Council Tool
Author Topic: New Cant Hook Grip  (Read 10000 times)
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
New Cant Hook Grip
« on: August 09, 2017, 08:59:08 PM »
My 60" Logrite Cant Hook got a new rubber grip today.
I contacted Logrite and had them to bring me several new rubber grips to the Pig Roast.  One that I needed plus a couple of extras.  Tammy and Kevin warned me that the grip replacement could be done but not easily.  I tried but the trapped air inside of the handle and grip had a mind of it's own so I did not do it as they described or as was printed on the enclosed instruction sheet.  Since Logrite uses air and a special jig, I decided to attempt the same method, well sorta.
I cut the old grip off so there is no turning back now.
Next I had some "unpinning" to do.  The roll pin came out easily enough, but the tip was another matter.  It was in solid so drastic measures were in order.
I added Bluecreeper, let it soak in, and then added more.
The tip then tapped right out.
Duct tape to the rescue to seal the roll pin holes.
I also needed to wrap my air nozzle so that it would fit snuggly to the end of the cant hook.
Everything is air tight so now it was time to call Marty because there was no way that I could handle both ends of a 60" cant hook.
We cleaned and lubricated both the handle and new grip with alcohol.  A shot of air and the new grip easily slid onto the cant hook handle.
It was now a simple matter to tap the tip back into the handle.
And drive the roll pin back into it's hole.  Mission Accomplished.   logrite_cool
Offline grouch
  • I'm recyclable!
Re: New Cant Hook Grip
« Reply #1 on: August 09, 2017, 09:52:04 PM »
You're just going to leave those scratches and dings in there?!?
Offline Jeff
  • Fearless Leader
  • I know that I do not know.
    • THEE Forestry Forum
« Reply #2 on: August 09, 2017, 10:13:55 PM »
:D :D :D
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #3 on: August 10, 2017, 08:03:47 AM »
Those are not scratches and dings.  They are well earned "battle scars" that are worn with pride.   :D :D
Offline Tam-i-am
  • Board Moderator
  • Gender: Female
    • Logrite
« Reply #4 on: August 10, 2017, 12:01:12 PM »
Wow Magicman your process is well documented!  I could use it as an instruction sheet.
We use Bluecreeper to get the pins and tips in as well!!!
Offline John Mc
« Reply #5 on: August 10, 2017, 03:49:48 PM »
So what is the shot of air doing to help this process?
Offline Jeff
  • Fearless Leader
« Reply #6 on: August 10, 2017, 04:28:15 PM »
Expands the foam grip so it can slide on.
Offline John Mc
« Reply #7 on: August 10, 2017, 04:35:03 PM »
OK. I was picturing just blowing it right off the end of the handle.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #8 on: August 10, 2017, 06:08:40 PM »
Oh and if you don't have a tight grip, the air will indeed send it flying.  The trick is to push the "air" expanded grip onto the handle while letting the air escape, as in quickly.
The grip is too tight (small) to allow the air to be inserted alongside the grip.
Offline grouch
  • I'm recyclable!
« Reply #9 on: August 10, 2017, 06:18:58 PM »
I wonder if dish detergent would work as well as alcohol. I once had to put a grip on a piece of weight-lifting equipment and the instructions said to use dish detergent and water to get it on. Figured it would fall off in short order, but it never got loose after drying. The soapy water made it slick and allowed the air to bubble out as the grip was pushed and twisted on.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #10 on: August 10, 2017, 07:26:34 PM »
The rubber grip manufacturer (EEZER Products, Inc.) specifically warns against using soapy water as a lubricant.
Rubbing alcohol is their first lubricant suggestion and P80 rubber lubricant is the only alternative lubricant option that they recommend.  I followed their suggestion and used alcohol.  There was no need to seek an alternative lubricant.
Offline grouch
  • I'm recyclable!
« Reply #11 on: August 10, 2017, 09:00:36 PM »
You were just trying to get grip drunk so you cant hook and have an excuse to go back nawth out of the rain.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #12 on: August 10, 2017, 09:13:30 PM »
Guilty as charged.  Rain and Heat.   smiley_sweat_drop smiley_sun
Offline grouch
  • I'm recyclable!
