Arborwear
Author Topic: Pulling a marine steering wheel  (Read 552 times)
Offline Qweaver
  • The cabin is done and we love it
« on: July 28, 2017, 09:54:37 AM »
I'm putting a new engine on my Carolina Skiff and I am unable to pull the old steering wheel.  The wheel is not made to be able to use a puller well.  Soaked with Blue Creeper for three days, drove wedges, drilled and tried puller..no joy with any of these.  I want to let the steering system stay with the old engine but it looks like I am just going to have to destroy the wheel to get it off.  I'm surprised that the Blue Creeper has not worked because I have had very good results with it on rusted bolts.  I have a few more days until I get  the new engine so I'll keep soaking and then I'll grind it off.  No way to get heat on the wheel until I cut away all of the plastic.  Any suggestions?
Quinton
Offline sprucebunny
  • Gender: Female
Re: Pulling a marine steering wheel
« Reply #1 on: July 28, 2017, 06:25:46 PM »
Have you looked at the back of it ???
Maybe it bolts on to the dashboard inside the base.
Or maybe the steering cables or whatever have a place to detach them.
Picture would help.
Offline Kbeitz
  • Never enough time...
    • My Hobbies
« Reply #2 on: July 29, 2017, 05:14:54 AM »
If you have room to put a bearing separator behind it then that makes a spot to hook a puller to.
Love machine shop work
and Wood work shop work
And now a saw mill work
Offline 69bronco
  • Location: Upstate New York when it's warm, southwest Fl when it's cold!
« Reply #3 on: July 29, 2017, 07:58:45 AM »
Usually a tapered shaft, try driving some wedges behind it. Loosen the nut to the end of shaft, using a hardwood scrap on the shaft/nut give it a Crack with a hammer.
Lt 25, New Holland 555e backhoe, Ford 2120 and a sore back
Offline drobertson
« Reply #4 on: July 29, 2017, 08:09:10 AM »
I was thinking kinda like SB, thinking it may be set screwed on or something like it,  if not, it sounds like years of corrosion has bonded the shaft and hub together,  heat may be the only resort,,  or just some good ole pounding to crack it loose.  Sounds like a real pain either way,,
Offline Qweaver
« Reply #5 on: July 29, 2017, 09:16:22 PM »
Thanks for the suggestions.  Tried them all---still no joy.  I would just keep the existing steering if it worked better.  I can't even get to the steering box until I can remove the wheel.  I'm just going to keep the wedges in place and keep adding blue creeper for a few days.  When all else fails...demolition derby I guess.
Offline Kbeitz
    • My Hobbies
« Reply #6 on: July 30, 2017, 07:56:31 AM »
This is a bearing separator. Most of the time it will fit behind the wheel.
Then you can bold a large puller to it.
Offline snowstorm
« Reply #7 on: July 30, 2017, 08:19:51 AM »
this must be a push pull cable set up. are you going to hydraulic steering? if so it will be well worth it in the end
Steering wheel shake
Started by ElectricAl on General Board
Last post December 05, 2005, 08:51:11 PM
by ElectricAl
clark steering wheel
Started by donny hochstetler on For Sale
Last post August 24, 2015, 10:08:09 PM
Steering wheel for 1966 Chevy C60
Started by LeeB on Wanted
Last post March 24, 2012, 12:49:38 AM
by LeeB
Steering radius of a 5 ton long wheel base army surplus truck
Started by Woodchuck53 on The Outdoor Board
Last post January 31, 2009, 04:03:57 PM
by Ironwood
