Arborwear
Author Topic: Need coil for Stihl 056AV chainsaw  (Read 471 times)
Offline mikee1149
  • Member*
« on: July 31, 2017, 01:10:24 PM »
My saw quits when it is hot and won't start. I've been told it is the coil. Need coil for Stihl 056AV. Will the coil from a 041 FarmBoss work in my saw? Thank you.
Offline ZeroJunk
Re: Need coil for Stihl 056AV chainsaw
« Reply #1 on: July 31, 2017, 08:01:55 PM »
No.  There were three ignition types for that saw. Points, Bosch, and SEM. Since it is not  Magnum that pretty much rules out SEM. The Bosch is no longer available. So, if it is Bosch you would need to convert it to SEM which requires a different flywheel and will be expensive.
Pull the starter cover off and see if there are three bolts going though the flywheel. If so it is a Bosch and you can start looking for a SEM flywheel and ignition. The SEM is a single piece flywheel and the Bosch is two piece, hence the bolts to hold it together.
There is an outside chance it has points, and could be just a bad condenser.
Offline John Mc
« Reply #2 on: July 31, 2017, 08:36:52 PM »
Have you tried forum sponsor Chainsawr for parts?
Offline Mad Professor
« Reply #3 on: August 07, 2017, 08:03:37 PM »
There is a way to fix the common problem in Bosch coils that fail when hot.  It involves digging into the coil and replacing some cheap inside parts.
It's covered well on another forum.  Do a search on Foggysail, He's the one who came up with the fix.
Not sure if I can post a link to another forum here?.........
Offline Al_Smith
« Reply #4 on: August 07, 2017, 08:15:15 PM »
If I'm not mistaken  one coil used by that model ,SEM type GA is also used on the Husqvarna 2100 .They are costly .
Chainsaw ignition coil
Started by schnur7 on Chainsaws
Last post April 22, 2016, 09:19:39 AM
by schnur7
Looking for coil for Stihl 031
Started by scott60 on Wanted
Last post October 31, 2015, 05:53:15 PM
by Magicman
Stihl 031 Coil
Started by gravydude on Chainsaws
Last post October 29, 2014, 12:49:58 PM
by gravydude
OEM coil for an 066 Red Light Stihl
Started by Lorenzo on Wanted
Last post February 13, 2014, 10:49:00 PM
by Lorenzo
