Arborwear
Author Topic: What's the best pocket knife to carry and why?  (Read 1750 times)
Offline btulloh
« on: August 07, 2017, 02:16:20 PM »
It's a rainy day today - -
So this is a topic everyone will find agreement on:  What kind of pocket knife do you carry and what makes it THE RIGHT knife?
I carried The Prince (made by Buck) for a long time because it was perfect for work, play, and formal occasions.
It was THE BEST POCKETKNIFE IN THE ENTIRE WORLD;)
Last year I switched to a thumb-open/gravity close knife made by Benchmade:
It is THE BEST POCKETKNIFE IN THE ENTIRE WORLD;)
Good steel, easy on the arthritis, available using one hand, fashionable black durable scales.
I do still use The Prince for formal and semi-formal occasions.
HM126
Offline 21incher
Re: What's the best pocket knife to carry and why?
« Reply #1 on: August 07, 2017, 03:40:15 PM »
I don't think there is 1 best knife to carry. It depends on what you are doing.
I used to carry the Opinel's. They can be sharpened to a razor blade sharpness, but are tough to open and stain with moisture
Then I switched to Kershaws. They are spring assisted and open easily, hold a good edge, but as you can see the metal is brittle and the points break off easily but I usually have 1 in my pocket when leaving the home.
Recently I have switched back to a fixed blade for around the yard and garden. The Morakniv's have stainless blades that hold the edge very well and will not rust, The handles are comfortable and work well with garden gloves, and there is no problem with dirt getting in the mechanism all for under 10 bucks.
I guess I have not found the perfect single knife and will always be looking. :)
Hudson HFE-21 on a custom trailer, Deere 4100, Kubota BX 2360, Echo CS590 & CS310, home built wood splitter, home built log arch, and a Logrite cant hook.
Offline Corley5
  • Wolverine, Michigan
    • Whittaker Farms
« Reply #2 on: August 07, 2017, 03:46:13 PM »
Leatherman Rev.  Knife, pliers, screwdrivers with pocket clip.
Offline chevytaHOE5674
« Reply #3 on: August 07, 2017, 03:50:01 PM »
I carry a Gerber EAB which is a small box cutter that takes the disposable utility knife blades. Used to carry a Kershaw but it was always dull and I hate sharpening, then carried a multi-tool but it was so bulky that I often "forgot" to carry it. The EAB is perfect around the farm for opening boxes, feed sacks, cutting twine, stripping wire, etc; then when it gets dull take a dime and unscrew the retainer and flip the blade over, once that side is dull just replace. Nothing better than box cutter sharp.
Offline Crusarius
  • Lost in....
    • RockModified.com
« Reply #4 on: August 07, 2017, 03:55:18 PM »
I carry the best knife in the world. It costs less than $10. It has a clip. It has a blade and is spring assisted opening. This one has a window punch and a bottle opener.
What makes it the best in the world? It is cheap, and disposable. I am not friendly with any of my knives so those 2 features make it the best. If I lose it or break it I am out $10.
I knew what I thought I meant.
Offline Texas Ranger
  • Texan, by God and by choice.
« Reply #5 on: August 07, 2017, 04:13:07 PM »
Folding Buck, Swiss Army, and an SOG Flash 1 with 2 inch blade.  The SOG takes and holds a razor edge and is my field, shop, what ever, surgical instrument of choice.  Swiss is a Swiss and I use it daily.  Buck is for bigger stuff.
Offline tree-farmer
  • Hillbilly in the wild
« Reply #6 on: August 07, 2017, 04:43:20 PM »
Kershaw in right pocket, Gerber in left. If I have pants on I have at least 2 knives. Somtimes one in boot, depends on circumstance. Tools for all ocassions, formal and casual.
Off subject a bit:
Local joke about one of our "less developed counties". You can tell its a formal wedding if they are using white shotguns.   :D
Old doesn't bother me, its the ugly that's a real bummer.
Online Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #7 on: August 07, 2017, 04:47:43 PM »
My "favorite" has changed many times as time has passed but the Leatherman Original is always on my belt.
I also now carry a Benchmade pocket clip of one variety or the other and a Leatherman Micra.
Offline dgdrls
  • Learning the Art of Milling Logs, Lucas 8/27
« Reply #8 on: August 07, 2017, 05:32:14 PM »
Small, holds an edge well & doubles as a money clip.
D
Offline Woodcutter_Mo
« Reply #9 on: August 07, 2017, 06:11:06 PM »
 I think everyone will have slightly different opinions on this. But my preference (aka best knife for me) is a single blade, lock-back knife of fair quality and reasonable price. I like a knife that has a thin profile and has a pocket clip.
 The Kershaw "skyline" if one of my favorite carry knives. It is thin, light weight, simple and holds an edge pretty good and they're not terribly expensive. I also like the grip. The ones I've had are open very smooth and quick even though they do not have the spring assist.
