Arborwear
Author Topic: Dolmar 120S Primer Bulb  (Read 255 times)
Offline gregd
  • Member*
« on: August 11, 2017, 05:29:59 PM »
I have a Sach-Dolmar 120 Super. Need a new or used fuel primer bulb (pump). #119155050.
thanks,
Greg
Offline sawguy21
Re: Dolmar 120S Primer Bulb
« Reply #1 on: August 11, 2017, 05:34:04 PM »
Welcome to the forum. OEM parts have pretty much dried up but a lawnmower shop may be able to match it with an aftermarket bulb. That is one rugged saw, I hope you can fix it.
Offline Savannahdan
  • Retired.
« Reply #2 on: August 11, 2017, 06:05:54 PM »
Jacks Small Engine has a Dolmar part with that # for $5.18.
Husqvarna 3120XP, Makita DCS7901 Chainsaw, 30" & 56" Granberg Chain Saw Mill, Logosol M8 Farmers Mill
Offline joe_indi
  • The older I get the more I learn
« Reply #3 on: August 12, 2017, 12:07:45 AM »
This seems to be a primer with only one tube connection. The inlet and outlet valves are  a separate unit.
It should be possible to use a modern integrated primer in place of the original if its not available.
This is the link of a parts catalog for the 120.
http://www.barrettsmallengine.com/partslist/dolmarpartslist995700062.pdf
Primer bulb issues
Started by old2stroke on Chainsaws
Last post February 04, 2016, 05:10:33 AM
by Al_Smith
Primer bulb question
Started by Rob5073 on Chainsaws
Last post March 07, 2014, 05:00:59 PM
by Rob5073
What chainsaw compable to a Stihl MS 260 PRO has a primer bulb and starts easil
Started by chris jensen on Chainsaws
Last post October 03, 2010, 09:09:04 PM
by Cut4fun
Wet/Dry bulb Problem
Started by Charles on Drying and Processing
Last post February 25, 2017, 11:45:23 PM
by YellowHammer
