Arborwear
Author Topic: This Dang Peterson  (Read 5220 times)
Offline Qweaver
  • The cabin is done and we love it
This Dang Peterson
« on: October 13, 2017, 01:25:29 PM »
I have worked for three days trying to get this WPF 10 to saw correctly.  I have gone thru the setup according to the manual and video.  Re-tipped the blades.  I'm at my wits end.  I would gladly pay someone  $500 plus transport to come and make this saw cut as it should.  As I was re-tipping the blade I noticed that the tips appeared to have very little relief.  The manual does not address this but I am considering grinding a little more back angle on the tips and see if that helps.  I've got a huge red oak to saw and I can just not do it under the current setup.  BTW this saw has always been difficult to work. Always. I know it must be something that I am doing wrong---but dang if I can figure out what?
Quinton
Offline scsmith42
    • Whispering Pines Farm
Re: This Dang Peterson
« Reply #1 on: October 13, 2017, 02:54:39 PM »
Quinton, I'll give you a call one evening soon.
Scott
Tom's 3638D Baker band mill
Offline drobertson
« Reply #2 on: October 13, 2017, 02:56:30 PM »
Hold tight, I'm sure so help is on the way, either by post,, hope so for the rest of us, or by a pm,, peterson and lucas are very similar and there are a few users here,
Offline ButchC
« Reply #3 on: October 13, 2017, 02:58:21 PM »
Something is seriously wrong because sawing good lumber quickly on mine is as easy as falling down and it's  the first mill I have ever run. Certainly no expert here but might help if we knew what is is doing wrong other than "not sawing correctly" that's a pretty broad statement.  Can you post pictures of the blade tips so  I can compare them to my new blade?
Peterson JP swing mill
Morbark chipper
Shop built firewood processor
Case W11B
Offline scsmith42
« Reply #4 on: October 13, 2017, 03:09:29 PM »
Quinton, here is how the tips look on two of my blades.
  [/img]
Offline Savannahdan
  • Retired.
« Reply #5 on: October 13, 2017, 05:06:20 PM »
I feel for you.  I've been trying to get some logs cut and have been fighting rainy weather.  I also had the gremlin climb onboard my mill and moved the brake lever while I was half way through an oak log.  Thought the system had gone totally bad on me.  On one hand it's something sort of simple but on the other it sure messes with your cutting.  I'm sure there's someone close to you that can help.  If the wife didn't have some health issues I'd offer to work with you to resolve the problem(s).  Good luck.
Husqvarna 3120XP, Makita DCS7901 Chainsaw, 30" & 56" Granberg Chain Saw Mill, Logosol M8 Farmers Mill
Offline Qweaver
« Reply #6 on: October 13, 2017, 05:22:01 PM »
Hey Scott, sorry about the mis-name.  Many years(and old age) dull the memory.  As I suspected when I grinded a little more relief on the tips the saw began cutting much better.  Thanks for the pics.  I have the saw set up as close to the manual as I can get.  Crosshatch and lean in are near perfect and I think it is cutting well enough to do this big oak now...not perfect but pretty good.  Still harder to push than the saw I saw working in Pa. this summer.   I have not been using water while doing this setup but will use in on the oak job.  Do you have my number?
Offline shenandoahsawmill
« Reply #7 on: October 13, 2017, 05:42:47 PM »
Quinton; Where are you located? I am near Winchester, Va. and might be able to help if you are not more than a couple hrs. drive. I ran a Peterson WPF for a few years and came up with a sharpener that works better than OEM. Gary
Offline Qweaver
« Reply #8 on: October 13, 2017, 07:25:39 PM »
Hi Gary, we are about 3 hours from  Winchester, Va.  I'd sure be interested in better sharpener and help with my mill.
Quinton
« Reply #9 on: October 13, 2017, 09:24:18 PM »
Quinton; Call me if you want to talk over  details. 540-686-0351 Gary
Offline MbfVA
    • Tanglewood Ordinary Country Restaurant
« Reply #10 on: October 13, 2017, 10:12:40 PM »
 Peterson sent me something about a new sharpener they have, though it looks similar to the old one.
Have you checked level front to back (and of course side to side)?  Sometimes a tiny little bit of difference can make a big difference in pushing effort, in particular.
 I would also make sure that the brake on the top left is not getting in the way, I've had it intrude unexpectedly.
My recollection is that finer looking sawdust is an indication of blade issues,  with kind of long stringy looking "sawdust" being the best indication of a correctly sharpened blade.
My experience is not extensive, newer owner here, so I'm probably not the best person to advise you,  but I'm a quick study, so I'll help where I can.
Keep the dialogue going and let's see if collectively we can help further-- I'll be looking out for what I can learn as well.
 The Peterson folks have a toll-free number (figure in the time difference) , and Left Coast may be able to help as well.
Offline firefighter
« Reply #11 on: October 13, 2017, 11:07:30 PM »
Hi Gary I have a 2009 WPF model .I would also be interested in the sharpener you are talking about could you send me some info on it thanks .Qweaver I was not sharpening the whole tip properly and Chris Brown showed me how to do it the proper way . Give Aaron Kalan a shout on there 1-800 number and he will help you out .
