KNOW WHAT?
Between February 12, 2018 and June 18, 2018, this space displayed 13 Million, 871 Thousand and 87 times.
Author Topic: Cooks AC36 production numbers?  (Read 2360 times)
Offline Kbeitz
  • Never enough time...
    • My Hobbies
Re: Cooks AC36 production numbers?
« Reply #20 on: August 03, 2017, 01:39:54 PM »
Problem with set works is that it blinks and it loses its settings.  It started doing that right after i got it.  Cooks had a man working for them at the time that tried to help me figure out what the problem was but he retired or quit before we got it worked out.  I have just used the scale since then.  It would be nice to have the set works actually work ..especially when some body asks for some off the wall dimensions.   It would be helpful if Cooks had a service route like Woodmizer has.  My problem may be a ground somewhere,  but i have checked everything i know to check.  I am retiring from the state job i am presently working in 8 months and i hope to fig a little deeper into the problem then.  The maintaince guy where my # 2 son works is pretty sharp on electrial issues and has shown interest in helping me with it.  I bought this mill new, and for the money spent i sm very disappointed with the set works.  I would not have said anything about it if I had not given Cooks a chance to fix it.  Thats my take on it.  Banjo
What I would try is to run a new ground and hot wire. Bypass everything. Just try running it on your
new wires and see what happens.
Love machine shop work
and Wood work shop work
And now a saw mill work
Offline ladylake
« Reply #21 on: August 03, 2017, 02:45:18 PM »
   That's what I would try.  Bango  how does the wiring get from the controls to the head on your mill.  Steve
Offline Banjo picker
  • A goal without a plan is just a dream. Elbert H.
« Reply #22 on: August 03, 2017, 04:26:11 PM »
The computer controls are in two different places.   The control box is located on an arm that swings out, that arm has the hydraulic levers that turn, clamp, and dog the log as well as the levers and loading arms.  That is all on the right side of the mill.  The box that controls the computer is behind the mill on a cable that you can walk around with.  There are a couple junction boxrs that the wires are connected to.  All those wires run to the power supply through the flexable gooseneck.  Thats a fair distance.   Bsnjo
Cooks AC 36--Prentice 210C--Morgan edger--Kubota M7040 with loader--Case 580 K with extendahoe--Case 850C dozer--Int 1700 series twin cylinder dump/log/flatbed truck--logging arch--2 Logrite mill sp.--Cat claw sharpening system--And a bulldog to make sure it all stays here.
« Reply #23 on: August 03, 2017, 05:23:22 PM »
I just got home and went to the mill and took a couple of shots of what I was talking about in the previous post.
That is the set works on the swing arm.  This swing arm is quite nice, as when you are edging on the mill you can move it into position where you can reach your boards and controls at the same time.
Here is the pict of the remote control on the cable...it can be put in the vacant box on the right of the screen, but I usually leave it at the location behind the mill.
This shows the gooseneck that the hydraulic lines and electrical contorl cable run through. I appreciate the feed back on trying to come up with a fix. Banjo
Offline Bruno of NH
« Reply #24 on: August 03, 2017, 06:35:34 PM »
Do any folks that work at Cooks read the forum ?
I like the looks of a Cooks mill
It would be nice to have set works
thomas 8013 mill ,Mahindra 3540 cab tractor loader  Dump trailer  and lot of contracting tools
Offline ladylake
« Reply #25 on: August 04, 2017, 04:40:31 AM »
  Banjo
 If you leave the head in one place and run the setworks through a few cycles does it still blink off or only when the head is traveling.  Steve
Online kelLOGg
  • Still learning more than I'm teaching
« Reply #26 on: August 04, 2017, 06:47:56 AM »
They are in the "Sponsor News" but there are very few posts from FF members or Cooks. I emailed them about not seeing enough responses from Cooks but ... no change. They make nice rugged products but apparently don't see the need to promote them to the forum members.
Cook's MP-32, 16HP, 20' (modified w/ power feed, up/down, loader/turner)
DH kiln, CatClaw, setter, tandem trailer, log arches, tractor, thumb tacks
« Reply #27 on: August 04, 2017, 08:13:02 AM »
Steve i will check that.  I want to say it blinks off when the mill is traveling forward, but i will look at it to be sure.
I think i was probably instrumental in getting Cooks to sign up here as a sponsor.   Tim Cook personally delivered my mill and i told him what a great site this was, and that most people who were going to buy a mill are going to find this site and ask about the different mills.  Where that had an effect or not...i cant say, but they became sponsors shortly thereafter.   I agree with Bob about them making a super tough mill. Banjo
Offline Bruno of NH
« Reply #28 on: August 04, 2017, 02:04:08 PM »
I think its great when a sponsor interacts with the FF .
