Author Topic: Sleep apnea  (Read 6744 times)
Offline thecfarm
Re: Sleep apnea
« Reply #80 on: March 23, 2018, 08:56:40 PM »
Yes,I went back. Once was for the test,than they fitted me with a mask and took the test again. I had to go with one that went over my nose and mouth.
Offline 51cub
Re: Sleep apnea
« Reply #81 on: March 24, 2018, 09:29:10 AM »
I didn't have to go back for equipment, but things could have changed over the years. They did want me to go back from time to time to see what changed. After 3 or 4 overnights, I was out of patience. I can stay home and not sleep. I changed Drs. The insurance company wanted a new test for a new Dr, and the Drs office talked them into letting me do it at home. I did have to go pick up the machine, but that wasn't bad, just in the next town
I believe in the hereafter, because every time I take two steps into the tool crib to get something I wonder " what did I come in here after"
Offline xlogger
Re: Sleep apnea
« Reply #82 on: May 13, 2018, 06:38:36 AM »
I'm just got up from my 3rd night with the cpap. I believe I will like it. Sleeping good and over 8 hours a night, usually 5-7. I'm going to try the humidifier tonight maybe, no tried it yet.
Offline ljohnsaw
Re: Sleep apnea
« Reply #83 on: May 13, 2018, 11:11:21 AM »
IF you are not having a bloody nose in the morning, I would NOT try the humidifier.  It is a fairly high maintenance item.  You need to clean it regularly so mold does not grow in it.  If you want to go camping, most CPAPs can run off 12v, but if you have a humidifier, it will kill a battery in very short order - it draws quite a few amps to run the heater.
John Sawicky
Offline xlogger
Re: Sleep apnea
« Reply #84 on: May 13, 2018, 07:42:00 PM »
I hear you, I'll keep doing like I've been doing, thanks
sleep apnea
Started by thedeeredude on General Board
Last post October 20, 2007, 11:31:11 AM
by junkyard
moved
MOVED: Sleep apnea
Started by Roxie on General Board
Last post August 16, 2017, 12:21:39 PM
by Roxie
Can't Sleep
Started by Autocar on General Board
Last post November 16, 2011, 07:17:15 AM
by pappy19
Can't Sleep
Last post January 07, 2013, 08:43:13 AM
by drobertson
