Arborwear
Author Topic: Evolution Raptor Steel Cutting Blade  (Read 281 times)
Offline alsayyed
« on: August 01, 2017, 10:13:55 PM »
 Hello  fellows I have purchase this saw blade through Amazon.
I was happy when I have my eight cuts. Net day I came to do a cut in 4 cm square tube is not cutting like used be it got dull. I was surprise what happean why did the blade get dull after eight cuts. I am using Bosch chop saw. Dose anybody run into problem, like that .?
Do I need to use a special chop saw or any regular chop saw will do.
HTC Evolution Raptor Steel Cutting Blade 355mm x 25.4mm x 66T HTCRP3552466
Offline Woodcutter_Mo
Re: Evolution Raptor Steel Cutting Blade
« Reply #1 on: August 01, 2017, 10:43:00 PM »
 Entering the cut before the blade gets up enough speed can cause the some premature dulling and can break the tips as well. It might be worth looking up the specs on the Evolution chopsaw and compare RPM specs to your Bosch. It may be spinning too fast it too slow. There are chopsaws specifically for running a carbide tipped metal chopsaws blade.
- WoodMizer LT25, Kohler, all manual, old "drag" style WoodMizer sharpener, cat claw single  setter
- Husqvarna 372XP X-Torque/24" bar, 455 Rancher X-Torque/20" bar, 550XP/20" bar, Stihl 024AV/18" Oregon speedcut
- Kioti DK45, '92 Dodge Cummins with Cannonball  bed, '07 Honda Rancher
« Reply #2 on: August 01, 2017, 10:57:57 PM »
 Looks like the blade it's self says 1500RPM max. The evolution chop saw for that blade says it runs 1450RPM no load if that helps.
Offline Kbeitz
  • Never enough time...
    • My Hobbies
« Reply #3 on: August 02, 2017, 06:39:58 AM »
Metal cutting blade saw run at a much lower RPM and cost much more.
The speed destroyed your blade.
Love machine shop work
and Wood work shop work
And now a saw mill work
Whats best for cutting steel for fabrication
Started by chainsaw_louie on General Board
Last post February 08, 2006, 06:28:45 PM
by barbender
cutting steel with band blades
Started by spencerhenry on Sawmills and Milling
Last post April 23, 2005, 01:32:01 AM
by Rockn H
? type steel for shear blade to buck up wood??
Started by whitepine on Firewood and Wood Heating
Last post December 05, 2009, 07:43:31 PM
by maple flats
Need advice, cutting steel tube ends squarely for welding.
Started by Delawhere Jack on General Board
Last post September 25, 2015, 06:06:55 PM
by Delawhere Jack
