KNOW WHAT?
Between February 12, 2018 and June 18, 2018, this space displayed 13 Million, 871 Thousand and 87 times.
BRUTE FORCE Authorized Dealer
Council Tool
Author Topic: peg location  (Read 450 times)
Offline Momatt
peg location
« on: October 09, 2017, 11:57:11 AM »
Is the ideal location for a peg centered on the tennon?  I was pegging some  6x6 together and  decided to cheat to the bottom of the tennon to maximize the relish.  I also noted that a 3 inch tennon looks kind of short when you are using a one inch peg.
Offline Don P
    • Calculator Index
Re: peg location
« Reply #1 on: October 09, 2017, 01:39:59 PM »
Generally down low, near the bearing. Think about shrinkage, you would usually prefer not to hang things off of pegs so normally you would put the peg relatively close to the bearing face. Edge and end distances would be the same as if you were using a steel dowel at the same load.
Offline LeeB
Re: peg location
« Reply #2 on: October 10, 2017, 02:11:54 AM »
Don,
I assume this would apply to just about any tenon no matter the orientation? The peg would pretty much always be best placed near the base of the tenon?
Offline Don P
    • Calculator Index
Re: peg location
« Reply #3 on: October 10, 2017, 08:30:04 AM »
Actually applies to any connector, if you look at the glulam guidelines they say the same thing about bolts and brackets.
Offline canopy
Re: peg location
« Reply #4 on: October 10, 2017, 08:22:54 PM »
For 6x6 timbers, 1" pegs are not standard. The standard is intended to balance the strength of all parts of the joint so that there are no weak spots. For a 6x6, the standard is 3/4" pegs in a tenon that is 3" tall, 1.5" thick, and peg placed 1.5" off the bearing surface.  For longer pockets (7-10") 2 pegs are used. For longer than 10" 3 pegs, still 3/4" each. There are exceptions. For a tension joint an engineer may specify 1" pegs matched with extra long tenons. But the important thing is you don't just beef up one thing because even though you strengthen that one thing, you can often end up taking away strength from the other parts making the joint weaker rather than stronger.
Hitch vs Drag- Skid trail vs Twitch rd....Location Location Location
Started by riverlogger on Forestry and Logging
Last post February 23, 2014, 11:47:13 AM
by Rick Alger
Location,Locatiion,Location
Last post March 09, 2005, 01:02:39 PM
by SwampDonkey
location
Started by ksu_chainsaw on General Board
Last post March 21, 2004, 07:53:32 AM
by Kevin_H.
Location , Location
Started by sprucebunny on General Board
Last post February 02, 2005, 05:07:02 AM
by Jeff
