Author Topic: Dead tree too near my sawmill!  (Read 2108 times)
Offline MbfVA
    • Tanglewood Ordinary Country Restaurant
« on: August 31, 2017, 07:02:17 PM »
I've been putting an eye on this dead tree with its double poles for a while, and it isn't getting any less scary.   Not bigger huge, and no branches left, but it will fall right on the head of my sawmill by my calculation.  No no.
 Here are some photographs with annotations (it's not easy to get them in the right order adding photographs using the system here, but you'll get the point):
I'm thinking of using my 24 foot painter pole and pushing a loop and/or my grapple up the tree a ways, maybe 10-15 ft, putting a snatch block on a solid tree in the other direction which is slightly downhill to boot, and going a safe distance away at a 90 angle and pulling it over.   Neither part of the tree looks safe to saw.  We may have to secure both shoots at once, since pulling one down might bring the other one down and in a different direction!
 Anyone got anything to suggest, the floor is open and I appreciate it.
Offline TKehl
  • Certified Contrarian
    • Kehlhof Ranch
Re: Dead tree too near my sawmill!
« Reply #1 on: August 31, 2017, 07:46:05 PM »
I'd move the mill then drop the deader half at the crotch followed by the other half.  Looks like Oak maybe?  Often the heartwood stays good long after the sapwood is squishy and rotten.  May even mill something out of the big half.   :)
Just don't be a ding dong like I was on a similar snag.  I cut it and confident what was going to happen, so I stayed at the stump and watched the snag break in half the limb of another tree and then the top half came back at me.  If I had planned my exit and taken a few steps away like normal... I wouldn't have a warning story.   ;)
Of course don't do it if you don't feel comfortable making the cut.  Dead snags release with less warning than a live tree.  More snap than creak if that makes sense.
Offline mills
« Reply #2 on: August 31, 2017, 08:31:08 PM »
Boy, the big question is how rotten is the heart wood. A lot of options if the center is solid. Only one if it's soft, and the pictures don't look promising.  :(
Not being there to study it, I'd move the mill and set up out of harms way. If that's not possible, move the mill and take her down where she wants to go. Trees that dead are dangerous and unpredictable. Don't mess with it if you don't have to.
Offline landscraper
  • LT4H0DD47. Dyna SC14. Hudson Stake Sharpener.
« Reply #3 on: August 31, 2017, 09:46:12 PM »
Can you get your Liebherr in there and just push it over?
Firewood is energy independence on a personal scale.
Offline nativewolf
« Reply #4 on: September 01, 2017, 07:01:13 AM »
I won't do this for just anyone but if you promise to comp me a good meal here's what I'll do:
we'll bring the peterson up to my place here in Fauquier County, when you need to saw something you just pop up the road and get to work, nice drive right up 29/15.
that is a nice woodpecker tree and your forest looks a bit light on good snags.  Just let it sit there and rot down.
when you feel safer about moving the saw back, say 8 years or so, we'll bring the peterson right back.  Don't have to move the mill pad or anything, it will all be sitting there waiting.
Liking Walnut
Offline MbfVA
« Reply #5 on: September 01, 2017, 09:43:03 PM »
 Can't afford the taxes
Offline MbfVA
« Reply #6 on: September 01, 2017, 09:44:21 PM »
 I think you should come on down and help me push it over. I'm good for the dinner.  I'll call Don P to see if he can figure out the engineering angle.
 smiley_chop smiley_swinging_board
Laughs aside, my brother-in-law got his shoulder broken in 10 places or more, they kind of lost count, when a snag he bumped with an open station tractor fell on him.  Found out his boss did not have Worker's Comp. on him, but his boss was quite wealthy so no problem.
 Mike would probably come lock me up if he thought I was about to mess with something like this.
Offline nativewolf
« Reply #7 on: September 01, 2017, 10:49:37 PM »
Ochh, Open station and tractor are not a good combo in my opinion.  I've known 2 farmers to have died in rollovers.
If I come down I think we should eat first, so if it falls on me at least I'll be full and happy  :D
Liking Walnut
Offline Ianab
« Reply #8 on: September 01, 2017, 11:32:21 PM »
Well first step would be moving the sawmill, it is portable after all.
After that I agree with attaching a nice long cable / rope and putting some tension / rocking on the tree from a safe distance. If it falls or even breaks into pieces, problem solved from a safe distance. If you try winching and rocking It, and it won't move or break, that suggests it's probably safe to saw. Release the rope tension and put some cuts in It, leaving lots of holding wood the first time. Then try the winch again. Repeat until it does fall down
The initial pull and shake is to find if the top is ready to fall on your head as you are cutting. If you can shake the tree and it stays intact it "should" hold together while you saw it. But only cut to the point where it can be winched over, then get a safe distance away and pull. A dead tree like that can snap as it falls, and the top 1/2 comes back towards the stump end.
Offline DDW_OR
« Reply #9 on: September 02, 2017, 02:09:40 AM »
best idea.
Mill costs $$$$$
repairing $$$$$$$$
MOVE THE MILL
Multitek 1610EZ, TimberKing 2000 & Talon Sharpener,
Offline longtime lurker
« Reply #10 on: September 02, 2017, 03:09:32 AM »
You sound them with a hammer?
