Arborwear
Author Topic: Old single sided planer rebuild  (Read 7756 times)
Offline Quebecnewf
« on: August 21, 2017, 05:25:44 AM »
Found this old planer setting outdoors on a hill and decided to rescue it and get it running again if possible
I now have a pile of parts on my workshop floor.
Got the cutter head bolts out yesterday . They look ok I think.
Still a bit more to remove and things to unstick and then start to clean and paint.
Interesting project and I am learning a lot as I go
Quebecnewf
Offline Kbeitz
  • Never enough time...
    • My Hobbies
Re: Old single sided planer rebuild
« Reply #1 on: August 21, 2017, 05:28:16 AM »
Great... I'll be watching... Nice to see someone else doing the rust thing.
Love machine shop work
and Wood work shop work
And now a saw mill work
Offline Quebecnewf
« Reply #2 on: August 21, 2017, 05:53:28 AM »
Yes I saw you are into the rust as well. I think you are far ahead of me in this dept. This is my first real rebuild. Sad to say I do not weld so I have to be real careful not to break anything. This unit has come apart very good so far. I have been using a mix of ATFand acetone mixed 50/50 . Seems to be doing the trick. Glad I got all those cutter head bolts out without breaking any. I do have some stuck shafts that are a concern. Still have not went at them with full force yet. Just heating and squirting so far. Giving them time and notice that they are going to come loose one way or the other.
Quebecnewf
Offline Kbeitz
    • My Hobbies
« Reply #3 on: August 21, 2017, 06:15:11 AM »
I don't use a lot of force. If something does not move like a bolt
I just bump it back and forth many many times. You can't see it
but it is probably moving maybe only a 1000's of an inch. That will
grow. Next thing you know it's moving 2000's of and inch. I have
spent an hour tapping a wrench one way then the other without
seeing it move. Keep at it and you will win.
Offline bandmiller2
« Reply #4 on: August 21, 2017, 07:32:28 AM »
Cast iron parts can be soaked in muriatic acid to completely remove rust and make them look new, flush well. Planers are a finicky machine requiring much adjustment and maintenance. After your complete teardown it will hide no secrets from you and you will not hesitate to make needed adjustments. Frank C.
Offline Bob_T
« Reply #5 on: August 21, 2017, 08:21:46 AM »
Great project.  I have a similar but different 24" Porter planer that I haven't started on yet.  Who's the maker of yours?  What will you power it with?
You probably know, lots of ways to remove rust, including plain old cleaning vinegar, citric acid, the commercial rust remover chemicals and electrolysis.
1959 FWD Model 286 Dump Truck
1955 Allis Chalmers HD-6G Crawler Loader
1941 GMC CCKW 6X6
Wood-Mizer LT30 G18
Offline grouch
  • I'm recyclable!
« Reply #6 on: August 21, 2017, 09:14:16 AM »
Those curved spokes suggest it is very old. Any info?
Find something to do that interests you.
Offline Kbeitz
    • My Hobbies
« Reply #7 on: August 21, 2017, 09:18:23 AM »
When you get it finished and want to keep it looking good
and you want a slippery top get a can of (SlipIt Sliding Compound).
It also protects it from rusting again. This stuff is great for table saws.
Offline TKehl
  • Certified Contrarian
    • Kehlhof Ranch
« Reply #8 on: August 21, 2017, 09:31:32 AM »
As do the counterweights versus springs.
Offline Quebecnewf
« Reply #9 on: August 21, 2017, 05:41:47 PM »
Here's what I know. The planer is badged Bournival . This was a guy ( Doctor) in Montreal who had a business selling woodworking machines . Machine was made by Continental Machine Works in Montreal. Their production line was bought out by Jos Poitras ( my three sided planer was made by Jos Poitras. They in turn were bought out by General tools of Drummondville . Small, world. No idea of the age maybe 1940 ,s . Not sure about that.
Quebecnewf
Offline Kbeitz
    • My Hobbies
« Reply #10 on: August 21, 2017, 06:29:55 PM »
I was one told the all curved spokes are made in England or out of USA.
All straight spokes are made in USA.
Offline Bob_T
« Reply #11 on: August 21, 2017, 10:30:10 PM »
Sign up over at OWWM.org  (old wood working machines) and post a picture.  Those guys know everything about vintage machinery.
Quebecnewf
1941 GMC CCKW 6X6
Wood-Mizer LT30 G18
Offline Quebecnewf
« Reply #12 on: August 21, 2017, 10:45:53 PM »
That's were most of this info came from . Been posting over there as . Lots of good info to be had
Quebecnewf
Spent the day up righting my kiln that blew over last fall
Offline Andries
  • Making buildings out of big curvy logs
« Reply #13 on: August 21, 2017, 11:25:25 PM »
Hey!
It's good to see that "high wind casualty" being put right-side up again!
Will you install ground anchors and cables as hold downs this time?
Also, looks like a great planer find.
Looking forward to seeing more photos of the clean up and restoration project.
LT30G24
Ford 545 Series loaders
Stihl chainsaws
Offline grouch
  • I'm recyclable!
« Reply #14 on: August 22, 2017, 02:49:36 AM »
Curved castings were made to relieve stresses regardless of country of origin. See, e.g., the old curved wrenches that became the focus of a collector fad a few years ago.
Offline Quebecnewf
« Reply #15 on: August 22, 2017, 05:29:49 AM »
The upright went well. Got it pulled back near its original location . Will shore it up in the coming days and make some repairs . Inside will be gutted and redone , water damage .
Quebecnewf
Offline Quebecnewf
« Reply #16 on: August 22, 2017, 05:55:31 AM »
Just need to be jacked, levelled and shored
Quebecnewf.
Offline Quebecnewf
« Reply #17 on: August 22, 2017, 06:11:12 AM »
Got the rest of the planer took apart yesterday . Time to start cleaning and painting . Then hope that I took enough pictures to put it back together again
Quebecnewf
Offline grouch
  • I'm recyclable!
« Reply #18 on: August 22, 2017, 07:06:01 AM »
Quebecnewf.
And anchored. ;)
Offline sealark37
« Reply #19 on: August 22, 2017, 08:57:59 AM »
Your planer looks like a great project.  Keep us in the loop, and good luck on the refurb.  Regards, Clark
any one using a 2 sided planer
Started by ozarkgem on General Woodworking
Last post June 03, 2016, 07:38:41 AM
by ozarkgem
4 Sided Planer
Started by ddcuning on Sawmills and Milling
Last post April 16, 2015, 11:17:15 AM
by ddcuning
4 sided planer ......
Started by TexasTimbers on Sawmills and Milling
Last post February 17, 2006, 07:12:51 PM
by karl
4 sided planer molder
Started by jim king on Drying and Processing
Last post April 24, 2010, 07:49:43 PM
by Larry
