Arborwear
Author Topic: Brace location  (Read 504 times)
Offline mpuste
Brace location
« on: August 15, 2017, 03:20:54 PM »
In most timber frames I see in the US, braces are located at the top of posts, such as between a post and plate.  The ability of the brace to prevent racking should be just as effective if it is located at the bottom of a post, such as between the post and sill, and by moving the brace down you can create more options for locating windows.  Are there other structural (or non-structural) reasons for choosing to locate braces at the top of posts?
Offline Dave Shepard
  • Geometrically proportional
    • My homepage
Re: Brace location
« Reply #1 on: August 15, 2017, 03:43:57 PM »
I don't think the effectiveness would be nearly the same if the braces were at the bottom of the posts.
Offline Roger Nair
Re: Brace location
« Reply #2 on: August 16, 2017, 01:32:51 AM »
I admit that I have a bias towards plate to post braces but I have used both sill to post and sill to plate braces.  Long sill to plate bracing will be stronger and will require fewer braces to secure a frame and are very common in old barns in my area.  From a raising pov once a sill to post braces are set the frame is braced without resorting to temporary bracing.  Braces that tie to securely supported sills are rock solid, without flex.  sill to post braces do not pick up direct load as they would from plate to post braces that impart a steady side load to posts that can stress joints and can lead to breaking joints.  Frames that have plate to post braces are probably more ductile and that could be a long term advantage.  I have worked on frames that were broken by braces footed in sills, in those cases the barns were not well maintained for generations.
An optimist believes this is the best of all possible worlds, the pessimist fears that the optimist is correct.--James Branch Cabell
Offline Don P
    • Calculator Index
Re: Brace location
« Reply #3 on: August 16, 2017, 06:56:00 AM »
I don't see a problem with it. A longer brace is better than a shorter one. Look at old European work and you'll see both used. Old balloon frames and earlier platform frames prior to let in bracing typically had sill to corner post bracing.
Offline mpuste
Re: Brace location
« Reply #4 on: August 16, 2017, 07:31:40 PM »
Thanks everyone for the feedback.  A brace from sill to plate is something I had not considered and I have seen barns here in the Midwest with that construction.  One of the reasons I asked the question is because I have seen timbered buildings in Germany with braces located mostly below the windows.  I have heard that the design of those buildings was partially due to the lack of quality timber so the design may have been driven more by material availability than optimal strength or rigidity.
    • My homepage
Re: Brace location
« Reply #5 on: August 16, 2017, 08:54:42 PM »
Did those German buildings have brick infill (fachwerk)?
Offline mpuste
Re: Brace location
« Reply #6 on: August 17, 2017, 05:49:44 PM »
I can't say for certain if they had brick infill but since the exterior (between timbers) was coated with plaster it is very possible.
Offline Don P
    • Calculator Index
Re: Brace location
« Reply #7 on: August 17, 2017, 10:06:24 PM »
Will you have some form of bracing sheathing? If so that will be where the load goes.
Hitch vs Drag- Skid trail vs Twitch rd....Location Location Location
Started by riverlogger on Forestry and Logging
Last post February 23, 2014, 11:47:13 AM
by Rick Alger
Location,Locatiion,Location
Last post March 09, 2005, 01:02:39 PM
by SwampDonkey
Brace problem
Started by beetle on Timber Framing/Log construction
Last post April 05, 2005, 07:38:47 PM
by Jim_Rogers
H Brace Question
Started by Ironhead80 on General Board
Last post June 23, 2016, 08:56:54 PM
by Magicman
