Author Topic: got the 250 together and runs great,but  (Read 667 times)
Offline southdakotasolo
« on: July 28, 2017, 11:43:40 PM »
got it together yesterday and cked the vac to make sure the new seals sealed and started it up. set carb to the book settings and it tried to start but acted like it was real rich, so I turned the L needle to about 3/4 and it still would not start. so ckd plug and it was flooded. cleaned plug and pulled the rope 20 times and reinstalled plug. turned needle in a 1/4 more and it ran. played with the L needle and it would run with it closed. backed it out about 1/2 turn and it runs great. high speed is right on. it will go to idle after cutting but will quit every once in a while. can not figure why the idle screw seems to do nothing to the idle. it opens the throttle as it is supposed to, to change the idle speed but the speed never changes. strange.  i'am thinking a damaged L speed seat. any suggestions welcome. I am thinking find a walbro replacement carb. have never had a problem with the zama carbs before. thks again
Offline joe_indi
  • The older I get the more I learn
Re: got the 250 together and runs great,but
« Reply #1 on: July 29, 2017, 12:15:31 AM »
3 possibilities
Metering lever is high
Metering needle has worn out
The pump diaphragm might have a leak.
With the last, at every impulse inwards fuel would go directly into the crankcase causing engine to run very rich. But beyond an rpm it would lean out because the leak would prevent proper fuel delivery
« Reply #2 on: July 29, 2017, 10:32:20 AM »
will ck items suggested. put in new kit with rebuild but would not be the first time new parts could have failed. quality cking seems to be a thing of the past thks joe wlw
Offline Air Lad
  • Onwards and upwards
« Reply #3 on: December 27, 2018, 05:35:06 AM »
3 possibilities
Not sure if you're carb is Zama or Walbro but Zama website gives a troubleshooting chart. It says this issue could be a leaking welch plug,(mine was on Husky240) or Idle and main mixture screw seats damaged. Either way the carb is certainly a likely culprit .Frustrating times but a chance to learn stuff. Good luck with it.
Ms 170/260c /039...Husk 142e/240e...Unloved Chinese 51.2cc that hasn't done anything wrong...2 x dead Mculloch's ..Vintage Poulan.. and a vintage Echo that still runs beaut
New Rancher runs great but
Started by Timberwerks on Chainsaws
Last post August 08, 2004, 01:58:15 PM
by Timberwerks
Stihl 021 Runs Great, Then Does Not Run At All
Started by BrokenStihl on Chainsaws
Last post December 16, 2018, 08:04:03 AM
by Old Greenhorn
question
Stihl 028 runs great until it gets hot then no power
Started by Jim Spencer on Chainsaws
Last post February 01, 2006, 03:15:39 PM
by kenskip1
husky 257 runs great for 5 min stalls Need HELP -PLEASE help!!!
Started by bhub on Chainsaws
Last post November 11, 2005, 12:34:16 PM
by Chris J