« Reply #13 on: August 10, 2017, 10:23:02 PM »
Aha! I knew it.
Well, seeing all those untended wounds on your poor Logrite, I just couldn't stand it any more. There's at least 1 that won't suffer your (horror!) forced feeding of alcohol and compressed air -- I just ordered one to rescue it from your clutches.
Offline Banjo picker
  • A goal without a plan is just a dream. Elbert H.
« Reply #14 on: August 10, 2017, 10:44:35 PM »
I have two mill specials with the base ball bat handle on them.  Would that not be practical on the larger versions?  Banjo
Sorry for the poor picture quality.  Thats Chris aka Meadows Miller in the background all decked out in the proper ppe.  Thats a 24 foot log I am turning with that little mill special.  Banjo
Cooks AC 36--Prentice 210C--Morgan edger--Kubota M7040 with loader--Case 580 K with extendahoe--Case 850C dozer--Int 1700 series twin cylinder dump/log/flatbed truck--logging arch--2 Logrite mill sp.--Cat claw sharpening system--And a bulldog to make sure it all stays here.
Offline LeeB
« Reply #15 on: August 11, 2017, 06:50:41 AM »
That's a name that I haven't seen in a while.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #16 on: August 11, 2017, 07:39:36 AM »
Yup, Chris aka Meadows Miller was at this year's Pig Roast.
And quiet a healthy lad he is.
Offline Crusarius
  • Lost in....
    • RockModified.com
« Reply #17 on: August 11, 2017, 07:54:15 AM »
I always used hairspray to replace grips. It acts as a lube but act fast as soon as you start to slide the grip on it dries. once dry, you have to cut the grip off.
Worked great replacing the grips on my snowmobiles. Grips never moved either.
Offline petefrom bearswamp
  • made 70-11 and still feelin pretty darned good!
« Reply #18 on: August 11, 2017, 07:59:58 AM »
Used the air method when replacing a heated hand grip on my atv last week.
Glad to know it works for other applications.
Lynn after the pig roast you now have a 60" Logrite for both hands.
LT40SHDD51
Kubota 900 RTV
Polaris 550 Sportsman ATV
1 Husky 1 gas Echo 1 cordless Echo
241 acres of woodland
Offline grouch
  • I'm recyclable!
« Reply #19 on: August 14, 2017, 04:35:44 PM »
Just got an email today -- my Logrite is on its way!
Their order form has a space for additional comments. I put "would prefer UPS" in that, thinking they might offer that way of shipping in the future if enough other people wanted it. Somebody read it and they shipped it via UPS! I think it may have cost me an extra dollar in shipping, but the point is they 'listened' and adapted immediately. (Hope it wasn't too much extra burden. Didn't expect that response).
Thank you Logrite.
Aside:
I should probably explain about that preference. Whoever handles FedEx deliveries in my area is unreliable. They delivered one of my packages to a store about 3-1/2 miles away on the very day that store went out of business and locked its doors. Tracking info naturally said they delivered it to me. Another time, they called to see if I would meet them at some highway intersection. When I refused -- UPS, USPS and even Airbourne Express deliver to my door -- they handed the package off to the US mail carrier to deliver. Anybody remember FedEx's sneering commercials making fun of the U.S. Postal Service? Just last week, they falsely claimed to have delivered a package to my son when it was still in their warehouse. I'm not a fan of FedEx.
Grip Blanks
Started by Dale Hatfield on Wanted
Last post August 18, 2009, 09:54:02 AM
by Dale Hatfield
ATV grip heater
Started by trapper on The Outdoor Board
Last post November 23, 2008, 03:45:33 PM
by Corley5
weak grip in fingers
Started by Dan_Shade on Health and Safety
Last post February 24, 2015, 10:27:22 PM
by drobertson
iron-grip cable clamps
Started by bitternut on Forestry and Logging
Last post April 30, 2005, 04:00:20 PM
by SwampDonkey
