KNOW WHAT?
Between February 12, 2018 and June 18, 2018, this space displayed 13 Million, 871 Thousand and 87 times.
Author Topic: log deck ideas  (Read 549 times)
Offline KamHillbilly
log deck ideas
« on: August 11, 2017, 11:07:30 PM »
Looking for log deck ideas , as I am looking to build one possibly with hydraulic log loader as I have no equipment in yard to load my hobby  band mill. Any input appreciated
Bill
Homemade Bandmill ,Clark 664b ,Case 780b ,Jonsered 670,630
Offline btulloh
Re: log deck ideas
« Reply #1 on: August 12, 2017, 07:22:41 AM »
How are you getting logs to your yard now?  Is your mill in a flat area or do have some slope that could be utilized?  Here's a simple deck I made.  It's just thrown together and sitting on top of the ground.  Works fine, but it could use a few adjustments in spacing, etc.  Making it this way gave me a chance to try it out before I put holes in the ground.  It works well enough that it may be a while before revising it.
There's a couple pictures in a recent thread about saw sheds that show how the natural slope was utilized to help get the logs where they need to go.  I'll try to link it for you.
Not fancy.  The are two short pieces of 6x6 that I just set in place when I want to roll a log onto the deck.
There'll be some more people chiming in shortly, I'm sure.
Offline kelLOGg
  • Still learning more than I'm teaching
Re: log deck ideas
« Reply #2 on: August 12, 2017, 08:23:22 AM »
Mine is similar to btullah's:
Cook's MP-32, 16HP, 20' (modified w/ power feed, up/down, loader/turner)
DH kiln, CatClaw, setter, tandem trailer, log arches, tractor, thumb tacks
Offline mike_belben
  • Pulp Friction
Re: log deck ideas
« Reply #3 on: August 12, 2017, 08:33:18 AM »
Id also incorporate a swing up mount for a cheap ATV winch on the far side to parbuckle them up the deck.  Save your energy for stacking slabs.
Revelation 3:20
Re: log deck ideas
« Reply #4 on: August 12, 2017, 09:03:45 AM »
Right now just using my skidder pulling logs off my lot in winter and setting mill up close to them and manpowering them on mill . But I have a chance to get oversize from local sawmill at a good price so I am looking for ideas, I have a couple of areas that would work with natural slope in yard I like the winch idea . Would like to make a unit I could tow to different location on property & maybe hydraulic log loader like the ones on the wood mizer mills
Offline Kbeitz
  • Never enough time...
    • My Hobbies
Re: log deck ideas
« Reply #5 on: August 12, 2017, 09:24:31 AM »
I did not have a lot of room at the mill so I made a rolling log deck. Works great.
Love machine shop work
and Wood work shop work
And now a saw mill work
Offline Darrel
  • Never throw an unopened log on the burn pile.
Re: log deck ideas
« Reply #6 on: August 12, 2017, 10:47:46 AM »
I have a natural slope and have thought about doing something like this because the slope is too much.
1992 LT40HD
Offline fishfighter
Re: log deck ideas
« Reply #7 on: August 12, 2017, 10:56:35 AM »
I will be building one something like yours. When I do, I don't want to set the post in the ground. Reason, I want to be able to pull them out so I can clean up. Moving them will make that much easy. ;D
Online thecfarm
Re: log deck ideas
« Reply #8 on: August 12, 2017, 01:09:51 PM »
For what you have,it looks good. Or that is how I do it too. Mine is just a little higher than the mill. I put on a few logs,with the tractor,and roll them on.
Time to re deck the deck
Started by rimshot on Sawmills and Milling
Last post October 01, 2013, 06:43:41 PM
by rimshot
Log Deck
Started by rooster 58 on Wanted
Last post October 31, 2014, 10:17:49 AM
by rooster 58
Oak Deck
Started by campy on Sawmills and Milling
Last post January 22, 2010, 06:53:19 AM
by ljmathias
The Deck (s)
Started by hawby on General Board
Last post June 18, 2003, 06:48:17 PM
by Jeff
