Author Topic: After the sanity check!  (Read 10443 times)
Offline Satamax
« on: August 16, 2017, 04:42:31 PM »
Well guys!
I realy wanted a JD440. But here there's a few and far between. All expensive.
This machine was just next door, over the Lautaret pass. Less than 20 miles!
Originally, it's a "debusqueur" a french type of skidder. 4wheel drive, 4 wheel steer, lockers. 4 high, 4 low 4 extra extra low.
The snowblower is shot. But there's plenty of parts for the log stacler blade, winch etc. There is a "unic" V8 of 270hp in the back, with PTO etc. Hydraulics.  and whatnot. Only 250h on the machine, 150 on the back engine. The "chimneys" of the snowblower have 360 hydraulic rotation, which will become my log turner on the sawmill somehow.
V8 will most certainly replace the GM 6-71 in my gen set. There's rams on the snowblower for the blade etc.
So not a bad deal at 2000 Far sounder than a well broken in 440. It has a 6 inline saviem 5.5 liter of 125 din HP in the front.
So there's some new iron in my fleet.  ;D
French CD4 sawmill. Latil TL 73. Self moving hydraulic crane. Iveco daily 4x4 lwb.
Offline Riwaka
Re: After the sanity check!
« Reply #1 on: August 16, 2017, 05:55:47 PM »
Is that cab ROPS certified? or are you going to put a rollcage or T-Bar on?  (T- Bar behind cab http://www.engrep.co.nz/fertiliser.html  )
What type of tires might you use, old tyres and rims off an old forwarder?
http://www.trelleborg.com/en/wheels/your--industry/agriculture--and--forestry/forestry--machines
Offline mike_belben
  • Pulp Friction
« Reply #2 on: August 16, 2017, 07:17:35 PM »
Now this is a bad idea i can get behind.. Right up my alley!
I like it.  What axles, and does it have any sort of suspension?
Revelation 3:20
Offline Satamax
« Reply #3 on: August 16, 2017, 08:07:45 PM »
Riwaka, Rops certified? In France?  ;D for the moment, i have no plan. But along the roll cage line. There's plenty of space inside. Tirewise, the michelines on it will do for the moment.
Mike Belben, these are portals, made by Latil. Brakes juste outside the differential bulb. Not articulated, there's cardans, but a rigid bar below.  Ans the leaf springs are mounted on this. I haven't paid attention if SUA or SOA.
Here's a page describing the original tractor.
http://www.avant-train-latil.com/TL73.php
Offline sawguy21
« Reply #4 on: August 17, 2017, 02:38:27 AM »
I could have used that on my driveway last winter but the neighbors might get annoyed. I can just imagine it moving snow. ;D
Offline Satamax
« Reply #5 on: August 17, 2017, 04:49:42 AM »
Here, it's been 3 or 4 winters with less snow than usual. So the local machines weren't working much.
This one comes from paris airport. Which one i don't know. But it has only 275h. It has a 4 digit horameter, but can't have any more than the 275, it's brand new in some protected spots.
Same as mine, at work.
Offline Satamax
« Reply #6 on: August 17, 2017, 04:57:18 AM »
To work, but in the original configuration.
Discovered yesterday, that i have the small wheels :( For which it's even harder to find tires!
Offline mike_belben
  • Pulp Friction
« Reply #7 on: August 17, 2017, 06:24:54 AM »
Well, it looks much better suited than that crane and appears to have diff lock in both axles which will be a tremendous help.  A rear steering portal is an odd choice for a skidder since theyre inherently weakened by the kingpins and leverage that the portal box places on the inner knuckles, but it appears they have incorporated a lower tension brace across the bottom trunnion?  I suppose i would sacrifice the clearance for the increased strength.
Are they 14-20 xml's?  Thats a common american military tire.
Do you have a winch for it?
I highly encourage you to fab grapple fingers when you build your blade.  For every log ive wanted to push there has been another ive wanted to pull.
Revelation 3:20
Offline 47sawdust
« Reply #8 on: August 17, 2017, 06:57:58 AM »
Between this rig and the sawmill,there is no need for a sanity check.I can see you are a very troubled soul.There is no known cure ,so you might as well continue on the path you are on. ;D
 Best of luck to you.All I have to do is show your latest find to my wife and I can bring just about anything home.
 You are a great point man,keep up the hard work.
 Mick
Mick
Offline Satamax
« Reply #9 on: August 17, 2017, 07:53:36 AM »
Mike, there's lower tension brace. With those tires, about 12inches from the ground. They are 11.00r20 michelin XL. But i need one, cose one blew and has been replaced by a no good firestone.  There's a lock at the back, but there's no sign of a handle for the front. I bet there is all the gear inside tho.
I wouldn't mind a set of 14.00R20.
 Mick
My soul is fine. It's just my brain which is demented! :D
Offline Satamax
« Reply #10 on: August 17, 2017, 09:36:30 AM »
Guys, just one daft question.
Do i keep the ultra low gears? It's on the PTO, and i could use this one for other things.
I have 1/1 for normal gears. 1.72 to one for the low ones. The max speed in normal 5 gear is supposedly 45kmh. or 28mph.  1.72 lower is already very good. I wonder if the 12.8 to one could be of any use?
