchdoc
« Reply #24 on: August 10, 2017, 09:52:33 PM »
[/quote]
Not going to be exclusively for logs.
Offline fishfighter
« Reply #25 on: August 11, 2017, 06:22:55 AM »
Nice equipment trailer. You still could add a arch and build it to were you can unbolt it. The way your trailer it built, that would be easy and 10x more easy to load logs from the back. ;D
Offline Kbeitz
  • Never enough time...
    • My Hobbies
« Reply #26 on: August 11, 2017, 08:29:46 AM »
I made my arch unboltable. Two large bolts and it's off.
Love machine shop work
and Wood work shop work
And now a saw mill work
Offline Crusarius
  • Lost in....
    • RockModified.com
« Reply #27 on: August 11, 2017, 12:19:25 PM »
Winch rope frays very easily when rubbing on rocks or sharp objects. The best reason to have it is no kinetic energy. So when it snaps is usually just drops to the ground.
It is required for many competitions because of the improved safety factor over steel cable.
I knew what I thought I meant.
Offline Ditchdoc
« Reply #28 on: August 12, 2017, 10:41:46 PM »
Anyone here using a Warn 8274 on a trailer? If so how did you mount it? Hope to look at if Tue. Think it was manufactured in 1976.
Offline Kbeitz
    • My Hobbies
« Reply #29 on: August 13, 2017, 07:21:32 AM »
I have a Warn . I put class 3 hitches on everything and the winch is in a carrier. I use fork lift plugins .
Offline WranglerSS
« Reply #30 on: August 13, 2017, 08:32:41 AM »
I made a receiver mount for my Warn M8000 winch. My gooseneck trailer has a 2" receiver welded on the front of the bed so for parbuckling I use a snachblock on the opposite side to redirect the line.
Kubota L3240
Kubota RTV 900
Woodmizer LT28
Offline Ditchdoc
« Reply #31 on: August 15, 2017, 11:45:32 AM »
The 8274 mounts vertically. Pic of one:
has to mount on something like this:
Could weld a 2" tube to the bottom of the mount or see if it would bolt to a Curt or DrawTite receiver mount.
Another consideration is weight, thing weighs ~130#.
Offline WranglerSS
« Reply #32 on: August 15, 2017, 02:13:00 PM »
The 8274 Warns are heavy but by far the fastest winch made.
Kubota L3240
Kubota RTV 900
Woodmizer LT28
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #33 on: August 15, 2017, 04:44:12 PM »
I had one on the front of a '68 Bronco, and it was bullet proof.  I do not recall that it was that heavy because I could pick it up.
Offline Kbeitz
    • My Hobbies
« Reply #34 on: August 15, 2017, 11:01:31 PM »
I have no idea how much my 16,500 with the carrier weights.
I can pick it up but I would not want to have to carry it to far.
Offline mart
« Reply #35 on: September 27, 2017, 05:40:41 PM »
Here's a few pictures from back before I had a sawmill. I'm loading up some birch logs for a trip to a sawyer.  And parbuckling is the correct term. I have since fabricated better ramps for the purpose and still use the four wheeler for a power source.
I was young and dumb once. I got over being young a long time ago.
Offline Quebecnewf
« Reply #36 on: September 28, 2017, 06:20:16 AM »
You can par buckle just about anything . Like a solar kiln that blew over in a storm
Quebecnewf
Offline Kbeitz
    • My Hobbies
« Reply #37 on: September 28, 2017, 09:40:33 AM »
Or a building...
Offline cwimer973
  • I'm new! Wood-Mizer LT10 - Please Help Me Learn
    • Wimer Hardwoods
« Reply #38 on: September 28, 2017, 01:01:50 PM »
Sounds like a new competition brewing, prizes given out at the next pig roast.
Most Elaborate Par Buckling - 2017
Your Fellow Woodworker,
- Chris
Offline Darrel
  • Never throw an unopened log on the burn pile.
« Reply #39 on: September 28, 2017, 08:18:07 PM »
I parbuckled logs onto the back of my '49 GMC truck before I knew it was called parbuckling.  If asked I would have told you a parbuckle was a belt buckle worn by a golfer. Shirley that must be worth something elaborate or not.
1992 LT40HD
newbie parbuckling question
Started by skinnyest on Forestry and Logging
Last post June 14, 2013, 02:36:39 AM
by skinnyest
question
snatch block question for parbuckling
Started by tomb on Forestry and Logging
Last post October 24, 2010, 09:44:14 PM
by Stan snider
Did a bit of parbuckling...
Started by DanG on Forestry and Logging
Last post April 03, 2006, 10:51:27 AM
by Kirk_Allen
parbuckling
Started by board on Sawmills and Milling
Last post March 14, 2014, 11:27:27 PM
by justallan1
