Arborwear
Author Topic: Setting Up a New To Me Kubota  (Read 2843 times)
Offline g_man
« on: August 10, 2017, 08:11:57 PM »
I've been looking for an M series Kubota for a long time but never found one that seemed right. Late this spring I found this M5640 that I couldn't pass up and got it home earlyer this summer. 56 hp, 4WD, geared transmission, loaded 16.9 X 28 rears,  3rd function hydraulics on the loader, and a single rear remote.
I was lucky and found a used Farmi JL501 winch for it.
Been adding goodies to it little by little.
I put a saw scabbard on the loader post
and a removable shelf behind the seat mounted on the ROPS
I put my second saw scabbard and tool box on the shelf.
Underneath was pretty good except the hydraulic filters were at risk. I made a box to protect them from a direct hit.
Last but not least, so far anyway, I put a Frost Bite Log Grapple on it
Yesterday was the first day I did anything serious with it out in the woods. Pulled some maple firewood that I dropped last winter. Quite a different beast from my little L3010.
gg
Online thecfarm
Re: Setting Up a New To Me Kubota
« Reply #1 on: August 10, 2017, 09:24:01 PM »
And you have the real tires on it too!!!!
Looks new. How many hours?
I hate the way some brands put the filters down low.
Offline Stephen Alford
« Reply #2 on: August 10, 2017, 09:43:02 PM »
   That right there is some  " sweet hardware"  Looking forward to more pics.    :)
logon
Offline 2308500
« Reply #3 on: August 10, 2017, 09:58:02 PM »
i would add valve stem protectors on each wheel.
 i do quite a few and usually make them with a piece of tubing over the valve stem and a piece of flat bar between two outer rim bolts. (no pictures)
eliminates the risk of burning tubes while welding
Offline 78NHTFY
  • I'm old!
« Reply #4 on: August 10, 2017, 10:02:51 PM »
Sweet ride g_man!  All the best, Rob.
If you have time, you win.
Offline Stoneyacrefarm
  • Farmer/Service manager
« Reply #5 on: August 10, 2017, 11:00:54 PM »
Nice set up G_man.
Looks great.
Work hard. Be rewarded.
Offline thechknhwk
    • Story of the Trees
« Reply #6 on: August 10, 2017, 11:10:05 PM »
Awesome ride and attachments. 8)  I've got an L3800, and am still wishing I bought an M series.
Offline Peter Drouin
    • A&P Saw mill LLC
« Reply #7 on: August 11, 2017, 05:50:26 AM »
I like the box thing for the hydro.
2008 LT40 super,2008 edger, Cat telahandler, JD 5410 And can cut up to 45' long
http://www.forestryforum.com/sanbornton     NH Timberland Owners Association supporter.
And a license NH soft wood grader.
Sawing since 1987
Offline g_man
« Reply #8 on: August 11, 2017, 06:43:04 AM »
Thank you all !! I have used that grapple to move a few big rocks. It works good for that too. I need wider trails now  :)
I like the weldless valve stem protector idea No. 2308500. From past experience I know I should have them but it is easy for me to put off breaking and reseating a tire bead.
gg
Offline Crusarius
  • Lost in....
    • RockModified.com
« Reply #9 on: August 11, 2017, 07:58:47 AM »
Very nice. I have an L2800. My biggest complaint is absolutely no place to put anything on it. The best place is on the foot board and that is always in the way of the pedals.
I think I may copy your tool tray off the ROPS.
I knew what I thought I meant.
Online petefrom bearswamp
  • made 70-10 and still feelin pretty darned good!
« Reply #10 on: August 11, 2017, 08:04:20 AM »
Nice machine and mods!
LT40SHDD51
Kubota 900 RTV
Polaris 550 Sportsman ATV
1 Husky 1 gas Echo 1 cordless Echo
241 acres of woodland
Offline GRANITEstateMP
  • LIVE FREE OR DIE
« Reply #11 on: August 11, 2017, 08:38:08 AM »
Nice Rig g-man!  Does it have a forward/reverser?
Hakki Pilke 1x37
Kubota M6040
Load Trail 12ft Dump Trailer
2015 GMC 3500HD SRW
Offline Banjo picker
  • A goal without a plan is just a dream. Elbert H.
« Reply #12 on: August 11, 2017, 08:39:28 AM »
I like your mods.  Need to put some of those on my M7040. Banjo
Cooks AC 36--Prentice 210C--Morgan edger--Kubota M7040 with loader--Case 580 K with extendahoe--Case 850C dozer--Int 1700 series twin cylinder dump/log/flatbed truck--logging arch--2 logrite mill sp.--Cat claw sharpening system--And a bulldog to make sure it all stays here.
Offline porcupine
  • Porcupine Ridge
« Reply #13 on: August 11, 2017, 09:00:11 AM »
Not just a farm tractor anymore....a true woodsman special. Nice Setup.
Ditto on the valve stem protection.......$300 to get a tire guy out to repair mine!
2011 LT50 HD D47 Command Control
Accuset2 Debarker Lubemizer
Kubota M5040
Kubota U35 Mini-Ex
Logrite
Offline pineywoods
« Reply #14 on: August 11, 2017, 09:07:27 AM »
I have an M4700 2 wheel drive with forks on the front and home-made winch on the back. After 8 or 9 years of use, I'm well pleased. Have retrieved some hardwood logs too big for my woodmizer mill. I have a neighbor with one of the larger L series tractors. There's no comparison, the M is a much better machine for me.
100k bd ft club
Offline g_man
« Reply #15 on: August 11, 2017, 09:17:57 AM »
Your L2800 must be a lot like my L3010. I took two pieces of angle and put them across the ROPS. One in front, one behind, like a sandwich. ROPS in the middle. Used two long bolts on each side to clamp them to the ROPS at fender height. Laid a piece of plywood on top then a box. Might give you an idea.
This is how I did the M5640 shelf
The transmission is set up with a Forward low/hi - N - Reverse lever by my left thigh and a 4 speed stick on the floor between my knees. 8 forward, 4 reverse. Straight line shift Forward lo - N- Reverse. Forward hi off to the side.
gg
Offline rjwoelk
    • countrysidefirewood
« Reply #16 on: August 11, 2017, 09:35:01 AM »
I could use a graple, very nice. smiley_clapping
Lt15 palax wood processor,3020 JD 7120 CIH 36x72 hay shed for workshop coop tractor with a duetz for power plant
Offline Crusarius
  • Lost in....
    • RockModified.com
« Reply #17 on: August 11, 2017, 10:00:49 AM »
thats a nice idea. I should try that. Thanks.
How often do you hit your elbow on it?
Offline Ken
« Reply #18 on: August 11, 2017, 08:04:04 PM »
That is a very good looking piece of equipment g_man.  Hope it works out well for you
Online thecfarm
« Reply #19 on: August 11, 2017, 09:44:14 PM »
Crusarius,I did as he did with a chainsaw.
And than on the other side,
This is both gas and chainsaw oil,
And than a wrench. I have one on both sides.
Kubota L48
Started by Woodhog on Forestry and Logging
Last post June 11, 2007, 11:39:59 PM
by xtenon
Should I buy this Kubota tractor?
Started by Piston on General Board
Last post January 12, 2011, 04:16:05 PM
by Piston
Kubota FEL LA272
Started by tcsmpsi on For Sale
Last post February 23, 2013, 07:30:34 AM
by Goodmangm
It Matches The Kubota....
Started by Burlkraft on Sawmills and Milling
Last post October 20, 2006, 09:44:12 PM
by beenthere
