EZ Boardwalk Sawmills. More Saw For Less Money! sponsored by Northeast STIHL
Author Topic: Solar kiln interior paint?  (Read 341 times)
Offline vfauto
  • TimberKing 2000
« on: September 07, 2017, 07:27:08 AM »
What is everyone using to paint the interior of a solar kiln? I tried a black roofing coating but it gets soft when heated.
The definition of insanity is to do the same things over and over and expect a different result!
Offline btulloh
Re: Solar kiln interior paint?
« Reply #1 on: September 07, 2017, 08:22:31 AM »
I had the same question.  It comes down to this:  If you have a vapor barrier in your interior wall, you can use an exterior latex paint.  If you don't, you use the roof coating.  If you want to get fancy you can use an elastomeric paint.
When I was trying to sort this out I caught by the timing and the need to get the painting done.  I ended up using Blackjack Fibered Roofing and Foundation coating even though I had plenty of vapor barrier.  Asphalt based stuff.  It actually worked ok, but it does stay soft, but not as bad as the regular roof coating.  It dries pretty fast, but of course it's always going to be a little soft in the heat.  It's ok, and I guess I'm really sealed up, but it would have been much easier to use the acrylic latex.  I did use the latex on some of the misc. items on the inside.  It all got black and it all works.  With a latex of course you need to prime and you need two top coats, so there's that.  The foundation sealer went on well and adheres well.  No primer and no second coat was needed.
That was my experience.  I hope that helps.
I'm really enjoying watching your build and like the way you framed your kiln.  Too bad you didn't go first so I could have incorporated some of your design.
Keep us posted.
Offline GeneWengert-WoodDoc
« Reply #2 on: September 07, 2017, 02:49:52 PM »
I suggest flat black exterior latex. It is not too expensive and two coats will survive for at leAst five years. Plus you can rub against it without damaging clothes. For longer lasting, use an aluminum paint as the first coat.
Online Kbeitz
  • Never enough time...
    • My Hobbies
« Reply #3 on: September 14, 2017, 08:33:34 AM »
It wont get soft if mixed with about 1/8th diesel. It will soaks right in the wood and dry.
Love machine shop work
and Wood work shop work
And now a saw mill work
