Arborwear
Author Topic: placement and dimensions of Bladed scarf joint  (Read 389 times)
Offline windfall
« on: September 13, 2017, 12:42:28 PM »
Hello...I have noticed many pictures of Bladed Scarf joints, in a continuos  plate, placed directly over a post.  Do the rules of placement not apply to this type of joint?  I was basing this upon reading placement of most joints, such as, wedged scarf joint, should be supported by the brace and not set directly upon the post. Does this hold true with the Bladed Scarf as well?
Thankyou again!
Offline windfall
Re: placement and dimensions of Bladed scarf joint
« Reply #1 on: September 13, 2017, 12:44:58 PM »
oops... forgot the other question.  If using an 8x10 for a plate, Ive seen ratios for other scarf joints, dimensions.  What is the depth to length ratio of the Bladed Scarf joint?
Offline Jim_Rogers
  • Board Moderator
  • Keep your chisels sharp.
    • jrsawmill.com
« Reply #2 on: September 14, 2017, 11:32:17 AM »
Personally, I don't think any scarf joint should be located over a post. Again, as I have said before, you're asking the timbers to be as strong as they can be (at the post) and then you cut them in half. How can they be as strong as they can be if you cut them in half?
I feel you should locate all scarfs off to the side of a post. Unless an engineer tells you it's ok.
To make it easy to layout you could just do each blade 2" so that you can use a framing square for marking the lines and checking the mortises. And start at the top and do four 2" offsets, and whatever is left over go to the bottom.
Jim Rogers
Offline windfall
« Reply #3 on: September 14, 2017, 11:52:48 AM »
Thankyou Jim,
Interesting to note how many bladed scarf joints are over posts and, I've rarely seen any wedged scarfs over posts?  I understand why they should not be placed over the post. The graph showing the forces on the plates you posted a while ago explains it all!  Thanks again.
Bladed scarf joint questions
Started by Jim_Rogers on Timber Framing/Log construction
Last post June 10, 2017, 01:04:08 PM
by Jim_Rogers
Cutting a bladed scarf joint
Started by jph on Timber Framing/Log construction
Last post January 27, 2006, 07:24:37 PM
by Jim_Rogers
Post extension using the bladed scarf joint.
Started by Remle on Timber Framing/Log construction
Last post October 22, 2014, 08:34:06 PM
by Remle
Bladed scarf joint videos for sale
Started by Jim_Rogers on For Sale
Last post May 06, 2014, 09:25:23 AM
by Jim_Rogers
