Author Topic: Used a new (to me) tool today  (Read 1889 times)
Offline starmac
« on: September 09, 2017, 02:07:26 AM »
My son has a skill saw for steel that I used today, doing a little fab work on the log truck.
It is supposedly rated to cut 3/4 mild steel, I needed to make 2 6 foot cuts in a piece of I beam and didn't want to use a torch, so used his saw.
I looked at the blade and it is no heavier and resembles a regular wood blade. He is down south of Houston and I could not get a hold of him to ask if he had put a wood blade on it.
I wasn't keen on sticking this blade in 3/8 steel, so I went to the industrial hardware store that sells these things and checked out the blades, they resemble a regular carbide tipped blade, so I let her rip. lol
I made 12 foot of cut in 3/8 mild steel slick as a whistle.
I took it real slow, not knowing how fast a guy should push it, but cut straighter cuts than I can on plywood, probably because I went so slow.
A plasma cutter would have been faster, but mine tanked a year or so back and I have not got around to replacing it.
Offline ljohnsaw
Re: Used a new (to me) tool today
« Reply #1 on: September 09, 2017, 02:27:10 AM »
What brand is it?  How big is the blade?  I'm tired of using the abrasive cut wheels.
John Sawicky
SkyTrak 9038, Davis Little Monster backhoe, Case 16+4 Trencher, Home Built 38" cut Bandmill up to 54' - using it all to build a timber frame cabin.
Offline coxy
« Reply #2 on: September 09, 2017, 07:28:22 AM »
they are neat   I watched my buddy use one a years or so ago  he clamps 2 pieces of straight bar to the piece hes cutting just wide enough for the saw to keep his lines straight  the blades he uses he says he can cut up a 4x8 sheet of 1/2in in 3in wide strips on one blade  :-\
Offline 21incher
« Reply #3 on: September 09, 2017, 08:46:26 AM »
The saws usually turn at a much lower rpm then a wood cutting saw. I just bought one of the low speed dry cut 14 inch saws that uses a similar blade and love it. Cuts steel like butter with no heat. :)
Hudson HFE-21 on a custom trailer, Deere 4100, Kubota BX 2360, Echo CS590 & CS310, home built wood splitter, home built log arch, and a Logrite cant hook.
Offline Dakota
  • Swing'en in South Dakota
« Reply #4 on: September 09, 2017, 09:12:48 AM »
Great video, as usual.
Dave Rinker
Offline Magicman
  • A "Traveling Man"
    • Knothole Sawmill
« Reply #5 on: September 09, 2017, 09:27:19 AM »
Wow, what a tool and thank you 21incher for yet another very detailed and informative video.   smiley_thumbsup
Offline ljohnsaw
« Reply #6 on: September 09, 2017, 11:46:23 AM »
What a great saw.  I re-purposed a 10" wood miter saw with a abrasive blade to cut steel.  Works ok but gets hot and the sparks fly!  What did this saw cost from Northern Hydraulics?
John Sawicky
Offline Kbeitz
  • Never enough time...
    • My Hobbies
« Reply #7 on: September 09, 2017, 12:06:44 PM »
I used one at work. I did not like it. Hot chips down the shirt just don't cut it.
I go through over 100 cut off wheels a year.
Love machine shop work
and Wood work shop work
And now a saw mill work
Offline starmac
« Reply #8 on: September 09, 2017, 12:33:33 PM »
The one I used was not a cutoff saw, but more like a skill saw. It catches its own chips and you take the heavy duty guard off to empty them.
It is a Milwaukee 8 in saw, I do not see it replacing a cut off saw at all, but when you have long cuts or wider than a 14 in cutoff wheel will handle it is handy. In my opinion a good plasma cutter would be used more than this saw, but then again for some things this would be the berrys. The blades push a hundred bucks here for it though, not sure how long they last.
Offline 21incher
« Reply #9 on: September 09, 2017, 12:58:47 PM »
It was about  $230.00 shipped . The blade alone is a hundred bucks and is only rated for steel. They are not resharpenable so I am waiting to see how long it lasts. There are different blades for stainless and aluminum.
