Arborwear
Author Topic: We found buried treasure!!!  (Read 1797 times)
Offline Brad_bb
    • My timberframe blog
« on: July 30, 2017, 11:10:50 PM »
We found buried treasure while clearing up to an old wire fence.  I had a guy on a track loader and grabber pulling brush to clear up to the original wire fence on an old farm property.  It was woods behind the fence.  He notified me about an old chain sticking out of the ground a few weeks ago.  I could see that a hackberry root foot had grown over it and was about the diameter of a baseball.  My 11 year old niece and i finally went to dig up the treasure and it was better than I thought.  At first it looked like an old chain that I'm thinking may be civil war era??  Maybe someone can tell me how old the chain is - the part with the long links.
As we dug, the chain turned out to be longer than we thought. There was another section of chain attached to the first with a hook.  It looked like a more modern sized chain, but there were two links that were longer than the rest.  It seems like there was some weld spatter on one so that chain may be more modern and someone repaired it making the chain section longer by welding in those longer links?
I was surprised at how clean the first chain section was compared to the more modern sized one.  Maybe the first is more iron than steel?  Anyway, we kept digging and I hit something larger and metal with my shovel.  I worked it up out of the ground and Eureka!  This was truly gold to a logger/sawyer!  It was an old logging hook with ring on it's own chain section.  This too is not pitted with rust like the second chain was.  This chain and hook have been here at least 30 years, but probably more.  It took a bit of work to dig enough space under the Hackberry root without damaging it, but we got it out!  It's going to hang in the barn and may even get used - the hook part, not the long link chain.  Can anyone tell me how old the long link chain is?  Or the hook?  I'll have to wire wheel it to see if there are any markings.
Offline grouch
  • I'm recyclable!
Re: We found buried treasure!!!
« Reply #1 on: July 31, 2017, 12:05:23 AM »
I don't have a clue about its age, but if that big hook and ring are in good condition, I'd clean 'em up and use 'em.
The section of chain with the grab hook does look modern. I have a section of long-link chain resembling the other that I used to use for holding my oxy-acetylene tanks in place. It came from an old singletree that was mostly rotted away.
Nice find!
Find something to do that interests you.
Offline Kbeitz
  • Never enough time...
    • My Hobbies
« Reply #2 on: July 31, 2017, 03:31:04 AM »
I see old chains with long links in the junkyard often. .
Love machine shop work
and Wood work shop work
And now a saw mill work
Offline Chuck White
  • Sawing Mobile since 2005
« Reply #3 on: July 31, 2017, 07:08:14 AM »
The long-link chain looks like the same chain as used on the end of the tugs on a work-horses harness!
All-in-all, great find!
~Chuck~
I LOVE MY SAWMILL
Offline sandhills
« Reply #4 on: July 31, 2017, 09:36:23 AM »
What don't you find?  :D
Offline goose63
« Reply #5 on: July 31, 2017, 10:23:09 AM »
Kbeits ( AKA junk yard digger ) :D  ;D
goose
thank you to all the vets
Offline tree-farmer
  • Hillbilly in the wild
« Reply #6 on: July 31, 2017, 06:37:53 PM »
Found a  small very rusted broad ax (maybe 3 lb)  in the chicken lot recently. Never has been a house here before, maybe lost by loggers in early days. Land was logged in 1920 era. Chickens love to dig, waiting for fossils to show up.
Old doesn't bother me, its the ugly that's a real bummer.
Offline Brad_bb
« Reply #7 on: August 02, 2017, 07:35:04 AM »
This is where I found the treasure.  The root foot from this bunch of Hackberry trunks in the foreground grew over the chain.  You can kind of see the disturbed soil where I was digging to get the chain out.
Offline grouch
  • I'm recyclable!
« Reply #8 on: August 02, 2017, 08:13:56 AM »
Not near enough disturbed soil there. Might find an axe, and then an old logger at the end of it. "What took you so long, sonny?"
