Arborwear
Author Topic: Different kind of Sawing  (Read 1188 times)
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« on: August 30, 2017, 02:49:10 PM »
The "engineer" and "construction foreman" messed up several years ago and did not allow for proper water runoff so I decided that it was finally time to correct my his mistake.
Yup, completely different sawing because this was the saw;
The rent on the saw is not bad, but those diamond blades are expensive.   :o
The two cuts will be 4" deep X 20'.  The chalk line did not stay with the cooling water running but it did serve as a guide.
I made about " deep cuts but the "saw" needed to rest at the end of each pass.   ;)
Done.  I made a few wobbles but no one will know it 100 years from now.  ;D  The best part of the job was leaving that saw back at the rental shop.  ::)
I opted for some heavy artillery for the removal.
That took about 30 minutes and was the best $15 that I ever spent.
Mississippi Pudding Stones.  Just in time before the "Harvey" rains get here.  At least now I will not have to deal with water all of the way to the back of my RV shed.
Offline rasman57
  • Location: Manistee National Forest Pine River Michigan and Home in Illinois
  • When you come to a fork in the road...take it.
Re: Different kind of Sawing
« Reply #1 on: August 30, 2017, 03:03:51 PM »
Well done.  Sometimes the pressure of knowing it is really supposed to rain is a good motivation to tackle those " when I get around to it"..... jobs.        Hope you stay mostly dry.  It sure dumped a massive amount already.  Really makes one remember that in spite of all the modern technology and progress, we still are just part of nature and all that can happen.    God Bless those affected folks.
Offline Savannahdan
  • Retired.
« Reply #2 on: August 30, 2017, 05:19:21 PM »
Not that you really needed it but you might want to try a crayon the next time for marking the line.  I probably would have had the line meander down the road instead in a straight line like you did.  Both of those tools were definitely right for the job.
Husqvarna 3120XP, Makita DCS7901 Chainsaw, 30" & 56" Granberg Chain Saw Mill, Logosol M8 Farmers Mill
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #3 on: August 30, 2017, 06:20:01 PM »
 :D I do not plan on there being a "next time" because this old puppy was whipped by the time I finished.  It will be interesting to see how it does tomorrow when we are forecast to get the most rain.   :P
Offline grouch
  • I'm recyclable!
« Reply #4 on: August 30, 2017, 06:45:58 PM »
mumble grumble nothing wrong with a hammer and a mason's chisel mumble
grumble lazy slackers gotta have power this and power that
get a brick and clean up those edges before somebody cuts a toe off!
mumble back in my youth people used muscle and bone 'stead of gas and 'lectric
grumble diamond saws even!
Find something to do that interests you.
Offline POSTON WIDEHEAD
  • Getting old but doing it with Friends.
« Reply #5 on: August 30, 2017, 08:08:48 PM »
Will you be traveling with this concrete saw?
Saw 'em and leave 'em?  :D :D :D
Where's the Spoon?
Online paul case
  • Original wearer of the PCM.
« Reply #6 on: August 30, 2017, 09:46:11 PM »
I did  a little of that for a local Christian radio station a while back. I broke minetheirs out with a sledge hammer and it wasnt too bad,but it was on the slim side of 4''.
PC
pc
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #7 on: August 30, 2017, 09:59:26 PM »
Yup, a sledge would have done it, but that $15 was well spent.  The rental store is only a couple of miles away.   ;D
Offline sandhills
« Reply #8 on: August 30, 2017, 11:49:20 PM »
I've been helping my sale barn boss on his construction side a few times lately with concrete which is pretty much his specialty, only takes one 10 yard load to remember why this is a young man's sport.  I just wish I could get in on an easy job where we don't have to rake it 3/4 of the way across  :D.  You did good Lynn  ;).
Offline Brad_bb
    • My timberframe blog
« Reply #9 on: August 31, 2017, 09:37:05 AM »
Do now do you have to dig down and put a drain pipe?  Do you have a path for water to go?
Offline Ox
  • Trying to learn/remember something new every day.
« Reply #10 on: August 31, 2017, 10:07:00 AM »
:D ya old grouch!  This made my morning.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #11 on: August 31, 2017, 10:45:53 AM »
And it is brought to you by the guy that (gasp) uses mig, arc, and plasma !!!   :o  Oh, what is this modern world coming to??   ???
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #12 on: August 31, 2017, 10:52:03 AM »
Brad, I could put a 4" perforated sewer pipe in the slot, but for now I will be content to watch the water run off.   ;D
Offline grouch
  • I'm recyclable!
« Reply #13 on: August 31, 2017, 11:38:03 AM »
Would bar grating work? It'd have to be removable because you know bolts, nuts and tools will seek that slot out.
Offline coxy
« Reply #14 on: August 31, 2017, 01:58:33 PM »
mm next time you do something like that call me and come get my walk behind saw has 20in diamond  blade and a 15hp motor no back braking and lines are straight  ;)  I cut blue stone so I have experience in the sawing department the diamond  you where using is 90$ here and on a good weekend cutting stone ill use up 2 of them  those blades will also cut metal that's what I use to cut my cable and sheet metal up to 1/4 thick
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #15 on: August 31, 2017, 08:06:21 PM »
Thanks, but I have no intention of there being a "next" time.
Offline coxy
« Reply #16 on: August 31, 2017, 08:42:59 PM »
 :D :D
Offline grouch
  • I'm recyclable!
« Reply #17 on: August 31, 2017, 08:50:47 PM »
I have legitimate excuses: Ran out of charcoal, lost my flint rock, and the sun was in my eyes.
Offline Don P
    • Calculator Index
« Reply #18 on: August 31, 2017, 10:19:23 PM »
I rent one more thing for jobs like that, that brute breaker fits his hands better than mine  :D I've got a few of those tools I try to keep loaned out to the young bucks, it makes them easier to reel in later  ;D
in the same aisle with the perforated drain pipe they usually have some plastic trench drain that looks pretty good, if it fits.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #19 on: September 01, 2017, 09:09:13 PM »
NDS Trench Grates are ordered and on the way.  Thanks Don P.   :)
A different kind of sawing.
Started by Dave Shepard on General Board
Last post May 17, 2014, 06:15:48 AM
by GDinMaine
Sawing black walnut log and post-sawing refreshment, Kickapoo style.
Started by whitepe on Sawmills and Milling
Last post October 06, 2011, 02:19:39 PM
by Magicman
comparing thin kerf sawing to circle saw sawing
Started by postville on Sawmills and Milling
Last post March 18, 2011, 08:40:49 PM
by northwoods1
Kind of a way out...
Started by HiTech on Forestry and Logging
Last post November 26, 2014, 07:48:49 AM
by HiTech
