Author Topic: Pulled the trigger on a Fire Chief outdoor furnace  (Read 5356 times)
Offline Woodcutter_Mo
Re: Pulled the trigger on a Fire Chief outdoor furnace
« Reply #20 on: November 26, 2017, 02:23:01 PM »
It's not ducted yet but I fired up the furnace to test it out and burn off the oil stuff from the manufacturing process. It seems to be working good. 8)
- WoodMizer LT25, Kohler, all manual, old "drag" style WoodMizer sharpener, cat claw single  setter
- Husqvarna 372XP X-Torque/24" bar, 455 Rancher X-Torque/20" bar, 550XP/20" bar, Stihl 024AV/18" Oregon speedcut
- Kioti DK45, '92 Dodge Cummins with Cannonball  bed, '07 Honda Rancher
« Reply #21 on: November 28, 2017, 01:29:08 PM »
 Last night I cut a hole in the sub floor to create a better access to the crawl space for when I run the ducting. In the process I found some issues in the floor joists and original sub floor. So I'll be tearing out my entire living room floor and replacing the joists. The up side is although the furnace install will be delayed, it will be alot easier to run the duct while the floor is out. I'm just glad I found this issue in the process before a joist broke or worse.
« Reply #22 on: January 06, 2018, 03:54:10 PM »
 Well, for now I decided to run just one main central duct outlet into the house to use until I am able to run the rest of the duct work. This way I can give the furnace a good test atleast and be able to use it as it's going to be a while until I can finish the duct work. Today we are running the hot pipe and return into the house.  ;)
« Reply #23 on: January 12, 2018, 09:32:12 AM »
 Well I got the ducts piped into the house yesterday just before the cold front got here. I will be simply installing a single outlet for now until I get the floor and joists fixed in the living room. I have a return box and grill/filter housing ordered and on the way. I will add one more section of chimney, get some electricity to it, install the thermostat inside and get it fired up this weekend to give it a good real world test.
 I'll give an update on how it works out.
Offline samandothers
« Reply #24 on: January 12, 2018, 10:07:57 AM »
Bummer on the floor.  Glad you’ll have heat soon!
« Reply #25 on: January 14, 2018, 05:49:52 PM »
 I didn't get the rest of the chimney installed yet but I have the single 10" heat supply pipe up through the floor and the 12" return towards the other end of the house installed to use until I can finish it up properly. I have a good fire going and it's working good. The hot pipe isn't insulated for the first few feet coming out of the furnace yet but but other than that it's doing a good job. The windows are open at the moment because the furnace is still putting off some fumes from being new.
« Reply #26 on: January 16, 2018, 09:53:13 AM »
 The furnace got a good work out last night, it got down to -3F.
 I loaded up the firebox with some seasoned black Oak rounds that weren't super dry as they haven't been covered. I didn't completely fill the fire box, the rounds were about 18-20" avg length so there was about a foot of space left. I loaded it up about 9:30 and at 6:00 this morning there was still a nice bed of coals so I just loaded it again and it fired right back up. The draft blower is apparently high enough up that it can keep a good bed of coals in the bottom. It got down to about 61°f in the house, which isn't too bad considering all the air gaps there are with me working on the house. And also the first few feet of the hot air pipe outside isn't insulated yet.
 I think I'll be very happy with this furnace especially once I get the hang of it and get all the ducting installed properly.
Offline TKehl
  • Certified Contrarian
    • Kehlhof Ranch
« Reply #27 on: January 16, 2018, 10:13:52 AM »
Sweet!
And thanks for the report on having coals remaining.  I've been leary about running a stove with a draft blower as I expected to have to relight it frequently with the blower pushing air until the coals were gone.
Sounds like it has a nice large firebox.  Sounds quite a bit bigger than mine!
"A successful man is one who can lay a firm foundation with the bricks others have thrown at him."  David Brinkley
« Reply #28 on: January 16, 2018, 10:43:13 AM »
 I think as long as the draft blower is installed high enough above the grates to where it doesn't blow directly  into the coals it would probably do fine. I'll certainly be learning more about it as I use it. I was somewhat surprised honestly.
 The firebox is listed as 11.00 cubic ft and will take firewood up to 34" long.
Offline gspren
« Reply #29 on: January 17, 2018, 08:49:58 AM »
  Is your draft blower controlled by a thermostat?
« Reply #30 on: January 17, 2018, 10:01:45 AM »
 Yea the thermostat in the house controls the draft blower on this furnace.
