Author Topic: Tractor tire chains on a timberjack???  (Read 990 times)
Offline dustyhat
« on: September 13, 2017, 12:32:06 PM »
We got a little 225 E skidder thats in need of some traction help the tires have a good 50% tread but its needing help, regular chains that we tryed were bear claws and the side chain hits and rubs on the blade cylinders same in the back,dont want to modify the wheels, so have any of you guys had luck with tractor chains on a skidder, being smaller chain diameter, i was just wondering if they would hold up besides the tractor chain is alot cheaper.
Running a custom built stationary bandmill with a slightly modded four cyl jeep go devil engine.
Offline Bert
Re: Tractor tire chains on a timberjack???
« Reply #1 on: September 13, 2017, 05:46:58 PM »
Im sure they would last a while. Id be willing to try it if I needed chains. I know a guy that put ring chains on a jack and they scratched the cylinder each time around until it blew. For some reason, mine clear fine. Might be cheaper to torch the edges down to clear them if you already have the chain-or replace just the side chains with a smaller diameter chain.
Saw you tomorrow!
Offline Maine372
« Reply #2 on: September 13, 2017, 07:49:37 PM »
can you swap wheels side to side? maybe the wheels are like tractor wheels and you can swap them to adjust your width?
Offline Spartan
« Reply #3 on: September 13, 2017, 11:40:30 PM »
thats what I was going to suggest, wheels might be reversible.
In my chain experience, you probably wont be happy with tractor style chains, unless you are maybe just plowing snow on roads.
They are cheaper for a reason, lower grade steel, less coverage of tire, etc...
You need HARD chain, or they will wear, stretch and break way too easy.  you also need some kind of cleat or stud on them.  Get on any kind of a hill with any debris and snow and you'll be finding a way to get the bear paws back on.
even skidder chain with cleats wore down to just chain links can get you stuck on something as simple as a 4" green downed tree.  You'll just sit and spin on it and eventually dig holes on any kind of slope, and thats without ice.
If your skidding logs, I recommend you fix the problem so you can get some decent chains on.
Offline Neilo
« Reply #4 on: September 14, 2017, 01:40:00 AM »
Most timberjack wheels are reversible. Take off one wheel nut and look for the taper on the inside of the rim. Might need a needle or similar to feel if the steel of the rim goes all the way to the hub.
Offline coxy
« Reply #5 on: September 14, 2017, 09:06:05 PM »
my buddy has a 225e also and did the same thing rubbed he went to a 1/2in trigg studded chain and works great now    the chains have been on there 5 years BUT HE MOSTLY ONLY LOGS IN THE WINTER and the chains are about 1/2 or a little more worn down
Offline Maine logger88
  • Don't force it get a bigger hammer
« Reply #6 on: September 14, 2017, 09:24:18 PM »
I had ring chains with 5/8 side chain that rubbed on my blade cylinders when I got new chains I bought Canadian brand chains with 9/16 diamonds but 1/2 inch side chain and they don't rub. Got around 300 hours on them and still look new
Offline coxy
« Reply #7 on: September 14, 2017, 09:33:23 PM »
do you have a name for the chains I was looking for 9/16 side chain and 5/8 stud  and was told they don't make the studs bigger than the side chain only side chain bigger than stud
« Reply #8 on: September 14, 2017, 10:23:14 PM »
Yeah I have a set of babecs on my 540 that have 5/8 stud and 9/16 side chain on my 540. The ones on my 225 are Canadian brand. They are both made here in Maine about an hour from my house. I can get some contact info if you would like. To me it makes sense cause the studs are what wears you never wear out side chain
Online barbender
« Reply #9 on: September 15, 2017, 08:57:31 AM »
I don't have much experience with skidder chains, but I can speak from experience in forwarders. We have always ran whatever Ponsse supplies on the machines, and they're not much. They stretch quickly, and you have to keep a close eye on them- they'll slide around on the tire and sometimes come into contact with the axle and cut it. Not good. We tried a set of Nordic brand chains, and what a difference. They were a heavier guage, they're through hardened and guaranteed not to stretch for 5000 hours after the initial break in. They were so heavy we had to put them on using the same method as tracks (they weigh 500 pounds a piece), the other brand you could just lift on. If I was looking at chains that I wanted to last, I'd be looking at Nordics.
Offline Corley5
  • Wolverine, Michigan
    • Whittaker Farms
« Reply #10 on: September 15, 2017, 10:32:22 AM »
I ran grader/heavy truck chains for a while on the Iron Mule I had.  They were 3/8".  They worked but had to be kept REALLY tight or the cross links would fall in between the tread bars.
Online Crusarius
  • Lost in....
    • RockModified.com
« Reply #11 on: September 15, 2017, 10:45:01 AM »
Is it possible to build a sacrificial guard over the ram instead of changing the chains? wouldn't take much to form a couple layers of 1/8" over it with light welds or even bolt on. Then as 1 layer wears replace it. the good news is with multiple layers it won't need to be attended to immediately when it does wear through.
I am assuming its only intermittent touching of the ram not constant?
I knew what I thought I meant.
« Reply #12 on: September 15, 2017, 09:44:01 PM »
With 5/8 side chain on my 225 it was consistent I'm not sure as you could get another 1/8 in there
Offline coxy
« Reply #13 on: September 16, 2017, 11:37:44 AM »
 it will rub till the oil comes out then there's a big mess  :D
Tractor tire chains
Started by mr T on Forestry and Logging
Last post October 26, 2010, 09:06:49 PM
by John Mc
Tractor tire chains
Started by crazy4saws on Forestry and Logging
Last post December 25, 2017, 08:32:43 AM
by g_man
tractor tire chains
Started by brandonward6 on Forestry and Logging
Last post February 04, 2015, 06:46:40 PM
by wfcjr
Compact Tractor Tire Chains?
Started by John Mc on Forestry and Logging
Last post November 15, 2017, 04:08:51 PM
by John Mc
