Author Topic: Felling question  (Read 818 times)
Offline Tony
Felling question
« on: September 05, 2017, 10:14:21 PM »
   I've  noticed on some felling vids, after the notch is cut there is a vertical cut/slice on each side, what is the purpose of this cut??? ??? ??? ???
                                                Thanks, 8) 8) 8)
                                                               Tony
TK1600, John Deere 4600 W\frontendloader, Woodmaster718 planer\moulder, Stihl MS461 Stihl 036 & 021 & Echo CS-370
"You cannot invade the mainland United States.  There would be a rifle behind each blade of grass."  Adm. Isoroku Yamamotto ( Japanese
Offline Riwaka
Re: Felling question
« Reply #1 on: September 05, 2017, 10:21:26 PM »
Are you referring to de-butressing cuts?
https://www.forestry.gov.uk/pdf/fctn5.pdf/$FILE/fctn5.pdf
Offline teakwood
  • Switzerland
« Reply #2 on: September 06, 2017, 08:22:14 AM »
They make this marks on each side so it's easier to see where the back cut has to stop, so you won't cut through the hinge wood
Offline Jemclimber
« Reply #3 on: September 19, 2017, 08:59:23 AM »
It's also to prevent fiber pull to the side of the hinge which can steer the tree after the hinge closes/breaks.  Sometimes this pull is intentional to cause swing, but when you're stuck to the tree at heights with a lanyard, this fiber pull can suck you into the tree with very bad results.  In climbers lingo it is sometimes referred to as "snipping the ears".
lt15
question about felling notch
Started by jackpine on Forestry and Logging
Last post April 02, 2011, 12:26:59 PM
by RandyMac
Felling leaning trees question
Started by Eugene on Forestry and Logging
Last post April 27, 2003, 11:49:55 PM
by Eugene
Intact felling question and Boulder Creek trail clearing.
Started by Chuck De Luck on General Board
Last post May 05, 2015, 10:33:07 AM
by Chuck De Luck
The old way of felling trees (with a felling axe)
Started by nebruks on Forestry and Logging
Last post February 25, 2012, 11:05:39 AM
by Jeff