I have a Evolution rage 3 being shipped to me to test that is basically a low speed sliding 10 inch miter saw rated for wood, plastic, steel, & aluminum that I am looking forward to trying. No sparks or heat with these saws, just small chips that I am going to try and collect with a magnetic in the future.
I was just trying to show how they cut with no lube and create no heat.  You are right about plasma. I can cut 500 feet of 1/4 inch steel with $12.00 worth of consumables. :)
Offline Crusarius
  • Lost in....
    • RockModified.com
« Reply #10 on: September 12, 2017, 12:42:54 PM »
I recently bought a sawblade.com saw. It works great but as Kbeitz said the hot metal chips all over the place is terrible and quite painful. I am planning on building an enclosure for mine to avoid the flying chips.
On a real positive note I am cutting 2x6x3/16 for my sawmill build and it cuts very fast and smooth. After you make the cut you can grab both pieces bare handed and they are still cold to the touch. The chips on the other hand... watch out they freaking hurt alot!
I knew what I thought I meant.
Offline DeerMeadowFarm
« Reply #11 on: September 12, 2017, 02:21:39 PM »
I bought a small diesel engine from a guy off CL. He had one of those steel cutting skilsaws. Very impressive! He let me try it on some 1/2" plate. It didn't cut like plywood but it cut MUCH faster than anything else I've used.
Here's a relatively cheap one:
https://www.houzz.com/photos/76589549/Evolution-Rageb-Multipurpose-Cutting-Circular-Saw-power-tools
Offline btulloh
« Reply #12 on: September 12, 2017, 08:13:59 PM »
Good info.  I gotta me one of those.  Or both of those actually.  It sounds like managing the hot chips is the key to happy cutting.
HM126
Offline starmac
« Reply #13 on: September 12, 2017, 08:32:00 PM »
Like I said, the saw I used threw no hot, or any other chips. It catches the chips and you remove the guard to dump them. I did have water trickling on it, maybe that contained them.
I went slow, not really sure how fast a guy could go. It was much slower than a plasma cutter or torch, but a lot cleaner than what I can do with a torch.
Offline Crusarius
  • Lost in....
    • RockModified.com
« Reply #14 on: September 12, 2017, 08:35:41 PM »
My saw is probably 10 times faster than the bandsaw with 18 tpi blade. Cuts a little smoother to.
Offline Corley5
  • Wolverine, Michigan
    • Whittaker Farms
« Reply #15 on: September 12, 2017, 08:37:38 PM »
A friend has the corded Milwaukee skilsaw metal saw.  It rocks!!!  They also make them in a cordless M18 version which has been added to my short list ;D
Offline ljohnsaw
« Reply #16 on: September 12, 2017, 08:40:18 PM »
DeWalt has a cordless (20v) 6-1/4" metal cutting circular saw.  Has anyone tried that one yet?  It is a dry cut saw, but don't know if it a cold cut.
John Sawicky
Offline 21incher
« Reply #17 on: September 12, 2017, 09:33:10 PM »
I really don't get hit by many chips with my saw. The problem is more they get stuck in my shoe soles and get tracked in the house. I plan on mounting one of the magnetic shafts on it in the future to see if I can catch them all. This is what the chlp collection magnets look like. http://www.evolutionpowertools.com/us/group/cyclone.php
Offline Kbeitz
    • My Hobbies
« Reply #18 on: September 12, 2017, 09:50:17 PM »
I use a Bingo chip collector. It's made to pick up Binge chips off the Bingo boards.
« Reply #19 on: September 13, 2017, 08:10:07 AM »
The one I tried was also this way. Open the guard and dump the chips. Pretty cool I thought.
Pre-Order your Log Rite Fireplace Tool Kit Today!
Started by 4x4American on LogRite Tools and Rite Leg Co
Last post December 19, 2016, 10:33:23 AM
by Tam-i-am
Tractor 3pt Multi-tool - And Another Log Handling Tool Added
Started by tcsmpsi on General Board
Last post February 08, 2007, 07:18:52 PM
by SPIKER
Tool Box
Started by bill m on Technical Support Topics
Last post November 08, 2014, 08:05:06 AM
by Jeff
My New Toy...I Mean Tool!!!
Started by Shawn on Sawmills and Milling
Last post August 11, 2006, 08:43:42 AM
by den