 Another one of my favorites is the Kershaw Blur. It is a spring assisted lock back. A little larger and heavier than the skyline but a good all around, durable carry knife.
- WoodMizer LT25, Kohler, all manual, old "drag" style WoodMizer sharpener, cat claw single  setter
- Husqvarna 372XP X-Torque/24" bar, 455 Rancher X-Torque/20" bar, 550XP/20" bar, Stihl 024AV/18" Oregon speedcut
- Kioti DK45, '92 Dodge Cummins with Cannonball  bed, '07 Honda Rancher
Offline WV Sawmiller
    • Green's Sawmill Services
« Reply #10 on: August 07, 2017, 06:19:24 PM »
   There is an old thread on this topic floating around I remember seeing when I first found this site and immersed myself into reading all the info I could find on it.
   Anyway, I carry a Leatherman Surge. Started carrying a Leatherman Wave when I was working in Africa then moved to the larger Surge which I carried in Haiti, Norway, Iraq, Afghanistan, & Guinea. I have used it to skin many deer, clean fish (I do bring along a fillet knife for filleting) and work on my weedeater, lawn mower, chain saw, and sawmill. The plastic choke lever is broken on my leaf blower so I use the pliers on my Leatherman to start it when cleaning my sawmill, burning brush piles, etc. If I'm outside it is likely on my hip.
Offline dnalley
« Reply #11 on: August 07, 2017, 06:42:48 PM »
Crusarius, what is this window punch that you speak about?  Does it have anything to do with shattering the glass in a vehicle?
Offline drobertson
« Reply #12 on: August 07, 2017, 07:00:10 PM »
I like the thin ones, kershaw being a favorite, but like many shown, the pocket clip on oriented on the wrong end, like shown, if they don't close and its sharp as they should be, a poke is near by.  Now, the one MM showed is the first I've seen with the pocket clip on the correct end.. this one I'm sure is a good and well used pocket knife,, the main thing for me is a locking blade, regardless of the make.
Offline Crusarius
  • Lost in....
    • RockModified.com
« Reply #13 on: August 07, 2017, 07:21:18 PM »
Yes, I am a volunteer firefighter so its real nice to have.
Offline dnalley
« Reply #14 on: August 07, 2017, 07:34:30 PM »
Thanks, I think everybody should have one, especially in your line of service.  I've seen police and such beating on a side glass with lots of things.  Nothing like an automatic center-punch with a carbide point to make short work of these windows, from the inside as well as the outside.  And thanks for your service.
Offline grouch
  • I'm recyclable!
« Reply #15 on: August 07, 2017, 09:27:59 PM »
Cheap almost-imitation Swiss Army knife. So cheap it doesn't have a brand. Used to have stamped sheetmetal grips, but they fell off. Blades are stainless at least.
Knife, saw (actually cuts wood), scissors (uselessly flimsy), scaler / dehooker, can opener, flat-blade screwdriver / bottle opener, corkscrew, leather stitching awl (also good for boring a hole in other things), really sharp fingernail file, reamer, philips screwdriver.
Never used the fish scaler.
Find something to do that interests you.
Offline btulloh
« Reply #16 on: August 07, 2017, 09:35:18 PM »
A bottle opener comes in handy for those really tough situations.
Offline Chuck White
  • Sawing Mobile since 2005
« Reply #17 on: August 07, 2017, 10:29:43 PM »
When I'm working, I usually carry the Gerber model S30V, clipped on my belt (as apposed to clipped in the pocket).
Everyday use, I carry a little Gerber model 500 that I got from Buckmasters a few years back!
~Chuck~
I LOVE MY SAWMILL
Offline bigred1951
  • logging and sawmilling
« Reply #18 on: August 07, 2017, 11:45:38 PM »
I just carry an old case 3 blade pocket knife. Its great because it was free that I found in the dirt washed it off been using it ever since. Can tell its been well used before me and has been sharpened but it stays sharp and hasn't let me down. I usually have to check my pocket a couple times a day to make sure its still there
Offline LeeB
« Reply #19 on: August 08, 2017, 08:23:16 AM »
The best knife is a sharp knife. A dull knife will hurt you.
What Pocket Knife Do You Carry?
Started by pappy19 on The Outdoor Board
Last post March 14, 2015, 05:12:43 PM
by Offthebeatenpath
Lost pocket knife
Started by yukon cornelius on General Board
Last post September 01, 2017, 09:26:57 PM
by Dave Shepard
Knife versus Knife! Forestry Forum support Auction
Last post November 17, 2014, 07:06:39 PM
by goose63
moved
MOVED: Stock Knife - also known as a cloggers knife
Started by Mooseherder on For Sale
Last post November 04, 2015, 08:15:11 AM
by Mooseherder
