Arborwear
Author Topic: Husky 353 Won't Start  (Read 430 times)
Offline ppine
« on: August 09, 2017, 12:06:01 PM »
Trusty orange saw has been dependable. After new spark plug, new fuel, carb cleaner, cleaned air filter, nothing.  Not even close to starting.  Anyone have some ideas besides the ignition module?
Forester
Offline sawguy21
Re: Husky 353 Won't Start
« Reply #1 on: August 09, 2017, 12:10:45 PM »
Do you have spark? Lay the plug on the bare cylinder and pull the cord. Does compression feel normal? Did you try squirting a bit of gas, NOT starting fluid, in the carb throat?
Offline JohnW
« Reply #2 on: August 09, 2017, 10:15:27 PM »
Try taking the air filter off.  You didn't change very much else.
Offline old guy
« Reply #3 on: August 14, 2017, 04:42:09 PM »
Check the wire on the side of the kill switch, if it got bent 90 degrees it will touch the other contact resulting in no fiah.
Offline ppine
« Reply #4 on: September 03, 2017, 12:09:36 PM »
Bad ignition coil was the culprit.
Forester
Husky 61 Won't Start
Started by WDH on Chainsaws
Last post October 28, 2007, 10:28:51 PM
by sawguy21
Husky 262 won't start
Started by b11lefevre on Chainsaws
Last post December 05, 2009, 11:16:38 PM
by nmurph
Husky 385 xp won't start
Started by Carpenter on Chainsaws
Last post September 12, 2013, 02:24:52 PM
by Pullinchips
Husky no start
Started by stumpy on Chainsaws
Last post September 10, 2010, 04:22:24 PM
by DR_Buck