Offline barbender
« Reply #12 on: October 14, 2017, 01:16:05 AM »
A friend has a shop built swing mill, I've seen him have problems sawing when the blade lead was not set correctly.
Offline bandmiller2
« Reply #13 on: October 14, 2017, 06:19:07 AM »
Quint, first thing I would try is a different saw. When theirs a problem with any circular mill the saw and its tension is always suspect, with lead close behind. Frank C.
Offline ButchC
« Reply #14 on: October 14, 2017, 06:39:11 AM »
Glad the see you are figuring it out. I have a sheet somewhere with the sharpening specs for my blades but unsure if they are the same for my smaller mill?
A few years ago I spent a lot of time in your neck of the woods when they built the 4 lane between Buckhannon and Elkins, cooridoor H I think it is called?, we crused the rock. I'd drive down but don't think I have enough experience to be of much help.
Morbark chipper
Case W11B
Offline dgdrls
  • Learning the Art of Milling Logs, Lucas 8/27
« Reply #15 on: October 14, 2017, 07:18:01 AM »
Q'
I'm unclear what your challenge with the mill is,
Sounds like you have the adjustments dialed-in.
is it making bad lumber?
I suspect the Peterson and Lucas share a very similar tooth spec.
Here is what I have in my manual if its any help.
FWIW I would be very conservative on adding more back-angle,
you will be taking strength out of the cutting face of the tooth
keep us posted
Best
D
Offline terrifictimbersllc
    • Terrific Timbers LLC
« Reply #16 on: October 14, 2017, 08:31:29 AM »
The adjustments
-tops of rails are parallel to each other by sighting, sag is taken out by the track levelers in the center, mill rolls freely along length.  A level can help but sighting is more accurate.
-chain lengths hang the mill frame the same everywhere (measure bottom of mill frame to the bottom SS cross members of the end frame at all 4 corners). If engine is at one end then this measurment will be 1/16 or so lower there than at the other end
Blade adjustments, Level the top of a log, then:
-horizontal lean-in, where the blade is tilted down to the right just a little, cut 2" in, then again another 8" in, the ridge from the 2" cut should be visible.
-horizontal criss-cross, the blade marks made by front of blade and back of blade are the same, adjust both nylon rollers the same accordingly
-vertical criss-cross, front of blade marks and back of blade marks are the same, AND, at your end of the log where the blade exits in a pulled vertical cut, the blade can re-enter exactly into this kerf.  Trust the latter more than the criss cross if they're different.  The adjustment is by turning the nuts on either side of the right roller on the head to which the handle is attached.  Removing the handle or turning these without remembering that this affects the adjustment has messed me up before. If the blade exits the log and won't reenter the same kerf there is also a "zinging" sound and there can also be difficulty pulling the saw in vertical cuts with it tending to want to go backwards. Adjust as necessary regardless of criss cross to get the reentry exact.
-vertical intersect adjusted by the stop bolts to get a perfect intersect
Stress in logs can make the above adjustments look off some times but most of cuts should be easy.
Of all these points the least obvious is chain lengths, chain can jump a link on sprocket if something blocks raising/lowering the frame when loading etc.
DJ Hoover, Terrific Timbers LLC,  Mystic CT   2001 WM LT40SHDD (42HP Kubota, Accuset2, FAO's, Lubemizer, debarker, hydraulics everywhere), Peterson WPF 10-30 with chain slabber. Logrite fetching arch, WM BMS250 sharpener/BMT250 setter.
Offline woodyone.john
« Reply #17 on: October 14, 2017, 08:01:18 PM »
I think TT covered most of it but ,
Check the wheels the frame runs on,sawdust or a flat spot will cause quite a lot of resistance.Also if the small grooves are not on the right side the your alignment will be some ways off.Using it like that will result in loss of tension in the blade. As in all things ,small things matter.
Saw millers are just carpenters with bigger bits of wood
Offline Don P
    • Calculator Index
« Reply #18 on: October 15, 2017, 08:32:55 AM »
Just another thought to throw out there. With the discussion on log stress, I've had bowing logs cause all kinds of trouble too.
Offline Qweaver
« Reply #19 on: October 21, 2017, 07:39:43 PM »
Thanks for the pics  Scott.  Your  blade looks like it has more front relief than mine and that may be the problem.  Also Peterson says the tip should have side relief and yours and mine do not look like they do.  My tips were bought from Peterson and should be right.  I got a diamond blade today and will do some work on the tips tomorrow.
DanG and double DanG
Started by chet on General Board
Last post August 31, 2004, 01:33:36 PM
by Woodcarver
moved
MOVED: Peterson Demo Day ...With A Real Peterson Guy
Started by Jeff on Sawmills and Milling
Last post April 09, 2007, 09:42:00 PM
by Jeff
Started by Burlkraft on General Board
Last post July 09, 2017, 10:38:46 AM
by red
Hey DanG
Started by Fla._Deadheader on Sawmills and Milling
Last post December 20, 2002, 04:58:58 PM
by Scott_R
