EZ Boardwalk Sawmills. More Saw For Less Money! sponsored by Northeast STIHL
Author Topic: Cherry Burl.....should I dry and if so how?  (Read 322 times)
Offline tuckerolson
  • Member*
« on: August 19, 2017, 07:47:03 PM »
So I cut an awesome cherry burl about the size of a beach ball off of a tree that was getting cut to clear land and I would like to make a bowl out of it.  I was hoping for some advice on how to dry it or if I even should before I start carving away on this thing.  Thanks for any help!
Online WDH
  • April 1998 - August 2008
Re: Cherry Burl.....should I dry and if so how?
« Reply #1 on: August 19, 2017, 08:01:34 PM »
Dry it slow, outside, under a shed.  You might consider wrapping it in several layers of newspaper to slow the drying.  Fast drying will crack it.  If you bring it inside, it will dry too fast and will likely split and crack.  Slow wins the race.
Woodmizer LT40HDD35, John Deere 2155, Kubota M5640SU, Nyle L53 Dehumidification Kiln, and a passion for all things with leafs, twigs, and bark.
Offline wesdor
« Reply #2 on: August 19, 2017, 10:44:32 PM »
Wanting a bowl says turning to me.  If that is the case I suggest you turn it green to about 10% of desired size, then put it in a brown paper bag with shavings. Let it dry for at least 3 months.
With something that size you should really consider using a McNaughton corer (or similar). That way you would get several bowls from this burl.
Welcome to the forum. Where are you located?
Cherry Burl
Started by whitepe on Sawmills and Milling
Last post September 28, 2003, 07:22:20 PM
by ohsoloco
Cherry burl
Started by purple otter on Ask The Forester
Last post April 10, 2013, 05:20:29 AM
by KBforester
drying cherry burl
Started by moselgreenwing on Drying and Processing
Last post January 14, 2017, 12:22:14 PM
by Den Socling
Cherry burl for pen blanks?
Started by jackpine on General Woodworking
Last post April 10, 2007, 10:41:35 PM
by low_48