In any case move the mill first "just in case", but it dont look like it'd be any issue dropping it.  Drop a vertical bore cut in first where your front will go and that'll give you an idea of how solid it is. If its pulpy to the middle go get a big yellow wedge. If firm enough take the away lead first, humbolt notch and a big front then bore cut the back. If it goes as you're doing the front thats okay because at worst it might bend a bar but bars are cheap.
That leaves the second one thats leaning towards the mill. Swing dutchman on a humbolt notch and bore cut your way out the back again and he'll spin straight out the way. And with the mill aint there and he goes early again thats okay.
If somewhere between firm enough and really pulpy a staggered front is a good bet. Prolly got some other name but your front is a series of horizontal cuts each one deeper then the last and as it goes it kinda compresses them down.Steadies it up a little and you can keep an eye on your tree looking for movement as each cut is deeper then the last.
Still prefer big yellow wedge though in every case, but thats because I'd rather sit on one of them then a chainsaw any time ;D
 WHAT YOU NEVER WANT TO DO is do anything that involves banging on wedges in rotten trees. Thats an easy way to get real dead real fast... vibration travels up the tree and next thing you know the whole top is on its away down to meet ya...
Offline MbfVA
« Reply #11 on: September 02, 2017, 04:46:02 AM »
Lots a' information, thank y'all very much
What is the yellow wedge, I think I'm missing something in the translation from down under, there?
Offline Neilo
« Reply #12 on: September 02, 2017, 05:09:28 AM »
A bulldozer
Offline Satamax
« Reply #13 on: September 02, 2017, 05:39:28 AM »
Griphoist?
French CD4 sawmill. Latil TL 73. Self moving hydraulic crane. Iveco daily 4x4 lwb.
Offline TreeStandHunter
  • ISA Arborist from Michigan
« Reply #14 on: September 02, 2017, 06:25:21 AM »
By the look of it im surprised its still standing. Bring that mill over to my house for safe keeping while you get the tree on the ground  :D
In all seriousness move that mill before you end up replacing the railing on it after it gets a good size dent.
Currently only have a Panther Mill 2, hoping to upgrade to a WM soon!
Offline MbfVA
« Reply #15 on: September 02, 2017, 11:29:45 AM »
As one of my fellow Virginia residents joked, I do have a 953 sized track loader, but the swath of destruction to get it in there would be  like a mini cyclone.  Before the sawmill was here, another tree fell over very nearby, and hit our house, no major damage.  It was pretty solid, unlike the instant case.  Rain softened root ball.
Between the leaves & sticks in the gutters and the hazard of falling against the house, we're going to make sure no trees are within falling distance of our new home & equipment/buildings at the farm.
Offline MbfVA
« Reply #16 on: September 02, 2017, 11:37:32 AM »
One of the difficulties of the current location of the mill is the very uneven ground it's on. It was a bear to get the sawhead on the tracks & in fact to get the tracks down and level to start with, would've been much easier if the mill has been ATS instead of WPF.  Wife is not keen on laying down sawdust elsewhere, but she had to help me get the mill where it is so I may win that argument.  The mill is going to go to the farm soon, and there's no more free wood around the house/restaurant here to cut, although based on experience it's only a windstorm away.
Many thanks for the advice so far.  I will be sure to post pics of the tree in detail on the ground for the benefit of those who might encounter this situation  in the future.
Offline Ianab
« Reply #17 on: September 02, 2017, 03:09:41 PM »
If you only move the mill and leave the blocks and cribbing in place you should be able to lay it back in exactly the same place in minutes. If things go bad and your supports get knocked over, it's just going to take a bit longer, but nothing important gets bent.
« Reply #18 on: September 02, 2017, 05:01:24 PM »
Big yellow wedge usually means a bulldozer; but a 953 class drott will do. :D
If i had the machine, a mill set on uneven ground, and an issue with trees dropping around the mill site. .. well let's just say that the path of destruction would be wide and catastrophic, and there'd be room to swing a road train in the mill yard.  Just sayin
Offline luvmexfood
« Reply #19 on: September 03, 2017, 07:25:34 AM »
I cut a maple similar to this awhile back except one fork was still good. Rot in the bottom but I could salvage a couple of good logs out of the green side. Don't remember exactly but my first cut was down thru the fork. Somehow got saw hung and got my other saw. Know things went from bad to worse. The rotten fork had a good lean in the direction I was trying to fall it but it somehow swung around and I had to drop the saw and make a hasty exit.
Not very experienced but I might consider putting a couple of straps or chains around them to hold them together. Then tie a line off and give it a good pull in the direction away from the mill. Put a pulley on a tree in the desired direction of fall and run the pull line thru it and then off to the side and take a comealong and snug it up. Then try cutting from the stump taking both down at the same time. Maybe after making the face cut tighten the line a little.
Give me a new saw chain and I can find you a rock in a heartbeat.
Is this tree dead?
Started by chisel on Forest Education
Last post October 11, 2005, 07:17:29 PM
by maple flats
Partially Dead tree ID
Started by dirtmover1250 on Tree, Plant and Wood I.D.
Last post March 15, 2016, 12:59:45 PM
by dirtmover1250
Tree with a lot of dead branches
Started by BenGill on Ask The Forester
Last post February 10, 2014, 06:48:48 PM
by BuckeyeAaron
Thinking out loud. Looks like a dead tree to me !
Started by Remle on Sawmills and Milling
Last post May 24, 2018, 06:25:02 PM
by Remle
