Author Topic: Central boiler 1400 air channels  (Read 3443 times)
Offline overclocking
Re: Central boiler 1400 air channels
« Reply #40 on: November 30, 2017, 08:37:06 AM »
Well it's been a few more weeks and all is well. I'm pulling 24 hour burns since the channel install. The gasification channel still seems low, but it's idling at 190 almost all the time and when it needs heat it seems to stay right around the set point. I would say the channels are working pretty good so far. I removed them last weekend and they came right out and went back in just fine once I located the bolts under the build up. Overall I seem to have made a great improvement to the original design.
Offline DeerMeadowFarm
« Reply #41 on: November 30, 2017, 10:39:12 AM »
Been a few weeks for me now. Plates are great, no warping to date. My boiler (sound of me knocking on wood over here) seems to be working better than ever. My heat is good, I'm getting good burn and I seem to be using a lot less wood so far. Time will tell....
« Reply #42 on: January 07, 2018, 07:42:41 PM »
Just another update. Turns out the angle iron I put on the plates as a means of stopping it from warping serves more than one purpose. It keeps the wood away from blocking the channels, makes the "sap" run away from the holes and acts like a rail for me to run the coal rake up and down to kick the coals away from the bottom channels.
I let the coal bed get way too high last week and all the bottom holes got filled with ash and coals. I was dreading pulling the plates off because it was so cold out. So I opened the back panel and removed the upper solenoid and clamped my leaf blower in it and revved it up. When I walked back around front after the dust settle I was completely astonished to see the channels were 100% cleaned out and back to full flow! Turned out to be a ten minute channel cleaning.
So at this point I am going to have to call this back yard fab job a huge success. Its been running the best it has ran since I installed it and the removable plate certainly are exceeding my expectations.
« Reply #43 on: January 08, 2018, 08:15:45 AM »
Excellent! So you put your angles on the firebox side? I put mine inside the channel. I had one end pull away slightly, not warped but I must have hit my slide bolt at some point. Creosote is getting in there slightly but it hasn't caused an issue to this point. I haven't wanted to shut it down to put it back on correctly due to this cold weather. I'm very happy so far with my repair!
Offline Roger2561
  • Love the outdoors
« Reply #44 on: January 08, 2018, 12:17:24 PM »
overclocking, DeerMeadowFarm - Thanks for posting the updates following this cold snap we experienced.  I've been waiting to hear from you guys to see how they are doing for you.  This gives me ideas to try next summer when I fix mine.  Roger
« Reply #45 on: February 19, 2019, 07:44:04 PM »
Old thread here but I just wanted to give an update.
I slacked for a long time on cleaning the air channels and finally after over a year pulled the plates out due to restricted flow. I cleaned out the channels and haven't reinstalled them yet. The bolts came right out no problem after over a year and I could have put the plates back in but haven't yet because I have to clean the back corners out.
Also, the entire center section in the bottom reaction chamber is failing. The metal is gone where the crescent shaped hole is in the bottom. So I need to replace that as well. Once the heating season ends I'm going to make new plates with thicker stainless because it did eventually warp.  Or I might just buy a new boiler, I'm not sure yet. This one has about 6 seasons on it now and heats my house pretty good, and although its been good its also been a lot of extra work compared to the newer models.
Central Boiler Eclassic 1400
Started by holder73 on Firewood and Wood Heating
Last post April 01, 2013, 08:34:35 PM
by Ohiowood
Central Boiler E-Classic 1400 - opinions please
Started by Dean186 on Firewood and Wood Heating
Last post December 10, 2010, 09:35:58 PM
by Guitarjunkie37
Central Boiler E Classic 2400 / 1400 Creosote Problem
Started by ParadisePA on Firewood and Wood Heating
Last post April 02, 2013, 09:48:27 AM
by Logging logginglogging
Central Boiler E Classic 1400 Water Temp Issues
Started by tmills1288 on Firewood and Wood Heating
Last post February 19, 2019, 08:22:58 PM
by overclocking
