TURBOSAWMILL GIANT SALE ON NOW UNTIL OCTOBER 31st
BRUTE FORCE Authorized Dealer
Council Tool
Author Topic: Using hydraulic motor for Log stops  (Read 1719 times)
Offline Rickcnc
« on: October 12, 2017, 06:38:50 AM »
I am considering using a hydraulic motor to raise and lower log stops as will an additional motor to move a log clamp. I値l use a cylinder to raise and lower the clamp.. My thinking is the motor will give me more travel for the clamp.
Has anyone else build their own stops and clamps this way ? I noticed the timberking 2000 appears to be set up like this.
Looking for your feedback on the idea and some input on what size of motors I would need.
Offline redprospector
Re: Using hydraulic motor for Log stops
« Reply #1 on: October 13, 2017, 01:15:02 AM »
I tried a hydraulic motor for the dog on the mill I built. It would back off on big logs. A motor's not made to hold like a cylinder is. My 2 cents.
1996 Timber King B-20 with 14' extension, Morgan Mini Scragg Mill, Fastline Band Scragg Mill (project), 1973 JD 440-b skidder, 2008 Bobcat T-320 with buckets, grapple, auger, Tushogg mulching head, etc., 2006 Fecon FTX-90L with Bull Hog 74SS head, 1994 Vermeer 1250 BC Chipper. A bunch of chainsaws.
Offline Satamax
  • Location: South eastern alps, in France but right on the italian border.
« Reply #2 on: October 13, 2017, 04:05:44 AM »
Rick.
For the log stops, i think a cylinder would work ok. You can have plenty of travel. If it's for log dogs/clamps I used old vertical sawmill parts, and modified these into horizontal ones, using three phase worm gear electrical motors.
http://www.forestryforum.com/board/index.php/topic,85066.80.html
If you are not mobile. Use electricity, it's far less hassle.
French CD4 sawmill. Latil TL 73. Self moving hydraulic crane. Iveco daily 4x4 lwb.
Offline ladylake
« Reply #3 on: October 13, 2017, 05:35:41 AM »
 Yes TK uses a hyd motor to raise and lower the vertical stops and it works just fine, doesn't need much holding power for the log stops. Almost any motor should have enough power, I'd get a slower rpm one as you don't want the going up or down really fast.  Steve
Timberking B20 12000 hours +  Case75xt grapple + forks+8" snow bucket + dirt bucket   770 Oliver   Lots(too many) of chainsaws, Like the Echo saws and the Stihl and Husky     W5  Case loader   1  trailers  Wright sharpener     Dino setter Volvo MCT125c skid loader
Offline bandmiller2
« Reply #4 on: October 13, 2017, 03:57:37 PM »
Hydraulic motors are expensive seems like a waste when a simple small cylinder could do the same job. My bandmill has two stops tied together that swing up from a handle in the front of the mill. Its simple and they are 12" high but they can be lowered for smaller logs. Save the motor for a chain turner or cable feed. Frank C.
Offline ladylake
« Reply #5 on: October 14, 2017, 05:34:24 AM »
 If using swing up stops which I don't like a hyd cylinder would work well and be easy.  With vertical stops a hyd motor would be a lot simpler and they can be bought for around $100 or less, not that much more than a cylinder.  Steve
Offline dean herring
« Reply #6 on: December 26, 2017, 12:22:12 PM »
Anyone know if Timberking has "factory made" vertical hydraulic log stops and log clamp for a TK 1600? They would surely be a time saver
Failure is not an option  3D Lumber
Offline Chaser357
« Reply #7 on: December 26, 2017, 04:59:00 PM »
My TK 1600 has a hydraulic log clamp.  The back and forth is hydraulic but the up and down is manual.  I wish they did make a retrofit hydraulic log stop kit for the 1600.   The manual log stops swing forward and are impossible to keep adjusted.   I'm thinking about getting mine straight and welding them.
Offline JB Griffin
« Reply #8 on: December 26, 2017, 06:57:08 PM »
Also it would only take one hyd. motor to run all the backstops, whereas you would need a cyl. for each stop or a complicated linkage system.
2000 LT40hyd remote 33hp Kubota, 160 Prentice, Frick 2 saw gang edger, Wright W-37 ABG, Suffolk dual tooth setter, Cat claw single tooth setter,'96 F-250 7.3 PSD 4x4, CS-590 Echo, MF 20c, M681 Memo.
Over 2 million bdft sawn with a Baker Dominator and counting.
« Reply #9 on: December 26, 2017, 07:21:48 PM »
Same problem here, the log stops are definitely a weak link.
« Reply #10 on: December 26, 2017, 07:58:29 PM »
Was looking at the TK 2000 on the website. It has vertical stops. Would it be possible to put them on a 1600?
Offline DPatton
« Reply #11 on: December 26, 2017, 09:14:24 PM »
I知 certain that if you call TK they will have an answer to your question. They are a great company with really good people that know their equipment inside and out. If it痴 doable they will know and will have likely done it before. You should give them a call at their number on the left side of this page.
« Reply #12 on: December 27, 2017, 08:37:57 PM »
Will do
Just as soon as we get over Christmas and our son getting married this too
Offline bozzaa69
  • not new anymore
« Reply #13 on: January 12, 2018, 06:14:23 PM »
I got 1, High torgue, low rpm hyd. motor that runs a driveshaft, that makes my 4 log stops go up and down. Home made, no problems in years. Can get the motors for $99 if you shop right. Pics in my gallery.
Offline bozzaa69
  • not new anymore
« Reply #14 on: January 12, 2018, 06:20:16 PM »
I got 6 of the same hyd. motors on my home made made mill. 1 each for 2 log dogs clamp/unclamp. 1 for 4 log stops up/down. 1 for head carriage feed. 1 for saw head up/down. 1 cylinder each for 2 log dogs up/down. 1 motor, and 1 cylinder for chain Log turner.
hydraulic log stops
Started by dean herring on Wanted
Last post March 28, 2016, 10:40:32 AM
by TractorBoy78
Hydraulic log stops
Started by reswire on Sawmills and Milling
Last post February 20, 2016, 08:36:28 AM
by dean herring
adding hydraulic log stops
Started by dean herring on Sawmills and Milling
Last post February 15, 2016, 09:16:59 PM
by dean herring
Hydraulic Motor
Started by chance33 on Firewood and Wood Heating
Last post April 13, 2015, 10:20:02 PM
by chance33
