BRUTE FORCE Authorized Dealer
Council Tool
Arborwear
Author Topic: strongest weed grass killer  (Read 750 times)
Offline bigred1951
  • logging and sawmilling
« on: August 13, 2017, 12:56:57 PM »
I'm looking for the strongest weed and grass you can get. Ive used roundup before but seems like I usually have to spray it 2 to 3 times a year to keep the weeds and grass killed out. I want something that I can spray one time and not have to do it again.
Offline Gary_C
  • Sunrise on the Prairie
Re: strongest weed grass killer
« Reply #1 on: August 13, 2017, 01:26:41 PM »
Roundup is what's called a contact herbicide. It only affects what it has emerged and contacts when it's applied. That's why you have to reapply with each flush of weeds.
The herbicides with residual action are pretty much restricted for use only by registered applicators because of the potential for environmental damage both on the surface and groundwater.
So the easiest, safest, and cheapest way is to just keep reapplying Roundup as needed.
Offline luvmexfood
« Reply #2 on: August 13, 2017, 01:35:34 PM »
Roundup has a spray called 360 that is supposed to last a full season. But it expensive so your about as well off just to spray as needed. I am thinking that Ortho also has a full season spray but again it is expensive. Both are available at Lowe's.
Offline Chuck White
  • Sawing Mobile since 2005
« Reply #3 on: August 13, 2017, 01:45:04 PM »
FWIW, maybe contact your local HighWay department and find out what they use around signs, guard rails, etc!
Must be some good stuff, weeds stay dead until next Spring!   ;)
~Chuck~
1995 Wood-Mizer LT40HDG2425 Kohler - Shingle & LapSider, Cooks Cat Claw Sharpener, 4-foot Logrite cant hook.
Basic mechanical skills are all that's required to maintain the Wood-Mizer.
I LOVE MY SAWMILL
Offline Claybraker
  • Mostly New!
« Reply #4 on: August 13, 2017, 02:23:02 PM »
Imazapyr (Arsenal) works well as a soil sterilant
Offline curdog
« Reply #5 on: August 13, 2017, 02:32:18 PM »
Arsenal will last.  I spilled a little in the bed of my truck last summer.  Then the bed filled with rain water. You can still see where I backed up in the yard over a year later  :D
I will also use oust xp in areas where I have grass but tree roots near by. Oust is effective on grass,  but won't harm nearby hardwoods.
Offline scsmith42
    • Whispering Pines Farm
« Reply #6 on: August 13, 2017, 02:45:51 PM »
I can buy Pramitol at my local ag supply store.  It's usually good for a year or more if you apply it to the soil after killing everything with Roundup first.
We also buy generic roundup at the Ag Supply store for a lot less $ than Roundup.
Tom's 3638D Baker band mill
Offline Papa1stuff
  • Can I trade for an LT70?
« Reply #7 on: August 13, 2017, 03:05:10 PM »
QuickPro works great ,it kills right down into the roots, I have used it on poison ivy and after a couple applications it is dead!!
1987 PB Grader with forks added to bucket
2--2008 455 Rancher Husky
WM CBN Sharpener & Setter
Online thecfarm
« Reply #8 on: August 13, 2017, 03:35:02 PM »
I use something I get from tractor supply,might be a Pronto brand? That does works for me. Will keep the ground almost barren for a year. Much,much cheaper than round up too. I try to catch it on sale. I buy it in 2 or 2 concentrate container. Will kill a $50 bill easy.
Online Corley5
  • Wolverine, Michigan
    • Whittaker Farms
« Reply #9 on: August 13, 2017, 06:02:14 PM »
I've used Pramitol with good results :)
Offline coxy
« Reply #10 on: August 13, 2017, 07:22:51 PM »
gas works good to  :-X ;D
Offline red
  • we will never forget
« Reply #11 on: August 13, 2017, 07:57:14 PM »
It's not the strongest but boiling hot water will kill some grasses . Your mileage may vary.
We have a lot of good boys and girls in harms way
lets all support them and their familys.
Offline Larry
« Reply #12 on: August 13, 2017, 09:38:23 PM »
I've been buying imazapyr at TSC.  It comes with glyphosate (generic Roundup) mixed in.  Its comparatively cheap, gives pretty good season long control, and fairly easy to find.  If we get a lot of rain all bets are off.
Other chemicals are better but require a license, are expensive, and will move through the soil if you don't know what your doing.
Nine out of ten trees recommend wood for your building project.
Online chet
« Reply #13 on: August 13, 2017, 11:29:46 PM »
Look into Mojave 70E  ( Imazapyr - 7.78%  Diuron - 62.22%)
With one application, Mojave 70 EG herbicide will give you bareground vegetation control of 150 species of weeds, perennial and annual grasses. Application can be done before or after emergence to eliminate weeds for one season. I am pretty sure it is not restricted use in your state.
https://www.rosepestsolutions.com/docs/msds/Mojave-70-EG-2011.pdf
I am a true TREE HUGGER, if I didnt I would fall out!  chet the arborist
Offline JB Griffin
« Reply #14 on: August 14, 2017, 04:32:21 PM »
Sodium cloride.
2000 LT40hyd remote 33hp Kubota, 160 Prentice, Frick 2 saw gang edger, Wright W-37 ABG, Suffolk dual tooth setter, Cat claw single tooth setter,'96 F-250 7.3 PSD 4x4, CS-590 Echo, MF 20c, M681 Memo.
1.8 million bdft sawn with a Baker Dominator and counting.
Attack of the Killer Johnson Grass
Started by Left Coast Chris on General Board
Last post June 29, 2008, 08:26:00 AM
by Norm
Strongest 6x6's
Started by azmtnman on Sawmills and Milling
Last post May 28, 2015, 04:06:36 AM
by Ianab
What is the best/ strongest wood glue?
Started by LaneC on General Woodworking
Last post October 17, 2014, 03:25:31 PM
by beenthere
the strongest portable winch?
Started by ray299 on General Board
Last post June 16, 2017, 06:02:20 PM
by Magicman
