Author Topic: Building a house with a sawmill  (Read 5665 times)
Offline Jmiller160
« on: August 16, 2017, 12:08:39 PM »
Just wanting to hear some success stories of anyone who has built their home entirely with a sawmill.. and how much money it wound up costing.. I bought a mill a couple months ago and have been trying to cut all my stuff, been hard at it just wondering if it's worth it in the long run?
Offline Kbeitz
  • Never enough time...
    • My Hobbies
Re: Building a house with a sawmill
« Reply #1 on: August 16, 2017, 05:58:52 PM »
I wish we could do that here in Pa. Building codes wont allow it.
Love machine shop work
and Wood work shop work
And now a saw mill work
Offline mike_belben
  • Pulp Friction
« Reply #2 on: August 16, 2017, 07:25:02 PM »
I had planned to but we ran aground financially.
Ive been logging to get by and keeping all of the sound but unsellable timbers for our home.  Im gonna frame it in debarked round knobby oak timbers about 10" diameter.  Cordwood infill for walls and probably a sod roof.  Have most of the doors, windows, cabinetry etc.  Expecting about $15,000 including slab and septic.
Revelation 3:20
Offline irvi00
« Reply #3 on: August 16, 2017, 08:33:37 PM »
I did it but it was back when my family had an entire lumber company. Two sawmills, kiln and a planer. It saved me a bundle. But I don't see why a smaller mill and a little work can't do the same. As said above, the building code could be a problem.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #4 on: August 16, 2017, 09:03:45 PM »
I have sawn the framing lumber, etc. for ~20 entire homes plus my Cabin Addition.  If you have a fair market for the logs, then sell them and buy your lumber, but the problem in my area is that "fair market".  That plus the many SYP trees being killed by the Southern Pine Beetle, etc.  There is no market for these logs so salvaging them and sawing you own framing lumber, etc. is a smart move.  The log/lumber sawing cost is about a third of what "store bought" lumber would be, plus the logging labor and cost.
Offline Planman1954
« Reply #5 on: August 16, 2017, 09:15:27 PM »
I built my barn, which I converted into an apartment and music room with lumber I cut on my Norwood. I dried it before using in the interior in my solar dry kiln. As far as cost...I'm guessing I spent around $25,000 for materials, including slab, windows, appliances, paint, nails, insulation, felt, wire, and plumbing supplies.
As for permitting, around here, a camp can be built using sawn lumber. My nephew built one which is actually as good as any home. We cut and dried all the framing lumber for it:
Norwood Lumbermate 2000 / Solar Dry Kiln /1943 Ford 9n tractor
Offline FloridaMike
« Reply #6 on: August 16, 2017, 10:05:57 PM »
I would think that Log Homes are a code compliant option in most areas, that won't allow rough sawed non-graded framing lumber  (might take an engineer's seal on the plans).  Many years ago, I cut several log cabin packages that were build and passed code in FL and AL.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #7 on: August 16, 2017, 10:19:32 PM »
The permitting/coding in some of our nearby counties will not allow non-graded framing lumber.  In some, the blueprint has to indicate #2 and/or rough sawn framing lumber so that the house is being built according to the blueprint.  Lastly, some counties have no building/code requirement and rough sawn framing lumber is allowed without question.
I talked with a (potential) customer this afternoon that has over 100 logs ready to be sawn into framing lumber for his home.  No building loan and no building permit nor coding restriction.  The only holdup was that it is ~100 miles away and he will have to secure/provide lodging.
Offline Jmiller160
« Reply #8 on: August 16, 2017, 10:40:09 PM »
I live in South East kentucky and there aren't any building restrictions other than septic and if you own over 25 acres you fall under a homestead act and you don't need plumbing inspection either.  I've cut about 60 tulip poplar from my land and are cutting them 68 to build a log house with my woodlands hm126.. I've only got 3800 In my mill.
Offline Darrel
  • Never throw an unopened log on the burn pile.
« Reply #9 on: August 16, 2017, 10:42:11 PM »
Building code here requires framing lumber to be graded. Plan A is to get my lumber graded and if that falls through, plan B, which is really part of plan A, is to saw everything I can that isn't framing lumber. Siding, flooring, interior paneling, cabinets, etc, all will be sawn on my mill.
1992 LT40HD
Offline paul case
  • Original wearer of the PCM.
« Reply #10 on: August 16, 2017, 11:03:06 PM »
I have done it twice.
I figured the first one would have cost more than the mill for the lumber and the logs were cheap in 08. I was low on the figuring and when it was finished we used more of my rough sawn lumber than we planned for. I think it paid for the logs and the mill.
That manual mill started the business that we are still running today, which makes a living for my son and my family.
PC
pc
Offline mike_belben
  • Pulp Friction
« Reply #11 on: August 17, 2017, 06:28:19 AM »
Amen.