I like to hear what they have to say  :)
I'm thinking about one of the Cooks extra wide cut mills
Offline ladylake
« Reply #29 on: August 04, 2017, 02:16:07 PM »
 Banjo   If it works good sitting still I'd try running a extra ground wire grounded to the head, the post, the engine, the mill frame and the swing out controls.  It might be trying to ground through the roller wheels and losing contact. Anything is worth trying.  Steve
« Reply #30 on: August 04, 2017, 08:03:41 PM »
I gave the mill a quick check this afternoon.  It will blink off when its setting still and not using any hydraulic feature.  It comes right back on, but thats no good as it would have to be reset.  When I first started it up, it stayed on for a couple of minutes....I began to move the guide arm in and out and turn on the debarker, raise the head up and down and it started blinking on and off.  Then it would blink on and off when nothing was being done at all.  Tomorrow I am going to just crank it and not move any control and see if it starts blinking.  Banjo
Offline ladylake
« Reply #31 on: August 05, 2017, 07:00:26 AM »
To check the ground easy with out the head moving find a good ground on the head and frame and hook up a good pair of jumper cables.  Also if it stays on for a few minutes and then acts up it could be something like a resistor in the power supply heating up. My B20 had a little chip or resistor in the wiring harness that fed power to the computer, when it goes bad the display on the compter would fade out or get real dim and sometimes it would lose its set. I bypassed that little chip and put in a 1/2 amp fuse to protect the computer from a power surge about 2 years ago , no more fading display and the setworks work great.  Steve
Offline CooksSaw
  • Cook's Saw Mfg., LLC
    • Cook's Saw
« Reply #32 on: August 10, 2017, 05:50:10 PM »
Banjo,
Troubleshooting electrical bugs can drive anyone nuts.
Just shoot an email to shannon@cookssaw.com along with your phone number and let him know the best time to give you a call and we'll get you taken care of.
James
Leaders In Bandsaw Technology!
Your source for Portable Sawmills, Board Edgers, Resaws, Sharpeners, Setters, Band Blades, and Parts
Visit us at www.cookssaw.com or call 1-800-473-4804
Email: james@cookssaw.com
Offline Bruno of NH
« Reply #33 on: August 10, 2017, 06:20:00 PM »
Thank You James at Cooks sawmills :)
« Reply #34 on: August 10, 2017, 08:37:47 PM »
I will do that, thank you.  Banjo
Offline slaghunter
« Reply #35 on: February 13, 2018, 11:18:09 PM »
Banjo
Any resolution to your problem from the Cook's people?  I like a lot of features that Cook's offer but would not want to sign up for computer troubles from day one with no support from the manufacturer.
« Reply #36 on: February 14, 2018, 10:53:29 AM »
After I gave it a close look, I found a wire down under the bottom that looked like it had been chewed into by an animal of some kind.  And to be honest I have been either too busy sawing to make the repair or its been just too cold.  And right now I am dealing with trying to get a couple medical issues resolved before I lose my insurance at the end of March as I am retiring from the Mississippi Dept. of Transportation.  I had a basal cell cancer cut off my cheek yesterday and as soon as that heals up I am having my nasal passage looked at to see if they can help get me any more air in there without having to work at it so hard.  I will give Cooks a call when I have the time to devote to getting the problem fixed, and I feel sure that they will be helpful in doing so.  I normally use the scale anyway, unless I am having to cut some "not so normal" dimension lumber.  But I do intend to get the computer fixed when I have the time. When I give them a call, I want to be able to stay with it untill we get it worked out, and right now I just dont have time to do a repair that can wait. It worked great when we first got the mill and my son Bobby was running it.  I am sure it will again.  Banjo
Cooks ac36 info
Started by Fether Hardwoods on Sawmills and Milling
Last post January 02, 2011, 05:14:19 AM
by ladylake
some production numbers
Started by woodmills1 on Sawmills and Milling
Last post June 01, 2009, 09:17:44 PM
by woodmills1
Belsaw Production numbers wanted.
Started by shelbycharger400 on Sawmills and Milling
Last post March 08, 2014, 11:32:48 AM
by shelbycharger400
real world production numbers
Started by mikeb1079 on Sawmills and Milling
Last post February 23, 2015, 12:54:44 PM
by Magicman
