Author Topic: How to abuse/destroy a perfectly good planer  (Read 1124 times)
Offline pineywoods
« on: September 06, 2017, 10:39:33 PM »
I recently took in a woodmaster 725 single side planer for repair. Owner says it leaves bad marks on the planed surface. A little investigation revealed this sequence of events, things you DO NOT want to do to ANY planer.
1..Planing some 4/4 lumber with severe dives and climbs down to 7/8 in one pass. Thick spots kept hanging on the bar across the infeed, so just removed the bar and lost it. I replaced the missing part with a piece of 2X2 angle iron. It will be cleaned up and painted.
2...Thick boards now don.t hang on the bar, but hard to get them started under the feed rollers, so removed the springs that apply down pressure to the feed rollers  ( and mis-placed them). New ones in the pic
3...Started getting kickbacks and marks on the lumber. Here's why..broken 25 inch planer blades,  NOT cheap..
I did ask, why not just lower the bed a bit and make 2 passes ?  OH, I can't find the crank to lower the bed.. ::)
Offline Darrel
  • Never throw an unopened log on the burn pile.
Re: How to abuse/destroy a perfectly good planer
« Reply #1 on: September 06, 2017, 11:46:59 PM »
Yikes!
If you don't like your planer and it makes you mad, don't tear it apart?  Send it to me, I'll give it a happy home!  8)
1992 LT40HD
Offline DDW_OR
« Reply #2 on: September 07, 2017, 03:04:12 AM »
..........I did ask, why not just lower the bed a bit and make 2 passes ?  OH, I can't find the crank to lower the bed.. ::)
yep, cant fix stupid. :( ::)
Multitek 1610EZ, TimberKing 2000 & Talon Sharpener,
Offline PA_Walnut
« Reply #3 on: September 07, 2017, 05:09:01 AM »
 :D :D :D Some people should not be allowed to have corded tools. I had a Grizzly Tech tell me that he had a dude call about a problem with his 1023 table saw. After diving into the problem, he also discovered that the man wasn't using a blade guard. When he asked him why, he replied that he doesn't use it, "...because I am blind and it gets in the way!".  :o :o
I own my own small piece of the world on an 8 acre plot on the side of a mountain with walnut, hickory, ash and spruce.
LT40HD Wide 35HP Diesel
Baker Portable Edger with Kubota Diesel
Kubota M62 Tractor/Backhoe
WoodMizer KD250 Kiln
Offline Kbeitz
  • Never enough time...
    • My Hobbies
« Reply #4 on: September 07, 2017, 07:32:08 AM »
That's one job I hated working at Grizzly was phone tech talk with someone that has not a clue.
Love machine shop work
and Wood work shop work
And now a saw mill work
Offline sawguy21
« Reply #5 on: September 07, 2017, 11:07:31 AM »
I almost cry when I see something like that, I love good tools. The trouble is the guy likely hasn't learned anything, will continue in his ways and expect future repairs done on warranty for free. I worked on the sales and tech desk for the Ridgid/Ryobi parts distributor, the consumers would phone us and complain when they couldn't get anywhere with the service center. One guy was mad when he couldn't get warranty on a new table saw, a call to the dealer revealed he had changed the plug so he could run it off 240 volts. ::)
Offline sawwood
« Reply #6 on: September 07, 2017, 12:52:48 PM »
I have the Woodmaster 18 for a long time with no trouble. The only thing that i didn't like was the dust collector
would not pull all the chips out. A lot was coming out the in feed side. I talked to Pineywoods and he said i might
try lowering the hood down. I did and A lot, no more chips coming out that side.
Sawwood
Norwood M4 manual mill, Solar Kiln, Woodmaster
18" planer/molder
Offline caveman
  • In the land of the blind the one eyed man is king
« Reply #7 on: September 07, 2017, 12:54:45 PM »
Some of these can be attributed to ID 10T errors.
Offline DDW_OR
« Reply #8 on: September 07, 2017, 01:46:30 PM »
if the 725 is going to be yours i would get the spiral cutter head.
less chatter, tear-out and quieter.
will be getting one for my 725.
Offline Don P
    • Calculator Index
« Reply #9 on: September 07, 2017, 07:56:28 PM »
I bought a planer "that wouldn't plane worth a flip". It was cheap, figured I'd give it a try. Worked pretty good after I turned the knives around  :D.
Offline sawguy21
« Reply #10 on: September 07, 2017, 08:51:03 PM »
 :D :D Now that is funny.
Offline pineywoods
« Reply #11 on: September 07, 2017, 09:08:05 PM »
Don, I've seen that one also. Took the blades out for re-sharp and re-installed them backwards. shoved in a wide ash board and actually cracked the head, letting the blades go loose...
Offline Peter Drouin
    • A&P Saw mill LLC
« Reply #12 on: September 07, 2017, 09:09:33 PM »
2008 LT40 super,2008 edger, Cat telahandler, JD 5410 And can cut up to 45' long
http://www.forestryforum.com/sanbornton     NH Timberland Owners Association supporter.
And a license NH soft wood grader.
Sawing since 1987
Offline coxy
« Reply #13 on: September 08, 2017, 06:45:45 AM »
but but if it wasn't for us stooped people some of you would be out of business  :D :-X
Offline MikeON
« Reply #14 on: September 08, 2017, 07:12:14 AM »
Sawwood
I also have a 718.  I took the cover off and made one of plywood, with the dust port relocated on the infeed side instead of on top.  This put the port where the chips were going anyway.  Reduced the escaping chips by about 95%.  I plan to modify the original cover and re-install it when time permits.
The original design had the chips bouncing off the inside front of the cover and scattering all directions, with some percentage being collected by the dust port.
Woodmizer LT40HD Super.  WM Single Blade Edger,  John Deere 4310 tractor, M35A2C Deuce and a Half truck
Old, Good planer
Started by tyb525 on Wanted
Last post November 27, 2008, 08:57:56 PM
by tyb525
Return product abuse
Started by Ford_man on Chainsaws
Last post October 04, 2014, 11:09:03 PM
by sawguy21
Perfectly square cants from an early -Mizer?
Started by musikwerke on Sawmills and Milling
Last post August 16, 2007, 12:19:10 PM
by sparks
this blade just keeps cutting wood metal mud abuse
Started by buildthisfixthat on Sawmills and Milling
Last post December 19, 2011, 01:11:07 AM
by redbeard