Revelation 3:20
Offline red
  • we will never forget
« Reply #12 on: August 17, 2017, 06:31:17 AM »
Only you can say if it is worth it .  Wants vs Needs
We have a lot of good boys and girls in harms way
lets all support them and their familys.
Offline drobertson
« Reply #13 on: August 17, 2017, 07:21:08 AM »
It will be much less expensive if you own your mill, but will also take longer with more labor, of course.
keeping with a good plan, sawing out extra and being sure to properly sticker stack all your lumber is critical.
Offline Banjo picker
  • A goal without a plan is just a dream. Elbert H.
« Reply #14 on: August 17, 2017, 08:06:36 AM »
I put an addition on my house and redone a back porch with material i sawed on my mill.  I already had the mill.   Banjo
Cooks AC 36--Prentice 210C--Morgan edger--Kubota M7040 with loader--Case 580 K with extendahoe--Case 850C dozer--Int 1700 series twin cylinder dump/log/flatbed truck--logging arch--2 Logrite mill sp.--Cat claw sharpening system--And a bulldog to make sure it all stays here.
Offline Larry
« Reply #15 on: August 17, 2017, 10:45:10 AM »
Sawing framing lumber for a house has about the lowest return on investment of any activity in house construction.  Depending on how you value your time, this could even be a negative return.  Its not just the sawing either.  Think every stud has to be end trimmed....on each end. :(
Given the limited number of hours owner/builders have to use, I would think hard about where I wanted to use those hours.
Higher ROI is sawing siding and paneling.  Highest ROI is hardwood for flooring, cabinets, and trim.  I would knock out those needs first so I could air dry and finish off in a kiln if required.  This is a great place to save $$$$'s.
Offline Jmiller160
« Reply #16 on: August 17, 2017, 11:59:39 AM »
Money is far harder to come by than time for me, I'm recently unemployed so I bought the mill and u own my trees, now my fulltime job is to take care of my kids and mill all my other time.
Offline alan gage
« Reply #17 on: August 17, 2017, 12:53:57 PM »
I think it depends on what you want to build and how you want to build it. Just got a mill and haven't started sawing yet but I did build my own home from the ground up about 6 years ago. After getting it done I realized that the actual lumber that went into framing the house was one of the cheapest parts of the build. The foundation, concrete work for slab, septic tank, electrical, insulation, siding, and roofing was where things really started to add up. That was stick framing and 2x4 or 2x6 studs are cheap and if you're doing standard 8' or 9' walls it's a huge time saver to use standard stud lengths since it works with sheathing and sheetrock. But if you're doing something not standard and post and beam construction maybe it would make more sense to mill your own rather than buy.
Another option would to be use standard construction lumber where you can and cut your own beams or columns where it will save you the most money. Being able to saw your own siding (vertical board and batton?) would probably be a good place to save some money too. Cutting your own trim (inside and out) should save some money.
Of course I've done plenty of things that didn't make sense on paper from a $$$ vs. time standpoint but mentally it was worth it for me.
Alan
Timberking B-16
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #18 on: August 17, 2017, 01:59:02 PM »
Since you have a minimum of cash but you do have the time, sawmill, and logs/trees, I am in the "do it all" corner.  Notice in the above linked "Cabin Addition" topic that I sawed the foundation, subflooring, flooring, framing, wall paneling, shelving, ceiling sheathing, and some ceiling.  The only items that I did not saw was the siding since I was matching the existing plywood siding and the fascia because I used pressure treated lumber.
Offline dablack
« Reply #19 on: August 17, 2017, 02:14:07 PM »
Like the others have said, it all depends.  It takes lots of time to trim each and every stud.  If you have tons of time and little money then YES!  If you want pride of "every stick came from my trees" then YES!
I have some big beams on posts on my porch that Den-Den cut for me.  That stuff is custom and would of cost a fortune to order special.
Like others have said, the biggest money saver will be cutting the flooring and trim.  The more custom the house, the more money you will save.  If you are building a 1700 sqft ranch with 8' ceilings, then......I wouldn't worry about cutting the framing but I would have some crazy nice 6" wide oak flooring and other custom bits.  That alone would pay for the mill.  Maybe a nice timber frame porch on the back or front too!
For my house, it is a two story and 26x52.  I would need posts down in the middle of the house to be able to use normal mill cut lumber.  I wanted an open downstairs so I went with floor trusses.  You could mill 2x4s and make your own floor trusses and roof trusses but again, that is a bunch of work!
Austin
Austin
Building my own house in East TX
Building a new house
Started by Kingcha on General Board
Last post May 06, 2017, 06:31:05 AM
by scgargoyle
building a house for mom
Started by wheelinguy on General Board
Last post June 30, 2012, 09:42:31 AM
by bama20a
House building project under way
Started by DanG on General Board
Last post September 04, 2004, 06:40:04 PM
by Gilman
house building costs
Started by Cedarman on General Board
Last post February 14, 2009, 09:37:49 AM
by pigman
