KNOW WHAT?
Between February 12, 2018 and June 18, 2018, this space displayed 13 Million, 871 Thousand and 87 times.
Author Topic: Using Aspen as framing lumber  (Read 701 times)
Offline TreeStandHunter
  • ISA Arborist from Michigan
« on: September 06, 2017, 12:29:32 PM »
I have a few acres of mature aspen that i have felled to make way for deer bedding/cover. I do not currently have a barn and am curious what you guys think about using the aspen for framing lumber? I have seen some tongue and groove wall panelling but i have not read anywhere about its use for framing...i also have quite a few white oaks with a few reds mixed in and i know i could frame with those but i would prefer too use the aspen if i can.
Currently only have a Panther Mill 2, hoping to upgrade to a WM soon!
Offline 1938farmall
  • Uff-da
Re: Using Aspen as framing lumber
« Reply #1 on: September 06, 2017, 04:34:36 PM »
Many old-time farmers used aspen(popple) for all kinds of outbuildings.  if kept out of the rain it will last many decades.
aka oldnorskie
Offline chevytaHOE5674
« Reply #2 on: September 06, 2017, 06:16:43 PM »
My neighbors house is built entirely of aspen. Sawed on sight and nailed up green. As long as its kept dry its as good as anything. If it gets wet it will rot in a heartbeat.
« Reply #3 on: September 06, 2017, 06:31:25 PM »
Did they get alot of warping when it dried? I plan on everything being out of the weather i just assumed id have too air dry it before using it
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #4 on: September 06, 2017, 07:01:32 PM »
TreeStandHunter, I for one am glad that you turned your name around.   smiley_dizzy
« Reply #5 on: September 06, 2017, 07:11:46 PM »
Haha ya i can see howbit could be confusing. Jeff was kind enough too change it for me
Offline Don P
    • Calculator Index
« Reply #6 on: September 06, 2017, 08:08:33 PM »
This calc lists aspen and gives allowable spans for joists and rafters;
http://awc.org/codes-standards/calculators-software/spancalc
Offline Corley5
  • Wolverine, Michigan
    • Whittaker Farms
« Reply #7 on: September 07, 2017, 09:25:14 PM »
Our house is built with big tooth aspen.  Cut the trees one day, sawed them into lumber the next and nailed them up the third with ring shank and ardox nails.  We waited a few months for it to dry down before hanging drywall.  Aspen will warp and twist in stickered piles when it dries.  It's best used green 8) 8)  Don't skimp on nails ;)
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #8 on: September 07, 2017, 09:51:03 PM »
Many times folks have to use what they have.  I sawed Tulip Poplar framing lumber today and it will probably all be nailed up next week.
« Reply #9 on: September 08, 2017, 02:56:08 PM »
Thanks for the info everyone!
I was a little discouraged because I had been told that Aspen will not do well with framing but I now feel up to the challenge for building the barn.
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #10 on: September 08, 2017, 05:45:25 PM »
Google is your friend.  There are many charts, etc. concerning the strengths of various lumber species.  LINK  Also do not overlook the Red Toolbox on the left.
Offline rjwoelk
    • countrysidefirewood
« Reply #11 on: September 08, 2017, 10:14:21 PM »
x2  :D
Lt15 palax wood processor,3020 JD 7120 CIH 36x72 hay shed for workshop coop tractor with a duetz for power plant
Aspen for framing?
Started by Fredh on Ask The Forester
Last post February 11, 2009, 10:11:51 PM
by blaze83
Framing lumber
Started by vfauto on Drying and Processing
Last post June 24, 2017, 08:00:20 AM
by Bruno of NH
Framing Lumber
Started by brooksmill on Sawmills and Milling
Last post May 18, 2007, 12:10:33 PM
by Fla._Deadheader
Framing lumber help
Started by Timster on Sawmills and Milling
Last post September 15, 2016, 07:48:51 PM
by thecfarm
