Baltic Abrasives Technologies
Author Topic: Is this Hackberry or Hickory?  (Read 1337 times)
Offline PA_Walnut
« on: October 19, 2017, 06:51:14 AM »
I have a fair number of these in my woods and have recently cut some down. Having trouble ID'ing them. Is it a pignut hickory? I have other hickories that have a much smoother bark. Any info is appreciated! Not sure if I should make boards or firewood. :) Thanks.
I own my own small piece of the world on an 8 acre plot on the side of a mountain with walnut, hickory, ash and spruce.
LT40HD Wide 35HP Diesel
Baker Portable Edger with Kubota Diesel
Kubota M62 Tractor/Backhoe
WoodMizer KD250 Kiln
Offline TKehl
  • Certified Contrarian
    • Kehlhof Ranch
Re: Is this Hackberry or Hickory?
« Reply #1 on: October 19, 2017, 08:51:08 AM »
Looks like Hackberry to me.  Bark is a little different than here, but the bark on the left side of the picture shows the bark "out-en-ing" in layers instead of flaking off.  Characteristic of Hackberry.  The leaves should look a lot like Elm.
Good wood.  Kind of plain lumber.  Spalts nicely though.
Not great firewood in terms of BTU, but dries down well and splits ok.  Better than Elm.
Offline goose63
« Reply #2 on: October 19, 2017, 04:22:18 PM »
Sure looks like Hackberry people here like it for fire wood I like it on the saw mill makes good looking lumber
goose
thank you to all the vets
Offline DPatton
« Reply #3 on: October 19, 2017, 06:12:25 PM »
I agree, it looks like Hackberry.
TimberKing 1600, 30' gooseneck trailer, Chevy HD2500, Echo Chainsaw, 60" Logrite.
Work isn't so bad when you enjoy what your doing.
Offline WanderWonder
  • Forestry Student - SIU-C
« Reply #4 on: October 19, 2017, 07:00:09 PM »
Hackberry Celtis occidentalis or sugarberry Celtis laevigata
Offline TKehl
    • Kehlhof Ranch
« Reply #5 on: October 19, 2017, 07:47:07 PM »
Further North than I would expect Sugarberry, but not impossible.
https://en.wikipedia.org/wiki/Celtis_laevigata
Offline PA_Walnut
« Reply #6 on: October 20, 2017, 07:13:01 AM »
Pretty sure it's one of the two. Does it make decent lumber? Mine appear to be 90+ % sap wood with a tiny dark heart pretty well uniform and centered.
If not, I'll make it into firewood for my fire pit!
Thx
Offline WDH
  • April 1998 - August 2008
    • hamsleyhardwood.com
« Reply #7 on: October 20, 2017, 07:48:40 AM »
It is in the elm family and has spiral grain.  If you flatsaw it, you will lose a lot of it to excessive twist and warp.  It is best to quartersaw it.
« Reply #8 on: October 21, 2017, 05:01:39 PM »
Ah, I didn't even think of the range.  Southern Illinois is the outermost part of Sugarberry's range and it's commonly confused where I'm from, so that explains it.  Definitely Cetlis occidentalis! !
Offline WDH
« Reply #9 on: October 21, 2017, 10:07:51 PM »
They interbreed and the diffrerence between hackberry and sugarberry is very technical and obscure.  Pretty much takes an expert to tell them apart.  Very, very minor differences, so it is only a botanical issue, not a practical one.
Offline PA_Walnut
« Reply #10 on: October 22, 2017, 08:15:54 AM »
Thanks for all the info. I will saw one up and see what the lumber looks like. Making a bunch of pallets for stickering and stacking my lumber piles, so if nothing else, I'll make pallet boards with them!  :D
Offline WDH
« Reply #11 on: October 22, 2017, 07:50:19 PM »
If you flat saw it, get ready for airplane propellers.
Offline BigBurOak
« Reply #12 on: October 29, 2017, 09:26:33 PM »
Let the cut logs sit for six months without doin anything to em and they should spalt beautifully. Definitely need to quarter saw unless you want a piece of unique and expressive modern art. You may need to stabilize the boards if you spalt em as they can get pretty soft sometimes. There is definitely a market for it.
Who needs a gym if you got a woodpile?
3 sided husk on hickory nut - what type of hickory is it?
Started by Lanier_Lurker on Tree, Plant and Wood I.D.
Last post August 25, 2007, 09:18:14 AM
by Lanier_Lurker
Hackberry
Started by Knute on Sawmills and Milling
Last post May 18, 2010, 12:38:04 PM
by OneWithWood
Hackberry
Started by Tree Feller on Sawmills and Milling
Last post October 11, 2012, 01:24:57 AM
by 5quarter
Hackberry
Started by D6c on Sawmills and Milling
Last post November 03, 2018, 07:44:00 AM
by D6c