 On a side note, it is still putting off a bit of a smell when the furnace gets good and hot. So if anyone else installs one, be sure to give it a good pre-burn to break it in before hooking it up or plan to keep the windows open all day the first couple times you fire it up.   ;)
Offline TKehl
    • Kehlhof Ranch
« Reply #31 on: January 17, 2018, 10:13:38 AM »
Have any Hedge?   ;) ;D ;D
« Reply #32 on: January 17, 2018, 12:49:51 PM »
 Dont got any hedge around here, but I though about tossing a few pine knots in the firebox and opening the draft a bit and letting it rip for a while  :o :D
Offline dave_dj1
« Reply #33 on: January 25, 2018, 05:29:03 PM »
As you get used to burning it you will learn what and what not to do depending on the weather and temps. I do not believe in the forced draft, I think it burns too much wood. I don't even have a thermostat hooked to the draft of mine. I have a wind up timer on the stove, I know how long to set the timer for after i fill it depending on the weather and temps. I have some half inch holes in the door that I plug with 1/2" bolts, I take a bolt or two out depending on how cold it is. I just installed a new door gasket and I can get 12-14 hr burn times on about 5 pieces of wood and a ton of coals. I am heating about 1800-1900 sf in a ranch home with finished basement.
« Reply #34 on: February 22, 2018, 10:24:00 AM »
 Just an quick update, so far I'm still very pleased with the furnace especially since I'm getting more familiar with it. I've only had to light the fire a couple times, it holds coals very well. The times I had to re-light it we're after warm days where I didn't add wood for a day or 2. I've been leaving the thermostat at 67°F and the draft blower runs very little, but the house will still stay in the 70's at near 0°.
 I will be installing a proper size draft blower on it as I have an oversized blower with the intake dampened down pretty low on it at the moment.
 It's easy to clean the ashes out, I just let it burn down to coals and rake the ashes with a garden hoe, which the grate is the same width as. The ash pan holds exactly what fills a standard ash bucket.
 I'm still in the learning curve, so as mentioned i can probably get better burn times and efficiency as time goes on. But so far I'm very happy with the purchase.  8)
Offline dave_dj1
« Reply #35 on: March 02, 2018, 08:41:13 AM »
Nice, thanks for the update. Like I said, there is a learning curve and once you find what works just keep doing it. I think you're on the right track keeping the blower use to a minimum.
« Reply #36 on: October 16, 2018, 09:53:23 AM »
 Season 2 with the Fire Chief furnace. A few days ago I plugged it in and fired it up, still looks and works like new. I'm still very happy with it and impressed with it vs my old indoor wood stove.
 Last winter I only had to light the fire a few times, of which a couple times I let it go completely out so I could clean it ect. It held coals very well, I assume because the blower is up fairly high.
Offline hedgerow
« Reply #37 on: October 16, 2018, 12:15:08 PM »
Good to hear the furnace is working out. Its nice to keep the mess that wood makes outside. Looks like the weather is going to warm back up. Its always nice to get these cool dip's early so we check wood supplies and wood burning equipment before the cool sets in.
Offline Pine Ridge
  • Part-time logger, Full time loafer
« Reply #38 on: October 19, 2018, 09:51:42 PM »
I installed a fire chief 2200 in our doublewide this summer woodcutter. I fired it up a week ago, it puts out the heat, i've got it too warm in the house a couple of times already. I think it will do great when it gets really cold this winter. I'm still learning what to do and what not to do with it, so far i'm satisfied with it.
Husqvarna 550xp , 2- 372xp and a 288xp, Chevy 4x4 winch truck
« Reply #39 on: October 20, 2018, 03:45:23 PM »
Glad to hear you like yours so far. Do you have it ducted into the central heating ducts?
One thing I've found with mine is I only open the spin draft on the ash drawer when it's prety cold. I keep it closed when it's somewhat mild or it will run me out of the house. And it don't have to be open much. You will get used to it though.
On a side note, one thing I would like to add to my furnace is a shield that goes over the draft blower to keep wood chips from getting in the fan and motor when loading wood into the door. I believe the newer models that were being sold at Menards had these shields on them. I've only had trouble with it once, but I can see it potentially giving trouble again.
fire chief FC 1700
Started by OH logger on Firewood and Wood Heating
Last post November 24, 2017, 07:56:39 PM
by OH logger
pulled the trigger
Started by raven737 on Sawmills and Milling
Last post April 27, 2010, 11:01:25 PM
by Magicman
Almost pulled the trigger……just could not do it.
Started by POSTON WIDEHEAD on Sawmills and Milling
Last post October 01, 2014, 07:37:51 PM
by ozarkgem
thumbup
Kwasie, Pulled the trigger
Started by kwasie on Sawmills and Milling
Last post September 07, 2017, 06:39:08 AM
by 47sawdust
