Author Topic: Clambunk skidders  (Read 1065 times)
Offline quilbilly
Clambunk skidders
« on: August 28, 2017, 08:35:42 PM »
I was fooling around on the interwebs and saw tigercat and a couple others make or have made clambunk skidders. I've never seen em out west here. What is the benefit? Increased payload or less drag? They look neat but surely must have a limited scope since they don't pop up much on the used market
a man is strongest on his knees
Offline kiko
Re: Clambunk skidders
« Reply #1 on: August 28, 2017, 10:09:49 PM »
Quilbilly,  the clam bunk works well for situations where the skids are long and mostly straight.  They don't do technical maneuvers well when loaded, but nor do I.  I have seen some clam bunk machines with a self loader, but most require a shovel to load them.   In a swamp type operation the landing must be set up on high ground for load out ,  and the knuckle boom can't be moved closer the wood .  The shovel will pull the mat as I goes and load the clam bunk with nearly a truck load per turn.   This method is also used with grapple skidders with the shovel pulling the mat and pilling bunches.
Offline quilbilly
« Reply #2 on: August 28, 2017, 11:27:46 PM »
In other words it must be a clear cut and no tight turns. The benefit would be more wood per turn?
Offline kiko
« Reply #3 on: August 28, 2017, 11:40:46 PM »
Yes more wood per turn.   Logging water must be clear cut in order to create the floating mat.   The longest skids will come first as the mat gets pulled.   Many of the clams and skidders are dualed on the front and have bogeys on the rear.
Offline mike_belben
  • Pulp Friction
« Reply #4 on: August 29, 2017, 01:59:40 PM »
Is it fair to say more wood per twitch equals less trips and thus less damage to the trail, or does the extra weight offset this and tear things up just the same?  Basically, im asking can a clambunk be considered "environmentally friendly" in any way or is that a joke in itself?  Not that im a greenie.
Revelation 3:20
Offline Riwaka
« Reply #5 on: August 29, 2017, 07:50:00 PM »
The North Carolina  bottomland swamps have been harvested for 200 years. (so logging appears fairly sustainable)
http://ncforestry.info/ncdfr/managing_and_regenerating_timber_in_bottomland_swamps/
The maintenance of the log haul road in a swamp is a key. Logs get pushed down, put some more on top.
Offline quilbilly
« Reply #6 on: August 30, 2017, 08:52:51 AM »
Are they used much outside of the swampland? That's a huge amount of wood on that tigercat.
Self Loading Skidder or Clambunk
Started by seastrike on General Board
Last post August 14, 2006, 09:12:04 PM
by seastrike
skidders first day on the job
Started by aksawyer on Forestry and Logging
Last post May 03, 2010, 08:49:20 AM
by Frank H.
c4 c5 skidders
Started by stoneeaglefarm on Forestry and Logging
Last post January 26, 2014, 06:31:31 PM
by SliverPicker
question
skidders
Started by David_c on Forestry and Logging
Last post January 04, 2005, 04:38:19 PM
by Ed_K
