KNOW WHAT?
Between February 12, 2018 and June 18, 2018, this space displayed 13 Million, 871 Thousand and 87 times.
Author Topic: Cooks sharpener  (Read 13516 times)
Offline irvi00
Cooks sharpener
« on: August 10, 2017, 08:26:56 PM »
Time for me to look into sharpening my own blades. The cooks cat claw sharpener and dual tooth setter looks like a good combo for the money. Anyone using it? Pros or cons? Anything out there better? Open to any and all experience and opinions.
Offline Ga Mtn Man
  • Y'all can call me GMM
Re: Cooks sharpener
« Reply #1 on: August 10, 2017, 08:52:54 PM »
Hey Allen-  I pulled my mill right past your place yesterday on the way down to a job just outside of Alto.  I keep meaning to stop by y'alls place and say hi.  If I were buying new, I'd go with a WM CBN sharpener.  Way less of a learning curve and very consistent results, from what I've been told.
2012 LT40HDG29 with "Superized" hydraulics,  2 Logrite cant hooks, home-built log arch.
Offline irvi00
Re: Cooks sharpener
« Reply #2 on: August 10, 2017, 08:54:29 PM »
You have to stop by sometime!!!!!
Offline Ga Mtn Man
Re: Cooks sharpener
« Reply #3 on: August 10, 2017, 08:56:58 PM »
I have to come in to town tomorrow.  I may just take a little side trip out your way.  When's your less-busy time?
Offline bandmiller2
Re: Cooks sharpener
« Reply #4 on: August 10, 2017, 08:59:39 PM »
I have the Cooks cats claw and I'am well pleased. Its a robust machine and will last a lifetime. Most of the parts are commonly available, although through Cooks the parts are reasonable. One advantage of the cat is its adaptability especially if you have different brands and spacing of band teeth. Don't fret over the number of different cams, myself I use one for almost all bands. The guys will be along to tout the shaped wheel machines they are a good option but are quite specific. A good dual tooth setter is important as setting is boring. You may consider sharpening bands for others it won't take you long to pay off the sharpener. Frank C.
Offline irvi00
Re: Cooks sharpener
« Reply #5 on: August 10, 2017, 09:00:11 PM »
The WM shapeners are quite a bit more money. I've been studying hard at several different machines. The cook looks like best bang for the buck but I'd love to hear some "real" talk from real users. I've already spent 500 bucks to have blades sharpened in 6 months. Time for me to learn how to do it myself.
Offline irvi00
Re: Cooks sharpener
« Reply #6 on: August 10, 2017, 09:01:36 PM »
Thanks bandmiller2!
Offline irvi00
Re: Cooks sharpener
« Reply #7 on: August 10, 2017, 09:02:40 PM »
Ga Mtn Man, come on by anytime. I'm there 9-5, everyday.
Offline Banjo picker
  • A goal without a plan is just a dream. Elbert H.
Re: Cooks sharpener
« Reply #8 on: August 10, 2017, 11:07:18 PM »
I have the Cooks cat claw sharpener and a single tooth setter.  I love the sharpener, but do spend the money and get the dual tooth setter, like bandmiller2 said, "it is boring" with a single tooth setter. Banjo
Cooks AC 36--Prentice 210C--Morgan edger--Kubota M7040 with loader--Case 580 K with extendahoe--Case 850C dozer--Int 1700 series twin cylinder dump/log/flatbed truck--logging arch--2 Logrite mill sp.--Cat claw sharpening system--And a bulldog to make sure it all stays here.
Offline redprospector
Re: Cooks sharpener
« Reply #9 on: August 11, 2017, 01:13:13 AM »
I've got a Cat Claw sharpener, and single tooth setter. I've got no complaints. I may upgrade to a dual tooth setter some day, but I'm satisfied with the sharpener.
Offline barbender
Re: Cooks sharpener
« Reply #10 on: August 11, 2017, 02:01:50 AM »
Another vote for the Cook's sharpener here. I like the versatility of the unit, too. I've never used the WM CBN sharpeners, they look like a really nice set up, although I think having to run the cutting oil would be a pain. From what I've read, a lot of the folks that are running the WM CBN machines and say they would "never go back" to a drag grinder were using the WM drag grinder, which sounds like it may have been finicky and built a bit light? I don't think they'd go back, regardless, but maybe the difference in grind quality between the  Cook's and the CBN isn't as great. My .02
Offline Peter Drouin
    • A&P Saw mill LLC
Re: Cooks sharpener
« Reply #11 on: August 11, 2017, 06:12:52 AM »
I had a drag WM one when I started a long time ago. When I got too busy I went with the CBN.  :o :o :o :o
With the CBN you can make the blade new again. For the $$$ your way ahead with the CBN
Payed off the CBN sharpener and setter in less than a year.