I found a couple of old wagon rims -- well, a 'dozer operator found one of them, so it's not exactly round any more. The hammer-welded joint was pretty clear. No way to tell when they were made.
Offline Brad_bb
« Reply #9 on: August 02, 2017, 08:39:13 AM »
That is what my friend said - "There could be an old logger dead at the end of it!"  If I find bones....
I do plan to metal detect this property...as soon as I break down and spend the money on a metal detector!
Offline sandhills
« Reply #10 on: August 02, 2017, 09:05:26 AM »
My uncle and cousin tore down an old garage that my uncle had moved onto the place probably back in the early 60's, under the floor they found an old lever action Winchester.  I asked them if anyone was down there holding on to it  :D.  The garage (actually shed) was really old and all the wood had rotted off the gun so who knows how many years it'd been under there.
Offline Bill Gaiche
  • Home built bandsaw, Kioti ck30. Sthil 211 & 361.
« Reply #11 on: August 02, 2017, 10:27:25 PM »
That looks almost like MM's. He must have lost it. bg
Offline TKehl
  • Certified Contrarian
    • Kehlhof Ranch
« Reply #12 on: August 03, 2017, 06:45:42 PM »
What's the movie where a trapper comes across a note on a man frozen while holding a rifle?
"I ____ being of sound mind and broken legs, hearby bequeath this here rifle to whomever comes along and finds it."
Kind of what this thread mad me think of.   :)
Offline WH_Conley
  • I need to tide my profile!
    • Stone Hill Hardwoods
« Reply #13 on: August 03, 2017, 07:34:47 PM »
Jeremiah Johnson
Bill
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #14 on: August 03, 2017, 08:26:59 PM »
The dude was Hatchet Jack.
Offline Chuck White
« Reply #15 on: August 03, 2017, 09:44:31 PM »
I had an Uncle who was extending a garage for a friend and when he was tearing out one of the walls, he found a 1910  401 Winchester Self Loader.
It would function, but was not safe to try to fire it!
Really deep rust pits and the wood was gone/rotted/etc!
~Chuck~
I LOVE MY SAWMILL
Offline tree-farmer
« Reply #16 on: August 06, 2017, 07:42:25 AM »
Axe head chickens dug up. Wish it could tell its story...
Offline Ricker
« Reply #17 on: August 06, 2017, 05:25:26 PM »
I have a friend that was a home builder in the 70's & 80's. When he closed up the interior walls, sheetrock or wood paneled, he hid treasures.  He bought newspapers, baseball cards, pictures of the home going up with the family around, etc.  He has got calls or run into people that have remodeled their home and they have found the items or some of them.  He says always makes him smile at how those small things made them so happy decades later.
Offline JB Griffin
« Reply #18 on: August 12, 2017, 06:50:07 PM »
Brad, a close up pic of the ring and hook esp around the eye of the hook would help.
Tree farmer, what you have there is what is referred to as a carpenters hatchet or a hewing hatchet.
2000 LT40hyd remote 33hp Kubota, 160 Prentice, Frick 2 saw gang edger, Wright W-37 ABG, Suffolk dual tooth setter, Cat claw single tooth setter,'96 F-250 7.3 PSD 4x4, CS-590 Echo, MF 20c, M681 Memo.
1.8 million bdft sawn with a Baker Dominator and counting.
Offline Brad_bb
« Reply #19 on: August 14, 2017, 06:51:42 PM »
Here is a closer view of hook/eye.  FYI I don't see any markings on the hook.  I took a wire wheel to both sides.
Info Treasure found
Started by Bibbyman on Sawmills and Milling
Last post February 21, 2003, 07:18:20 PM
by Bibbyman
Buried logs
Started by Ianab on General Board
Last post February 14, 2004, 05:52:59 PM
by Frickman
Buried in Sawdust!
Started by altonwoods on Sawmills and Milling
Last post August 28, 2010, 08:26:40 AM
by altonwoods
One man's trash is another man's treasure
Started by rbjones03 on Sawmills and Milling
Last post March 24, 2006, 09:07:21 AM
by rbjones03
