KNOW WHAT?
Between February 12, 2018 and June 18, 2018, this space displayed 13 Million, 871 Thousand and 87 times.
Author Topic: Pride comes before a fall  (Read 511 times)
Offline Roundhouse
« on: August 11, 2017, 12:19:22 AM »
I've been milling for a little over a year, not major production but learning a lot. I know the consensus around here regarding cutting into ones backstops as a rite of passage. I'll admit to some smugness around not having done that yet. Last month I was milling some maple on my HM130. Things were going well as I got the cant squared up and I took care to lower my backstops and clamps, ready to make boards. The unfortunate part is that I overcompensated and brought them a little too low. Halfway through the first board the cant popped free and wedged the blade in place a jaunty angle before I could get it stopped.
First to evaluate, one thing was for sure, I couldn't back out.
Next I put in some wedges to open up the kerf, nope still jammed too tight, even with tension taken off the blade.
I considered cutting away board with the chainsaw but I feared the consequences if the two blades touched. Instead I started drilling across the board above the blade.
One more look with the board broken free. You can see the contortion of the blade before I raised the head and re-clamped the cant.
So there you have it. Avoiding the backstops is good but don't get carried away and drop them too fast, too soon.
Woodland Mills HM130, 1995 F350 7.3L, 1988 F350 dump, 1979 Ford CL340 Skid Steer, 1988 Yamaha Moto-4 200, various chain saws
Offline paul case
  • Original wearer of the PCM.
Re: Pride comes before a fall
« Reply #1 on: August 11, 2017, 05:54:54 AM »
Many times you can cut the board off right behind the blade and it will back out. Dont ask how I know. MANY times.
PC
pc
Offline fishfighter
« Reply #2 on: August 11, 2017, 06:03:35 AM »
Yep, been there and done that too! ;D And yes, the blade was toast. :( Hitting a back stop is better. :D
Offline Peter Drouin
    • A&P Saw mill LLC
« Reply #3 on: August 11, 2017, 06:29:08 AM »
You can keep cutting when that happens, Just go up with the blade and push, up out of the cut.
Most times you can save the blade. Try it next time. :D
2008 LT40 super,2008 edger, Cat telahandler, JD 5410 And can cut up to 45' long
http://www.forestryforum.com/sanbornton     NH Timberland Owners Association supporter.
And a license NH soft wood grader.
Sawing since 1987
Offline Chuck White
  • Sawing Mobile since 2005
« Reply #4 on: August 11, 2017, 07:35:00 AM »
Been there, done that too!   :-\
~Chuck~
I LOVE MY SAWMILL
cheesy
Pride comes before the fall
Started by Bibbyman on Sawmills and Milling
Last post May 24, 2002, 10:22:55 AM
by Kevin
My Pride
Started by teakwood on General Woodworking
Last post October 27, 2016, 08:41:53 AM
by Carson-saws
moved
MOVED: My Pride
Started by chet on Forestry and Logging
Last post October 26, 2016, 09:02:45 PM
by chet
russian pride
Started by harrymontana on Forestry and Logging
Last post May 17, 2013, 08:57:09 PM
by harrymontana