Less work and a better job.
Use someone's rock or watch one work, then watch a CBN work, Then look at the two blades, Your mind will be made up fast.
2008 LT40 super,2008 edger, Cat telahandler, JD 5410 And can cut up to 45' long
http://www.forestryforum.com/sanbornton     NH Timberland Owners Association supporter.
And a license NH soft wood grader.
Sawing since 1987
Online kelLOGg
  • Still learning more than I'm teaching
Re: Cooks sharpener
« Reply #12 on: August 11, 2017, 07:21:27 AM »
I have had the Cook sharpener and single tooth setter for 16 years and am pleased with both, although a dual setter would be nicer.
Cook's MP-32, 16HP, 20' (modified w/ power feed, up/down, loader/turner)
DH kiln, CatClaw, setter, tandem trailer, log arches, tractor, thumb tacks
Offline Chuck White
  • Sawing Mobile since 2005
Re: Cooks sharpener
« Reply #13 on: August 11, 2017, 07:30:46 AM »
I also vote CatClaw!
I bought mine in 2009 and figuring at $7.00 sharpening fee, the sharpener and setter paid for themselves somewhere near the middle of 2010.
One thing I really like about the CatClaw is that it is heavy-built!
~Chuck~
I LOVE MY SAWMILL
Offline irvi00
Re: Cooks sharpener
« Reply #14 on: August 11, 2017, 08:49:27 AM »
Thanks for all the info!
Offline YellowHammer
  • Always taking steps to save steps
    • Hobby Hardwood Alabama
Re: Cooks sharpener
« Reply #15 on: August 11, 2017, 11:03:53 PM »
 smiley_thumbsup
I had a Cooks sharpener and used it for maybe three years.  It's a good sharpener, and as people said, nothing wrong with it and it will last forever.  I settled on a couple blade profiles I like and for various reasons, bought a BMS 250 CBN about 3 months ago.  All I can say is if Cooks rates an "A" then this is an "A+" and worth every penney.
I still use my Cooks dual tooth, as it sets accurately and fast.
HobbyHardwoodAlabama.com
Offline LeeB
Re: Cooks sharpener
« Reply #16 on: August 12, 2017, 06:00:06 AM »
Heavy is the truth. If you plan on moving it much you should invest in a truss.
Offline customsawyer
    • The Custom Sawyer
Re: Cooks sharpener
« Reply #17 on: August 12, 2017, 06:13:24 AM »
I have both the Cooks and the WM CBN sharpeners in my shop. Come on down and take a look at them and then make up your own mind.  ;)
Two LT70s and to much other support equipment to mention.
www.thecustomsawyer.com
Offline Mooseherder
Re: Cooks sharpener
« Reply #18 on: August 12, 2017, 06:31:43 AM »
By golly, looky here.
Lane Circle Mill
Offline Chuck White
Re: Cooks sharpener
« Reply #19 on: August 12, 2017, 07:52:22 AM »
Another thing to consider in choosing whether to go with the "drag style" or "CBN" sharpener is whether or not you will be sharpening blades for other people!
They will likely have blades with different profiles than what you have, in which case IMHO the drag style would be more forgiving due to the CBN wheels being very specific!
~Chuck~
I LOVE MY SAWMILL
WM pro series sharpener and Cooks sharpener with pics.
Started by customsawyer on Sawmills and Milling
Last post May 29, 2012, 08:45:10 PM
by Chuck White
Cooks sharpener
Started by trumpets3u on Sawmills and Milling
Last post February 12, 2010, 03:43:14 PM
by bushhog920
Modifying cooks sharpener for 4*
Started by Florida boy on Sawmills and Milling
Last post December 06, 2017, 01:37:57 PM
by Florida boy
Cooks catclaw sharpener
Started by tazz on Sawmills and Milling
Last post March 06, 2014, 08:58:54 PM
by kelLOGg
