Author Topic: Pulling the trigger on a new processor this week.  (Read 5555 times)
Offline jimbarry
    • WoodchuckCanuck
Re: Pulling the trigger on a new processor this week.
« Reply #40 on: January 18, 2019, 06:15:48 AM »
I bought a Bell 1000 processor (the one shown on their web site) Sent a long time researching. Could not be happier. Also have demoed it to others. ( i love to) Do about 30 bush cords now a year. As to sharpening; very little and not sure why. It stays sharp way longer than a chain saw??? Maybe more oil on the bar. Bought a load of maple in June last year. Logs were real muddy ( won't do that again) Figured I'd be destroying chains but still on original chain with miner touch ups. As far as customer support I still can't believe how well I've been treated.
TinHorse, do you have time to update your experience with the Bell 1000. I've been looking at one myself.
Jim
2017 Nyle L200
8ft x 10 ft x 20ft bldg
3.5-4" 2lb closed cell spray foam, Demilec brand HeatLok Soya Spray Polyurethane Foam Insulation
Offline Tin Horse
« Reply #41 on: January 18, 2019, 09:58:35 AM »
Working a load of firewood right now. Normally I'm cutting logs off my own property but because of lumber order s and a shop this year I've fallen behind on cutting. So I just had a load of logs delivered 2 days ago. My own logs are cut at about 12' length. They fit the processor well. The purchased load ranges from 16'6" to 19'. A little long for the trough. For now I've just set a lift of pallets at the end and gives enough support. Not the best solution but works. I may also just cut the logs in half. But that increases feed time. I'll build something this year to improve.
It was -15 C yesterday. Sitting about a month and fired right up. I'm still amazed a what it can pull through it. Some of the purchased stuff is pretty rough. This machine is built solid. No complaints.
Let me know if I can help.
Mike.
Bell 1000 Wood Processor. Enercraft 30HTL, Case 580SL. Kioti 7320.
pulling trigger on OWB
Started by mf40diesel on Firewood and Wood Heating
Last post September 11, 2016, 05:58:26 AM
by Roger2561
new processor coming next week
Started by cutter88 on Firewood and Wood Heating
Last post September 18, 2016, 04:21:16 PM
by firefighter
Processor Build, Home Made Firewood Processor
Started by Higgo on Firewood and Wood Heating
Last post September 17, 2018, 08:52:41 PM
by hedgerow
Leveling processor vs standard track processor
Started by quilbilly on Forestry and Logging
Last post December 23, 2017, 12:46:21 PM
by Skeans1
