Author Topic: Cooks sharpener  (Read 15515 times)
Offline barbender
Re: Cooks sharpener
« Reply #220 on: September 22, 2017, 09:56:17 PM »
I ordered a ruby and blue replacement stone from Cook's last year. The problem is, I put them somewhere "safe" and now I can't find them😊 I'll have to order more, then they'll turn up🙄
Offline YellowHammer
  • Always taking steps to save steps
    • Hobby Hardwood Alabama
Re: Cooks sharpener
« Reply #221 on: September 22, 2017, 10:54:22 PM »
I hate it when that happens! ;)
HobbyHardwoodAlabama.com
Offline drobertson
Re: Cooks sharpener
« Reply #222 on: September 23, 2017, 06:27:37 PM »
:D :D  I bet they are on the shelf tucked into that cubby hole, a nice safe spot,, 8)
Offline barbender
Re: Cooks sharpener
« Reply #223 on: September 23, 2017, 07:56:46 PM »
Just trying to figure out which cubby hole😊 The stone on my Cook's is getting pretty small, I either need to find the replacements or order more😊
Offline bandmiller2
Re: Cooks sharpener
« Reply #224 on: September 23, 2017, 09:04:32 PM »
Bender, the wheels are likely hanging on a nail with another wheel or small sawblade over them. Frank C.
Offline LeeB
Re: Cooks sharpener
« Reply #225 on: September 23, 2017, 09:54:45 PM »
I ordered 10 wheels yesterday. A mix of colors. That ought to last me for a long time. I'm using the last black rock I had bought from WM now. I think I bought it 5 years ago or more. Do they even sell them any more?
Offline LeeB
Re: Cooks sharpener
« Reply #226 on: January 10, 2018, 12:54:01 PM »
YH- I've always used the 3/8" thick rock. I just went to Cook's website and it appears that the only size Ruby they have is the 1/4" thick rock. That's 1/8" thinner than what I'm used to. Is that what you normally use?  Just make an extra pass or two and extending the pushing "fork" further to compensate for the 1/8" loss in thickness? Shouldn't matter, right?
I had always used a 1/4" rock before my last order and have never been able to get the proper profile. I switched to 3/8" rocks this last order and will never use a 1/4" again. Finally for the first time in all the years I have sharpened my own blades I'm getting the correct profile.
Offline kelLOGg
Re: Cooks sharpener
« Reply #227 on: January 11, 2018, 01:11:17 PM »
Do you dress the ruby colored stones the same way as the blue ones?
Cook's MP-32, 16HP, 20' (modified w/ power feed, up/down, loader/turner)
DH kiln, CatClaw, setter, tandem trailer, log arches, tractor, thumb tacks
Offline LeeB
Re: Cooks sharpener
« Reply #228 on: January 12, 2018, 01:11:02 AM »
For now I have only used the black 3/8 stone because I had a lot of blades I wanted to re-profile but I will dress the stones the same regardless of the color.
Re: Cooks sharpener
« Reply #229 on: January 12, 2018, 08:08:36 AM »
Its important to dress each stone exactly to the same working profile.  Once I had one correct, I would push the edge into a light piece of metal deep onto the stone, and real time cut the profile into the metal, much like making a master key.  From then on, all I had to do to check was slide the gauge of the wheel to check.
The ruby stones hold their profile much longer, getting a more predictable and consistent blade to blade profile.  This also makes successive sharpening easier.
Offline kelLOGg
Re: Cooks sharpener
« Reply #230 on: January 12, 2018, 08:10:44 PM »
My question about dressing the ruby stone wasn't clear. Do you use the same dressing stone to dress the ruby as you do the blue stone?
Bob
Offline Chuck White
  • Sawing Mobile since 2005
Re: Cooks sharpener
« Reply #231 on: January 12, 2018, 10:02:44 PM »
I'm not sure Bob, but I would think that it wouldn't make any difference what you used to dress the wheel with as long as it got dressed!
Just sayin'!
~Chuck~
I LOVE MY SAWMILL
Re: Cooks sharpener
« Reply #232 on: January 12, 2018, 11:23:06 PM »
Bob
Yes.  No problem.
Offline bandmiller2
Re: Cooks sharpener
« Reply #233 on: January 14, 2018, 08:15:45 AM »
Can't bring myself to call them rocks sounds so crude, they are grinding wheels or just wheels for short. I use the ceramic blue or the reds interchangeably and really can't tell the difference. Both seem to last forever. Probably shouldn't say this but once I shape a new wheel I seldom retouch it and when I do I use a diamond grit dresser. Frank C.
WM pro series sharpener and Cooks sharpener with pics.
Started by customsawyer on Sawmills and Milling
Last post May 29, 2012, 08:45:10 PM
by Chuck White
Cooks sharpener
Started by trumpets3u on Sawmills and Milling
Last post February 12, 2010, 03:43:14 PM
by bushhog920
Modifying cooks sharpener for 4*
Started by Florida boy on Sawmills and Milling
Last post December 06, 2017, 01:37:57 PM
by Florida boy
Started by NMFP on Wanted
Last post May 05, 2011, 11:44:31 PM
by najumcju