Offline Riwaka
« Reply #11 on: August 17, 2017, 05:09:13 PM »
The 11.00R20 is probably a NATO vehicle offroad tire, should be able to source from various tire suppliers as used tires if a new tire costs too much.
https://www.bkt-tires.com/en/pattern/em-936#cod_8903094026272_over   11r20
https://www.bkt-tires.com/en/pattern/earthmax-sr-44#cod_8903094046706_over
https://www.vrakking-tires.com/truck4x4-tires/231-1100r20-michelin-xzl-new.html
Offline Satamax
« Reply #12 on: August 17, 2017, 05:38:00 PM »
Sent a mail to vraking ans to another guy in France.
The later has replied, 294 shopping and taxes included.
I will see what vraking says. I hope i can scrounge enough to buy the tire, from the blower's metal. Ans few other bits of metal i have. I need four tons :(
Offline Puffergas
    • Puffergas
« Reply #13 on: August 17, 2017, 06:28:16 PM »
I would be one proud puppy to own that machine. Nice ! !
Somewhere 20 miles south of Lake Erie.
GEHL 5624 skid steer, IHC 300 Utility, Timberjack 225D, Burg Bandsaw mill, Steiger Bearcat II
Offline mike_belben
  • Pulp Friction
« Reply #14 on: August 17, 2017, 10:37:33 PM »
The 1:1 or 1.72.. Thats a transfercase after the transmission right?
You want to know your crawl ratio.  First trans gear x tcase ratio x ring and pinion ratio x portal box ratio = crawl ratio.
My truck has about 60:1 crawl ratio..it might go 4mph to the floor in takeoff gear, and will get any load rolling without throttle.  I think deeper than 70:1 is pointlessly slow.
Revelation 3:20
Offline Satamax
« Reply #15 on: August 18, 2017, 03:26:48 AM »
Mike, So these 1:1 and 1:1.72 are the transfer case ratios.
Then after you have 1.93 in the differentials, and 4.93 in the portals.
So that's Just for the secondary transmission, a ratio of 16,36, gearbox not taken into account.
The gearbox is from the Renault TRM4000 or it's brother Saviem SM8.
First gear is 7.41 to 1
Second 4.19
third  2.39
fourth 1.48
and fifth   1
So first gear low ratio, that's already 121 to one engine rotation. Plenty i would say!
With the 12.8 to one inserted, and the 1.72 out of the cinematic chain, that's 902.48 to one in first gear. So, at idle, it would do one wheel rotation every minute or so. Not worth it i'd think!
Offline mike_belben
  • Pulp Friction
« Reply #16 on: August 18, 2017, 10:48:19 AM »
Youre confusing me now.
Im seeing 5spd transmission, 2spd transfer case, single speed differential and portal box reductions.  Are there more? Does it have two manual transmissions in series.. Or a brownie box or something?
Crawl ratio
7.41 x 1.72 x 1.93 x 4.93 = 121.27
Transport speed
1.0 x 1.0 x 1.93 x 4.93 = 9.51
Seems pretty well set up IMO.   I think a 900:1 ratio is a pointless novelty unless you plan to get out and walk beside it.  Youd only find use for that type of ratio (inches per minute) in concrete type traction.  Anything wet or muddy will just spin.  Muck requires wheelspeed to clear the tire voids.
120:1is a very capable ratio.  It should be able to provide enough pull and engine braking for what you want to do.
Revelation 3:20
Offline Satamax
« Reply #17 on: August 19, 2017, 01:59:19 AM »
Hi Mike.
I don't know what is a brownie box!
Basically, there's a second gear at the gearbox (i think) . Sort of. It's on the PTO, then coming back out to the main shaft with pulleys and V belts. An additional 12.8 to 1. I will try it. But i doubt it's of any use besides blowing snow. And since i need PTO for lots of things. I think this will have to go.
Offline Satamax
« Reply #18 on: August 19, 2017, 02:19:28 AM »
Starting thinning down
Photo from yesterday.
Offline mike_belben
  • Pulp Friction
« Reply #19 on: August 19, 2017, 11:41:34 AM »
Browne-lipe was a manufacturer of auxiliary transmissions that went in series behind the primary trans to provide more ratios on american trucks of yore.  Eaton fuller incorporated the this internally with their auxilliary tail section in the roadranger line, which gave you only one shifter and some air buttons to wrestle, so brownies went extinct and fuller reins supreme.
I understand the pto box now.. It takes power off the trans input shaft, steps it down through extra reduction device and feeds it back into the driveline.  The purpose was to get full engine rpm (to run pumps, trecher, vibrator plow or auger etc etc) at a half mile per hour ground engagement speed.  Its not uncommon for trenchers to have a gear trans with a hydraulic drive option for plow engagement thats routed off the pto then back into the tcase.  Useless for you unless you plan to mow, till or mulch with it too.
I love your truck.   Im looking at those blower mounts and cylinders thinking how easy it would be to base a log loader/blade off them.  Then weld a limb riser brace right off that to an exo skeleton cage over the cab.  This thing is cool.
Revelation 3:20
question
Sanity check! JD 440
Started by Satamax on Forestry and Logging
Last post April 11, 2017, 07:16:11 PM
by lynde37avery
Is sanity returning ?
Started by jim king on Forestry and Logging
Last post May 05, 2007, 09:41:35 AM
by olyman
Before Pulling Your Mill....Check and Re-Check!
Started by POSTON WIDEHEAD on Sawmills and Milling
Last post August 09, 2018, 01:44:17 AM
by Ianab
Check
Started by Magicman on Health and Safety
Last post September 01, 2015, 09:50:23 PM
by Magicman
